This is a discussion thread titled "Timing belt replacement", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
  #76 (permalink)
Old 09-30-2004, 09:31 AM
romar's Avatar
Dealer : Boch Toyota South
Last Online: 12-29-2008 06:51 AM
romar is on a distinguished road.
romar's Photo Albums
Originally Posted by TUNDRAV8GEORGIA
have any more pictures be intrested to see them..
thanks
Just posted a few pics in my gallery. I was planning on photos of the whole procedure, but once I got going with the wrenches, that idea fell thru.
Rob
Black 2000 SR5 AccessCab V8 4x4 / Debadged / Tow package / Factory Bedliner / Trans. rebuilt @ 72k / Stone Mountain headers / Flowmaster 50 series dual out the side / chrome tips / slotted and drilled rotors / air box mod / power outlet mod
  #77 (permalink)
Old 10-10-2004, 02:17 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
How do you change the camshaft seals?
I'll probably replace the water pump, tensioner, and idler pulleys every other belt. Or is one of these prone to trouble before 180,000 miles?
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
  #78 (permalink)
Old 10-10-2004, 07:03 PM
Tundrav8yamaha's Avatar
Major Contributor
Dealer : Mike Calvert Toyota Scion
- Other - yamaha,
2000 Toyota Tundra (totalled),
2004 Toyota Tundra Trd Off road Navi,
2008 Toyota Highlander HV limited navi 4wd i
Last Online: Yesterday 11:37 PM
Ken
ken,
I've been doing a lot of research (number one) the belt and water pump must be replaced (you could not have the pump replaced but since there in there might as well spend the $92 dollars and get a toyota water pump ) number two i am not replacing my idler pulley's inless required to do so many master mech will know when these are going bad cost on each pulley and two are required are $55 each ..The cam seal and 3 are required are not needed inless directed by mech and are a cheap part to replace one being $7.90 and the other two being around $12.00 each .I am having the seal's replaced on mine and timing belt tensioner and water pump some extra measures to review (either replace now or wait till the next 80k) i think for me ill buy now and save the cost or repair's down the road at least i know it's done right.Tundra has never leaft me stranded yet except one flat and hey i got dirty changing it which aint that bad ..
my work on my tundra is around $250.00 on labor this is not including all the part's i am getting which is discounted at my end..
ps there isalso mention of a hype adjuster too anybody willing to tell me what this is and what the cost involved to replace it too??
T3 Grill, Line X extra front Bumper coating (too many mod's to list)
www.tundraheadquarters.com (Surporter)
  #79 (permalink)
Old 10-26-2004, 02:12 PM
Dealer : Checkered Flag Toyota
2002 Toyota Tundra
Last Online: 10-23-2005 07:48 AM
generosa5 is on a distinguished road.
generosa5's Photo Albums
Default Timing Belt
I didnt know there was a timing belt on the V-8. Is there one on both engines?
  #80 (permalink)
Old 10-27-2004, 12:01 AM
Dealer : Ken Shaw Lexus Toyota
2003 Toyota Tundra
Last Online: Today 01:57 AM
pagemaster is on a distinguished road.
pagemaster's Photo Albums
Originally Posted by leadsled
I doubt the water pump would make it to the next timing belt change interval (180K). Same for the seals, idlers, etc.
I had a 96 GMC with a 4.3 pushrod engine that had the original water pump at 187k when I traded it in.
I don't know why everyone gets so excited about changing the water pump at 90k when doing a timing belt change. Maybe at 180k interval it is worth doing.
If a Toyota water pump can't make it till 200k then Toyota "reliability" is bs.
  #81 (permalink)
Old 10-28-2004, 01:16 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
Mine went belly up at about 30K. "You asked for it, you got it, Toyota."
ADDING POWER HAS NEVER BEEN SO FAST!
  #82 (permalink)
Old 10-28-2004, 04:01 AM
2003 Toyota Tundra
That's terrible. I hope it was all covered under the warranty period.
  #83 (permalink)
Old 10-28-2004, 09:21 AM
JeffD's Avatar
Last Online: 04-23-2007 11:02 AM
JeffD is on a distinguished road.
JeffD's Photo Albums
The water pump is so easy to change while it is all apart it seems like it would be silly not to replace it. If it fails at say 140K then you will have to do all the labor of a timing belt again just to do the water pump. Shortly after doing my timing belt my fan clutch failed. I added that to my list of timing belt maintenance for next time. I actually considered replacing the alternator just because it was exposed, and how long can they really last?
I did my timing belt and water pump at about 130K, it was easy for me - I didn't think the water pump would last to the 250K mark which was when I was planning to do the timing belt again.
2000 4x4 LTD AC Sunfire Red - Sold w/ 200K
2005 4x4 LTD AC Phantom grey w/ dark grey - Sold w/ 20K
Alpine CDA-9835, W/ KCA-420i, Focal 165KP front, Focal 165V Rear speakers. powered by 2 MMats SQ2150 amps. Alpine MRD-M501 powering a JL Stealthbox with Infinity Perfect 10D VQ
Sound deadened everything with Cascade VB2HD, and Dynamat Extreme
2005 G35 Sedan 6MT - Returned due to paint work on a 'new' car.
2006 G35 Sedan 6MT - all stock. Where do I hook up the trailer and where's the bass?
  #84 (permalink)
Old 10-31-2004, 12:13 AM
Last Online: 10-26-2008 10:14 PM
Tundra2UZ is on a distinguished road.
Tundra2UZ's Photo Albums
I would say a Toyota Alternator would last at least 120K miles. The alternator in my Hi-Lux went at 170K. I had an older Camry where the alternator failed around 140K miles.
If it isn't broke don't fix it.
  #85 (permalink)
Old 11-11-2004, 06:27 PM
Last Online: 09-16-2006 01:00 AM
Intensity is on a distinguished road.
Intensity's Photo Albums
Default Timing Belt Replacement Recommendations
I was told by the dealer that at 90K Tundra's should have the timing belt replaced. I have a 2000. They quoted me $800!!!!!!!!!!!!! WHAT!!!!!!!!!!!!
Any other suggestions out there? Better to go with an independent mechanic and Toyota factory parts? I certainly don't want to spend 8 bills for a frickin timing belt! I might even sell it to avoid such ludicrious cost!!!!!!!!
HELP!
  #86 (permalink)
Old 11-11-2004, 06:51 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim will become famous soon enough.
dyogim's Photo Albums
Changing the timing belt is pretty involved. I suggest doing it yourself. If you don't feel comfortable doing that yourself and don't want to pay $800 with the dealer, start checking with local shops or become good friends with a mechanic.
Mike - http://dyogim.blogspot.com
  #87 (permalink)
Old 11-11-2004, 11:49 PM
Major Contributor
- Other - yamaha,
HELP!
hear's a few suggestion on what i did and the part's involved on my Truck
these are all toyota part's i used on my tundra and cap cost involved on each part...
$93.00 water pump (make sure you get o ring seal for $4.00 too)
$55.00 @idler pully 2 required (it's a ball baring part and very much needed why put on a new belt if this part fail's and you tossed your engine and new timing belt an extra measure that is worth it.
$36.00 toyota timing belt
$7.00 cam seal
$12.00 eaCH@2 engine seal's
$36.00 timing idle tenisioner
MY LABOR FOR ALL THIS IS $250.00 FROM AN OUTSIDE SOURCE..
  #88 (permalink)
Old 11-12-2004, 06:00 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Last Online: 01-14-2008 05:40 PM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
HELP!
Shoot, yer lucky! When I went to SC Toyota they got me for $1100 with everyhting. I had a coupon for $100 and coupon for a free rental car, I think I was all done at $1000. I could have done it but it was much better than spending my weekend doing it, and it was the perfect time-mytax refund just got there.
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/lockrite.htm
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
  #89 (permalink)
Old 06-14-2005, 10:13 AM
Dealer : Puente Hills Toyota
1995 Lexus LS400 Pearl White
Last Online: 09-06-2008 08:14 AM
Lextreme is on a distinguished road.
Send a message via AIM to Lextreme Send a message via MSN to Lextreme Lextreme's Photo Albums
Perhaps this link will give you some idea about the crank and camshaft marks. I wrote this article specifically for the timing marks. http://www.lextreme.com/timing2.html
Good luck.
* 1995 LS400 - Supercharged 5.2 Stroker at work
* 1995 SC470 - 4.7L Tundra Motor Start-up Video
* 1993 SC300 - BHG
* 1993 Previa - Cargo Hauler and Love it!
  #90 (permalink)
Old 06-14-2005, 11:50 PM
