This is a discussion thread titled "Tundra X-TREME low idle on startup...", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-27-2003, 06:19 PM
Avionix's Avatar
Last Online: 08-27-2004 02:40 AM
Avionix is on a distinguished road.
Send a message via AIM to Avionix Avionix's Photo Albums
Question Tundra X-TREME low idle on startup...
I have a failry stock Tundra, and recently the engine seems to have trouble idling on startup. It usually idles at about 750rpm's but on an intermittant occasion, the thing will idle below 500 and almost cut out. I've noticed this w/ and w/o the AC on, so I don't know. My guess is it would be the AC Idle Up relay, but...any help would be great. Thanks.
-=A=-
Old 09-28-2003, 01:13 AM
Dealer : Carson Toyota Scion
Last Online: 12-11-2008 11:55 PM
Alan is on a distinguished road.
Alan's Photo Albums
Post
There’s actually a diagnostic code for this, so if it’s a real issue, I think you’d get the MIL (malfunction indicator lamp [i.e., check engine]) warning. Mine has been idling low, but I never thought much about it. A thousand miles ago, the MIL came on and I scanned it - P0505 Idle Control System Malfunction. I reset the light and all was well until last week, whereupon my MIL turned on again. Curiously, it’s been cycling on and off all week. I never knew the MIL could turn itself off. I’ll probably scan it tomorrow (since it’s currently in the ON state), but I think it’s still the idle thing…I need to eventually dig into it.
Anyway, the short answer is…I think your MIL would illuminate if a real idle system problem occurred.
Stay shiny,
Old 09-28-2003, 10:23 PM
Alan's Photo Albums
Lightbulb Problem Solved
My problem turned out to be nothing more than a dirty throttle body. An hour of q-tip cleaning today and the idle is back within spec. I’ll post some photos in the throttle body cleaning thread.
So I’d suggest this as a possible cause for your low idle too.
Stay shiny,
Old 09-28-2003, 10:43 PM
Avionix's Avatar
I spent an hour or so with the intake system in pieces yesterday. No dice, didn't do a thing. Well, it improved accel and performance, but other than that...even pulled the ECU fuses. I think it might be some type of idle valve or relay, but not sure what to do about it yet.
-=A=
Old 09-29-2003, 08:10 AM
Dealer : Russel Toyota
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
Usually cleaning the throttle body (briskly with a tooth brush and TB cleaner), along with a good fuel injector cleaner cures this for me. If, after that, idle is still low, I'd clean and regap the plugs. After this, I would have to assume something is wrong.
Old 09-29-2003, 09:10 PM
Last Online: 12-24-2007 11:59 AM
Tundradad is on a distinguished road.
Tundradad's Photo Albums
-=A=
I adjusted my throttle cable... (2000) 03's do not have one. I needed to get my idle up a bit, it was just below the bottom mark, I raised it to just above the bottom mark with A/C off and all is fine (probably 50 to 100rpm's). cable is not too tight at full throttle, you just have to adjust it a little to get the right spot. Dealers could not do it & could not find anyone who could give me info.. After I did all the cleaning & adjusting that may have been the reason for low idle I adjusted the cable & it is now as smooth as can be and where it should be. pedal is right where I like it & I think where it was when I bought it.. Cables do stretch & I did slam it occasionally!!!! Hope this is a help
Old 10-01-2003, 05:09 PM
Johnny Law's Avatar
Moderator
Dealer : Haddad Toyota
2005 Toyota Tacoma
Last Online: 01-03-2009 08:29 PM
Johnny Law is on a distinguished road.
Johnny Law's Photo Albums My eBay
I didn't see this posted, so I will throw it out there. Did you check your PCV valve and air filter lately? My '94 Dodge had this same problem, it had low miles, but the PCV was plugged up with oil and the air filter was dirty. My idle was so low at times, it would actually stall out. Might be worth checking into to at least rule it out.
"Si vis pacem, para bellum"-Vegetius
2005 Tacoma Doublecab TRD Offroad 4X4 shortbed - Modifications - Fog light mod, Debadged, Black Toyota grille emblem, Map Light Mod, DRL mod
Factory Accessories - Tacoma Bedmat, Extra set of D-rings installed in front bed bolts, Extra set of factory tie downs
Optional Options - FilterMag, Fumoto valve, Westin Suregrip running boards w/LED lights, WeatherTech Floorliners, WeatherTech window visor vents, Prestige remote car starter w/keyless entry, SilverStar headlight and turn signal bulbs, Toytek 2" lift, Muth heated signal mirrors, WAAG grille guard (center only, I'm old school), Taillights tinted by JonsTintedTails.com, Anthracite FJ Cruiser wheels w/ 265/75r16 BFGoodrich A/T
Old 10-01-2003, 05:24 PM
Avionix's Avatar
Hadn't thought of that...for the reason that I'm not familiar with it. I do a lot of stuff to this truck, but I'm not ASE or anything so I'm still new to somethings. If you could, tell me, what and where that is, I'd check it out. It's not cables, or plugs, those are all new almost. Something's up with the way it sucks down air so...a PCV Valve sounds like it could be in the mix...if I know where that was. Thanks for the help!
-=A=-
Old 10-01-2003, 05:51 PM
Johnny Law's Avatar
Moderator
2005 Toyota Tacoma
The PCV should be wrapped in a foamy type tape on the driver's side of the engine block. Its kinda black/gray stuff and you have to unwrap it carefully, but its there. Its on top of the valve cover and it goes into the throttle body right behind the butterfly. Once you expose it and pull it out of the valve cover, clean with some chem tool to get all the gunk out, or just buy a new one. Make sure you also check the air filter, and also the air filter intake to make sure there are no blockages. Hope that helps!
Old 10-01-2003, 07:53 PM
Avionix's Avatar
Cool, thank you. Gonna go look into that right now.
-=A=-
Bookmarks
