Old 03-28-2002, 02:39 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:24 AM
nhparrot's Photo Albums
Default Radiator Fluid...
Topic: Radiator Fluid...
Rubix
TS Supporter
Member # 1584
Member Rated:
posted 03-10-2002 08:55 AM
I've also heard that the Toyota coolant protects against corrosion within the aluminum radiator. Not all coolants protect against the corrosion, so try to find one that does and does not have "sand" in it.
Cheers.
2000 Access Cab SR5
Posts: 13 | From: San Luis Obispo, CA | Registered: Feb 2002 | IP: Logged
Ed JadeSR5 Tundra
Super Moderator
Platinum TS Supporter
Member # 3
posted 03-08-2002 07:20 AM
The red Toyota coolant is silicate-free (sand).If you plan on doing a flush,make sure it's silicate-free if you don't use the factory coolant.
Become a TS Supporter by clicking this link
Then check out my corny Tundra website @http://home.att.net/~jadesr5/index.htm
Posts: 67 | From: New Jersey | Registered: Feb 2002 | IP: Logged
TundraV84Me
Moderator
Member # 159
Member Rated:
posted 03-06-2002 11:57 PM
Any thoughts?
ENJOY MORE and SAVE more, upgrade your membership today! TS Supporter or
Platinum TS Supporter subscription
