Topic: Oil Change...
Frogeye
TS Supporter
Member # 387
Member Rated:
posted 03-15-2002 05:32 PM
Actually, taking off the skid plate is the way the manual says to do it. It's all personal preference and what works for you. I wanted to eliminate the possibility of cross threading those bolts, too. Hey, TX-Hunter, I see that you have a 50 series Flowmaster on (with duals?). That's the series number I'm thinking of putting on mine, with duals out the back and 3 1/2" stainless tips. Do you like it?
Posts: 28 | From: New Holland, Pa. | Registered: Feb 2002 | IP: Logged
TX_Hunter
TS Supporter
Member # 2582
Member Rated:
posted 03-14-2002 05:45 PM
I take my skid plate off - VERY easy to do, and a lot cleaner
2000 Black Limited V8 TRD 4x4, Daystar full lift, CV boot mod, Chrome wheels, BFG 285/75 R16 AT ko tires, K&N Gen II FIPK, Flowmaster 50 Series muffler, Brush Guard, Hood Guard &
nerf bars
Posts: 16 | From: San Antonio, TX | Registered: Mar 2002 | IP: Logged
Frogeye
TS Supporter
Member # 387
Member Rated:
posted 03-13-2002 05:09 PM
Hey, TundraBear. Sorry it took me so long to get back, but I'm a greenhorn as to how to post photos on the web. I'll send you them as an attachment in an e-mail, though. Thanks. Randy
Frogeye
TS Supporter
Member # 387
Member Rated:
posted 03-08-2002 03:35 PM
TundraBear, I'll try to get a few pics of this in as soon as I can. I don't think it will affect it too much structurally. I cut about a 6"x 6" triangle shaped hole, about an inch up from the rolled edge on the bottom, and about an inch down from the top flange. I also stayed in about an inch from the back flat edge. I think somebody said they did this, in an old forum B/C.
aika
TS Supporter
Member # 87
Member Rated:
posted 03-07-2002 09:36 PM
looks likethe replacement skid plate doesnt have the protective wings on it like the oem one does. it basically looks like a sheet of metal with a bend in it. not much vertical protection from mud from the sides...true or no?
Posts: 154 | From: San Diego, CA | Registered: Feb 2002 | IP: Logged
TundraBear
Platinum TS Supporter
Member # 132
Member Rated:
posted 03-07-2002 09:24 PM
frogeye,
i was wondering if cutting a hole in the factory skidplate affects its strength. i realize that you don't off-road, but that was the second thing that poped into my head. the first is to request a picture of your mod. it sounds pretty cool and i can imagine others would also like to see it.
Get your TS Biz Card today!
a TS windsheild sticker????
although they will deny it...."THE BIG THREE" really means: "THE TOYOTA TUNDRA"
Posts: 85 | From: Los Angeles, CA | Registered: Feb 2002 | IP: Logged
Frogeye
TS Supporter
Member # 387
Member Rated:
posted 03-07-2002 03:37 PM
Since I don't do any off roading, but do like an easier way to change the oil, I did my own mod on the original skid plate. I cut a hole in the left front side, in line with the filter, big enough to get my hand in to get the filter off. I then fashioned a funnel to direct the filter drippings out this hole, and also made a cover that snaps over the hole. It works, looks good,and you have to look close to see anything is different. I now simply turn the wheels full lock left, and can access this area closer, and with no mess.
CJ
TS Supporter
Member # 214
posted 03-07-2002 12:15 PM
Not me. I'm one of them folks who bought and installed one of them thar newfangled Skidplates. See this here item done been designed by people who done their thinking by experience. You get access to that rascally little filter right by nudgin your arm right up to it. Got it a hole in the metal to allow fer right good access to the plug. Darn thing's so well built ya think it would stop a warthog running after ya. It was built to stay on the truck and let you get you fingers dirty maintaining the truck.
Pull it on up on your computer at
www.skidplates.com.
CJ
Posts: 43 | From: Mount Vernon, VA | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Member # 73
Member Rated:
posted 03-07-2002 11:44 AM
quote:
Originally posted by TundraV84Me:
Let get somthing started
Ok, I'm one of the ones who takes off the skid plate to change their oil. Anyone else?
SATundra
2001, SR5, V8, 4x2, Access Cab, Metallic Silver Sky
MODS: Better Built alum toolbox w/lights 2 inside 2 outside, lots of antennas, CB/Ham/Scanner/linear amp all mounted in custom made console, 10 disc CD player, DEI Sidewinder 5000 ESP alarm, undercarriage entry lights, extra set 55W reverse lights, underhood light, TRD add-a-leaf (ordered), Lund bugshield, chrome step tubes, UTR bedliner, hitch, tinted windows, fuzzbuster hard wired, 4 block power terminal under dash, 12V Acc plug engine compartment, synthetic oils, fog light mod, cargo light mod, acc plug mod, map light mod, back seat angle mod soon, 2 TS stickers (back windows), 2 TS license plate frames (front, rear)
Posts: 461 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
TundraV84Me
Moderator
Member # 159
Member Rated:
posted 03-06-2002 11:47 PM
ENJOY MORE and SAVE more, upgrade your membership today! TS Supporter or
Platinum TS Supporter subscription
Posts: 126 | From: So Cal | Registered: Feb 2002 | IP: Logged
