Old 10-09-2003, 09:06 PM
Genthar's Avatar
Last Online: 11-05-2009 09:51 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
Default AEM Brute Force Intake Tour Writeup- LONG
Ok, here's the writeup that I've done for the AEM Brute force intake. There are also lots of pictures available here, but beware, the images are fairly large. Feel free to ask me any questions you may have, and I'll try to answer to the best of my abilities.
AEM started in 1987, and quickly became a big player in the import sport compact market with their performance intake systems. Now sporting a large line of products and upgrades, including fuel management systems, fuel rails, tuned intakes, and other goodies for the sport compact market, AEM is bringing it’s expertise to the ever growing truck and SUV market with their Brute Force line of intakes.
I was the lucky winner of an AEM Brute Force intake for the Toyota Tundra 4.7L V-8, through TundraSolutions.com. My contact at AEM was their Internet Director, David Salvaggio. After some back and forth e-mails and phone calls, the date was set, and I made the short trek to Hawthorne, CA, and the AEM Headquarters.
After meeting David, he gave me a tour of AEM’s main warehouse, distribution, and administrative facility, at the Hawthorne facility, including their prototyping shop area. Their main manufacturing facility is located elsewhere (unfortunately I didn’t get the chance to check that out as well.) Their warehousing facility is quite impressive however. Rows and rows of parts are neatly stacked on the racks while the workers bustle about pulling parts and preparing kits for shipping.
In their prototyping area, they had a new Neon RT Turbo in the early stages of prototyping. The intake tubes were being fitted and spot welded by some of their engineers while they checked for clearances and positioning. In the meantime, in another corner a Mitsubishi Evolution was getting fitted not only with an intake, but one of AEM’s engine management modules. A brand new Dodge Ram 3500 was just having its completed prototype removed, while two other special vehicles were housed in this area. These special vehicles were Larry Ragland’s pre-runner that he uses for the Baja 1000, and the AEM/DriverFX.com Civic, driven by Stephan Papadakis, currently the fastest FWD Sport Compact in the world with an with a best e.t of 8.12 and a best mph of 184 MPH! The company’s PRO RWD drag car runs 6.90s at 208 mph!
AEM’s prototyping goes beyond just fitting the pipes to the engine compartment. At their facility, they have their own dynamometer where they test the vehicles out under different loads and conditions to better understand the performance curve at locations other than peak and W.O.T. They also purchase and test their competitor’s products and ensure that their model outperforms their competitions models. Each model is prototyped and tested repeatedly until they are satisfied with their performance before any model is released. Also during testing, they determine if their throttle-body spacer will be effective on the vehicle. They admitted however, that probably nobody in the industry really knows why a throttle body spacer works on some vehicles but not on others. They include one in their kits where their testing has shown it helps.
Quality control is fairly tight. During production, samples from the current production run are not only tested against a jig to ensure that the bends and lengths are correct, they are also fitted on actual vehicles to make sure that they fit properly. The Brute Force intakes also come with a Limited Lifetime warranty, and are all 100% made in the USA. The intakes are constructed from CNC mandrel-bent 6061 aluminum with TIG-welded fittings and brackets.
AEM uses Aluminum rather than plastic due to the way they design their intakes. The whole idea is to get more air/fuel to the engine. That’s the way you make more power. AEM’s engineers realized that sound waves are compression waves, and that timing and tuning the intake can cause the peak of the wave to hit the intake valves, causing more air to be pushed into the chamber. Plastic tends to absorb the sound waves, reducing the compression, however aluminum reflects the sound waves, keeping them moving along until it gets to the engine. That’s the secret to how AEM’s intakes work. Rather than just reducing restriction and allowing more air to flow, they actually tune the intake to get those compression waves to go where and when they want them to go.
The tour done, we grabbed Greg Nakano, one of their engineers, and headed off to R&D Dyno to do the testing and installation on my Tundra. They chose the third party dyno rather than their own facility to provide a neutral testing ground.
Pulling in, and strapping down the truck, Greg proceeded to do a few trial runs before recording the three main pulls that would form the baseline values. I asked about their dyno procedure and here’s what I got:
1) They don’t move the vehicle once it’s strapped down. They’ve found that just repositioning the vehicle on the dyno can give different readings even without modifications.
2) They perform the testing with the hood up and fans blowing toward the engine compartment to better simulate the airflow that you would encounter while driving. This makes sense to me because while you’re driving, air is flowing through the engine compartment via your forward motion.
3) They perform 3 pulls before and after to reduce any random hot runs.
4) At their facility their dyno can do load testing so that the whole curve can be seen from low to high RPM, different throttle positions, and under different loads. Unfortunately it’s not a Dynojet, so people are less accepting of those results, than one done off of the more familiar Dynojet dynamometer.
The three baseline runs produced an average HP peak of 202.1@5000 RPM, and an average TQ peak of 267.9@3500 RPM. Mechanically my truck is still a bone stock 4.7L iForce V-8, with the automatic transmission.
The installation took around 20 minutes, and probably would have been done in 15, if I hadn’t kept sticking my camera in Greg’s way, while taking pictures. The installation is very straightforward, and I imagine your average shade-tree mechanic could easily have it done in 30-45 minutes. The kit comes with all the parts needed to do the install, including some longer replacement vacuum lines to reach the new intake. Some of the connectors are cushioned to allow the engine to flex and move about without flopping the intake about. The installation procedure is well written out in the instructions included with the kit
With the installation done, Greg again made a few trial runs, partially to let the ECU figure out what’s going on, and partially to make sure that he did it the same way. And again, ripped off 3 runs.
The three post install runs produced an average HP peak of 208.9 HP@5000 RPM, and an average TQ peak of 270.0@3500 RPM, good for +7 HP, and +2 lb/ft over stock. Not too bad! The sound however is incredible! Under light to moderate throttle, there’s not much difference in sound over stock. Freeway speeds, under normal throttle is the same quiet engine, though with the Brute Force, you can barely hear sort of a sucking sound under light acceleration. However, start to stick your foot in it, and the Brute Force starts to come alive with a snarling growl that quickly builds to a roar that really grabs your attention. My butt-dyno tells me that there’s not a drastic difference in feel before and after, however, the power does seem to come on more quickly and smoothly versus stock, and the revs seem to climb more quickly towards that red-line when I punch it. Overall I’m very pleased with the intake.
I would really like to thank David and Greg for their time and patience in answering all of my questions, and of course AEM and TundraSolutions.com for the intake, and R&D Dyno for the use of their facility.
Some answers to questions from the TS Members and some that I thought may be of interest:
There isn’t a Tundra V6 application right now. Greg seemed to think that the Tacoma version might fit, but he wasn’t sure.
The graphs from the Dynojet don’t go any lower because the truck loses traction when you start lower (Greg tried a few times and just couldn’t get it to stay hooked up.) I asked about possibly getting copies of the engineering test runs on their dyno (rather than the ones from the Dynojet) and he said that they might not have them anymore, but it would be simple to re-test a truck and make new ones. Their dyno allows them to perform load testing, which would allow them to get the full RPM range of values, however, it’s not a Dynojet, and they’ve often run into some resistance because:
1) It’s theirs, and not an independent third party.
2) “it’s not a Dynojet like everyone else uses.”
They were going to look into the possibility of doing this and getting me copies of the runs so we can better see the whole power curve.
The ECU Reset period – With a MAF the system knows immediately that the airflow has changed and changes the map fairly quickly. With some of the older MAP designs, it could take a while for the system to remap for the new flow.
They choose vehicles like all other manufacturers do – based on popularity. Their engineers and design teams try to keep their ear to the industry and the consumers, so they can create products as the demand appears. A vehicle that may be popular, but with no demand for tuner parts (say a Buick Regal or something like that) would probably also not have anything designed for it. After all they are a business. Currently for the Brute Force line, they’re working on models from 2000 – 2004. After that, they will go back and start creating versions for pre-2000 model vehicles.
Genthar
Old 10-09-2003, 09:35 PM
03TundraTRD's Avatar
Last Online: 03-15-2007 08:11 PM
03TundraTRD is on a distinguished road.
03TundraTRD's Photo Albums
That sucks that there is no V6 Tundra app. I think that the Tacoma intake will be a little too short in the tundra engine bay , but I still am going to buy it and try it out so the V6 Tundra guys won't feel left out. Hopefully it will give some performance.
MODS: SpinTech Pro Street Muffler, Panisonic MP3 player, BellTech 1'' Drop Shackle.
Old 10-09-2003, 10:47 PM
Genthar's Avatar
Originally Posted by hovisimo
i'm glad you didn't lose any torque, but 7 HP at 5000rpm is not useful, how often do you hit 5000rpm? can you post the dyno graph?
Graphs are posted in my photos along with a number of other photos. There's a link at the top of my initial message.
Genthar
Old 10-10-2003, 12:45 AM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
1.3 hp gain @ 3500 rpm...not much for the money.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 10-11-2003, 12:32 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 11-05-2009 02:18 AM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
Great job on the write up Genthar! Professionally done! Have fun with your new horsepower gains.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 10-11-2003, 03:40 AM
icarusarna's Avatar
2003 Toyota Tundra
Last Online: 09-03-2009 08:47 PM
icarusarna is on a distinguished road.
icarusarna's Photo Albums
Good write up Genthar, ahahaha maybe you should work for like a import racing magazine or Sport Compact Car. Hmmmm....i thought the AEM would at least give a better horsepower and torque reading, then again its not a COLD AIR INTAKE that you can get like most Hondas where you can make lots of HP and some torque. I still like the looks of it, now i guess we have to add the RAPS to it make hopefully make another HP gain.
Old 10-11-2003, 03:43 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 08-20-2009 06:58 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
When I installed my muffler and put it on the dynamometer I had only driven the truck I think about 150-200 miles. The air fuel ratio was overly rich and off the charts. When I installed the stock exhaust back on it climbed back up to about 11.2 to 1. I suspect that when AEM installed their intake and made there runs they didn’t get the kind of power they expected because the computer in the Tundra richens the air fuel mixture and then relearns the proper ratios over time. If they had allowed about 500 miles of driving they might see that the gains could be much more.
When I installed my headers I was disappointed when I first drove the truck because I could not feel a difference in power. After driving the truck a few hundred miles the difference was becoming more and more apparent after every new start cycle. Even though setting up the truck on the dynamometer can skew the results a little I think if you did it again after 1000 miles of driving you would see bigger gains.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 10-12-2003, 11:09 AM
jbtoy's Avatar
Dealer : Boch Toyota South
Last Online: Yesterday 12:37 PM
Images: 55
jbtoy will become famous soon enough.
jbtoy's Photo Albums
Default Is it the same model?
Curious, was the AEM intake, a new and improved version or is it the same unit that is available as part # 21-8401? While not a true cold air system, I wonder
how it performs with headers and modified exhaust (lower restriction). Anyone have some experience or numbers with intake and exhaust upgrades together? Gracias.
John
The Toy: 2000 Tundra 4.7L TRD Limited 4x4 Red Pearl (23.0k Original Miles)
The mod list is long. Check some pics in my gallery for mod detail.
Old 10-12-2003, 06:12 PM
Genthar's Avatar
I believe it was the same Brute Force intake as they originally came out with. Nothing new.
Genthar
Old 10-12-2003, 08:29 PM
keiphers's Avatar
Dealer : West Ashley Toyota
2002 Toyota Tundra Limited White TRD4x4
Last Online: 11-27-2007 02:19 PM
keiphers is on a distinguished road.
Send a message via AIM to keiphers keiphers's Photo Albums
Have you lost low end power? I've got the K & N and have definately lost some low end....
2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
[in the works]: Skidrow Plates / Snorkel / Custom rear bumper / Ruf RTurbo
Old 10-13-2003, 04:05 PM
Genthar's Avatar
I haven't lost any low-end power according to my "butt-dyno". The graphs that I have from a real dyno unfortunately don't start until around 2500 RPM due to the limitations of the dyno testing. The engineer there did try to do some lower-rpm starts, but when the Tundra would downshift it would lose traction and spin the tires. AEM's dyno does have the ability to do load-testing, where they can get the full range of RPM's, but we weren't using theirs. I did ask if they could send me those charts, and unfortunately they'd have to retest a vehicle to recreate the charts. They seemed willing to do that, but I don't know if/when they'll actually do it.
According to AEM, the K&N isn't really tuned...it's just a free-flowing intake (Take this with a gigantic grain of salt since they ARE competitors), which is what causes the power loss at the low end. AEM also does buy competitor models (which I would assume includes the K&N) and tests them against theirs, with the goal of their product exceeding the competition's. Again, this is from AEM's point of view so take it as you will.
Genthar
Old 10-13-2003, 04:07 PM
Genthar's Avatar
Originally Posted by agbayani50
Anyone install or test the AIRAID throttle body spacers? Please respond thanks!!!
What I've generally heard is that the throttle body spacers are fairly useless on the Tundra. AEM doesn't include one with their intake because their testing didn't show any improvement with one. Other's have tried various spacers and the general consensus has been "don't waste your money"
Genthar
Old 10-13-2003, 04:26 PM
v8Toilet's Avatar
AEM claims they design their intake systems to produce the best power by tuning them to the specific vehicle. How did they do this for the Tundra if they already had the intake out without testing it on the dynamometer until months later?
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 10-13-2003, 05:06 PM
Genthar's Avatar
They had already tested it on another Tundra during its development. The one they put on mine is just part of a large give-away they did with a whole bunch of other internet boards similar to TS, for other manufacturers. I think David said they gave away 30 intakes for ford, dodge, chevy, toyota, etc.
AEM is a huge name in the sport compact industry, much bigger than K&N (according to AEM of course ), but they're just now trying to break into the truck/suv market where K&N is the big name so they're trying to spread the word.
Genthar
Old 10-13-2003, 05:08 PM
Genthar's Avatar
Oh, I just got an E-mail back from AEM, and they use a Mustang Dynamometer at their facility. David didn't specify a model.
Genthar
