This is a discussion thread titled "Rear axle seal leaks caused by syn. gear oil", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 10-03-2003, 02:18 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
be sure to only use regular gear oil in your rear diff as per the most recent Tundra TSB. Syn will cause axle seals to leak (00-02 only).
Glenn:
I saw this mentioned in another thread. Can you post a link to this TSB if available?
Thanks,
Bob
ADDING POWER HAS NEVER BEEN SO FAST!
Old 10-03-2003, 09:23 AM
Dealer : Herrin-Gear Toyota-Scion
2001 Toyota Tundra,
2004 Toyota Tacoma,
2008 Toyota Tacoma
Last Online: 01-04-2009 11:17 AM
MrGrowl791 is on a distinguished road.
MrGrowl791's Photo Albums
Default Rear axle seal leaks caused by syn. gear oil
What's this about syn. gear oil causing rear axle seal leaks? I have a 01 tundra with syn. in rear diff. Thanks
Old 10-03-2003, 09:33 AM
nhparrot's Avatar
Assistant Administrator
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
Last Online: Today 05:04 AM
nhparrot's Photo Albums
See the TSB DL003-03 posted in the thread Requests for TSB's
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 10-03-2003, 01:54 PM
nhparrot's Avatar
Originally Posted by hovisimo
any idea how the seals are incompatible? this is wierd. i don't doubt that this is a major problem, having replaced 2 front and 1 rear seals, but it's unacceptable that it took toyota 3 years to tell us we should not be running synthetic gear oil.
I do not know and the side note in this TSB is the first I have ever heard of it. I will pose a question to Toyota's National Customer Assistance Center via their website.
~Glenn~
Forum Rules
HERE!
Old 10-03-2003, 09:36 PM
nedjames's Avatar
Dealer : Yokem Toyota
Last Online: Yesterday 10:04 PM
nedjames is on a distinguished road.
nedjames's Photo Albums
What should we look and listen for if we have a leak? Hov, you've had to change your seals, what got your attention. This is bumming me out! I thought I was doing a good thing putting Mobil 1 in the diff, but I will change it out if I get enough info. Anyone else had axle seal problems?
Old 10-03-2003, 11:04 PM
nhparrot's Avatar
Just as a followup and headsup to folks. On August 6th, TSB DL002-03 titled REAR AXLE SEAL DESIGN CHANGE was issued. This TSB is applicable to ’01 – ’02 Sequoia, ’95 – ’02 Tacoma & ’00 – ’02 Tundra. The TSB states "The rear axle seal lip design has been changed from a flat face type to an angled face type."
Another TSB, DL003-03, was issued October 1st. This TSB is titled SYNTHETIC REAR DIFFERENTIAL FLUID MAINTENANCE AND REPAIR INFORMATION and applicable to ’03 – ’04 Sequoia & Tundra vehicles WITHOUT Limited Slip
Differentials (LSD). DL003-03 states "The 2003 – 2004 Sequoia and Tundra rear axle assemblies have a synthetic fluid with special additives installed during assembly. Maintenance intervals for the rear differential fluid have changed as a result." The TSB goes on to explain the how to determine proper inspection and replacement intervals for Toyota Genuine Synthetic Differential Gear Oil, Non–Toyota Synthetic Differential Gear Oils and Mineral Differential Gear Oils.
A note in DL003-03 states that "Toyota Genuine Synthetic Differential Gear Oil (P/N 00289–75140) CANNOT be used in 2000–2002 Tundra vehicles and 2001–2002 Sequoia vehicles. The rear axle oil seals are not compatible and will leak if synthetic differential gear oils are used in these vehicles."
I have emailed Toyota's National Customer Assistance Center for clarification around the use of synthetic gear lubes in the front & rear differentials and transfer case. As soon as I hear something back, I will post it here.
~Glenn~
Forum Rules
HERE!
Old 10-03-2003, 11:30 PM
kelltl's Avatar
Last Online: 08-20-2008 05:20 PM
kelltl is on a distinguished road.
kelltl's Photo Albums
You gotta be kidding me. I just changed both diff's and transfer case over to Mobil1 synthetic last weekend. Mine is an 02. Thanks for email Toyota....I hope you get more of a response than I figure corporate will give.
Old 10-03-2003, 11:54 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Keep in mind that there are several different types of synthetic base oils and different types of seal materials. Lots of us have many thousands of miles on our trucks with the popular synthetic gear oils and no problems.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 10-04-2003, 03:47 PM
Dude Boy's Avatar
2000 Toyota Tundra,
This is unrelated to automotive use, but I run synthetic oil in some of the ammonia compressors that I have at work. A few of them experience problems with shaft seals due to shrinking and hardening of the elastomers used in construction of the seals. Right now I can't remember if the effect is due to the synthetic oil itself or the additive package. The problem seems to be worse on Nitrile (Buna N) parts than on Neoprene.
Old 10-04-2003, 11:56 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 01-01-2009 05:17 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
Thanks Glenn. Im sure there are quit a few of us that will be interested in what they have to say.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 10-05-2003, 02:23 AM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 02:04 AM
RichR is on a distinguished road.
RichR's Photo Albums
Default Me Too!
I have had Mobil Synthetic in t case and diffs for about 20k-18 months.
I am wondering if this might be a breather vent problem?
A member had to replace seals. I had a pressure build up in rear diff that I used the breather mod to fix.
Or we might need to go to a blend type lube.
Please post the response Glenn!
Thanks
RichR
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Old 10-05-2003, 09:05 AM
nhparrot's Avatar
----- Original Message -----
To: nhparrot@comcast.net
Sent: Friday, October 03, 2003 1:44 PM
Subject: Use of Synthetic Gear Oil [Incident: 031003-000035]
Thank you for contacting Toyota Motor Sales, U.S.A., Inc. We apologize; at this time we are experiencing extremely high volume. We appreciate your patience. Please understand that it may be several days before we are able to respond to your email. If you need immediate assistance we recommend you contact the Customer Relations Manager at your local Toyota dealership. You may also reach our National Customer Assistance Center by calling 1-800-331-4331 Monday through Friday between the hours of 6:00 AM and 6:00 PM Pacific Time. We appreciate your consideration and hope to have your email addressed as quickly as possible.
Discussion Thread
Customer (Glenn Arsenault) 10/03/2003 10:44 AM
A Service Bulletin (DL003-03) released recently specifies that Toyota synthetic differential gear oil CANNOT be used in 2000–2002 Tundra vehicles and that the rear axle oil seals are not compatible and will leak if synthetic differential gear oils are used in these vehicles.
Is this true? Can any synthetic gear oils be used in the rear differential without causing damage? Does this also apply to the front differential and transfer case?
Thank you
~Glenn~
Forum Rules
HERE!
Old 10-05-2003, 12:09 PM
KDTundra's Avatar
Dealer : Riley Toyota
2001 Toyota Tundra,
1999 Toyota 4Runner,
2001 Toyota RAV4
Last Online: 11-18-2008 03:00 PM
KDTundra is on a distinguished road.
KDTundra's Photo Albums
Angry Those who already switched???
I wonder what this means to all of us who made the switch from dino to synthetic and will probably run into problems down the road?
I have read the TSB and although it specifically states that you shouldn''t use Toyota's Synthetic nor any non-Toyota synthetic, it's bit too late for some of us!!! Drain and refill w/ dino and hope nothing happens????
KDTundra
2001 Tundra Access Cab, SR-5, 4X4, TRD Off Road Pkg., 4.7 L, Stellar Blue w/ ARE "Z" Series camper shell. Flowmaster Cat Back Exhaust System #17425.
1999 4Runner SR-5, 4X4 w/ "Highlander" Sports Package, 3.4 L, Imperal Jade.
2001 RAV 4 L, 2x4, 2.0 L, Black w/ silver trim
Old 10-05-2003, 03:20 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 03:11 PM
DevinSixtySeven is a splendid one to behold. DevinSixtySeven is a splendid one to behold.
Default huh??
i'm going to stick with not believing the hype, and running mobil-1 75w90 synthetic. lemme guess, not using toyota fluid will void the warranty? i have not had any problems with my seals, plugs, diffs, etc...i have an extended and vented rear diff breather, so everything leads to the engine compartment, and i do not think that an axle seal clogged with dino oil resi
