Old 03-28-2002, 02:40 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 11:27 AM
nhparrot's Photo Albums
Default 30,000 Mile Service?
Topic: 30,000 Mile Service?
Cappi
TS Supporter
Member # 2594
Rate Member posted 03-07-2002 09:28 AM
In addition to the list nhparrot provided, my dealer also repacks the front wheel bearings. Cost is around $475. I haven't had this service performed b/c I'm only at 19K miles. Probably will do some of it on my own.
2001 Tundra, SR5/TRD 4x4, V8, w/ rhino bed liner
Posts: 7 | From: PA | Registered: Mar 2002 | IP: Logged
TundraDome
TS Supporter
Member # 1281
Member Rated:
posted 02-26-2002 10:12 PM
Well, I sure have learned a couple of things . . . 1st, Santa Fe, as usual, is way overpriced all the way around, including basic maintenance at the dealership.
2nd, I thought that probably 55-60% of the TS memebers might perform their own Tundra maintenance. After looking at the Poll on "Do It yourself Tundra Maintenance" (currently on thread-index page 4 as of the date of this post); I see that out of 37 votes to date, 81% do their own maintenance! A heck of alot higher than I anticipated. I guess its time for me to get with the program if I'm going to save some $$ or at least reallocate $$ to more Tundra mods.
-- TundraDome
2000 V8 Tundra SR5 4WD Access Cab, Thunder Gray. All stock except: hitch/7pin round harness, interior MAP light mod. Next Mod: Hella Horns
Posts: 16 | From: Santa Fe, New Mexico | Registered: Feb 2002 | IP: Logged
Mohamed
TS Member
Member # 589
Rate Member posted 02-26-2002 04:02 PM
I also do everything on my vehicles, except the "cooling system". No matter how hard I am educated on it, I still get scared to do it, in fear of getting air trapped somewhere in the lines and then overheat!
Pretty much the dealer only does the timing sets (since I don't have the gizmo) and the really hard stuff, like brakes!
Are you okay...you've been hit, you've been struck by a...SMOOTH CRIMINAL
Other pics of My Tundra
Posts: 95 | From: Carmichael, CA | Registered: Feb 2002 | IP: Logged
Imdone
TS Supporter
Member # 2203
Member Rated:
posted 02-26-2002 01:40 PM
This is a bit late but here in az at Bell Road Toyota the service is $279.00 for 30K
I have no clue how this came to be...
Posts: 70 | From: The Desert | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Platinum TS Supporter
Member # 12
posted 02-26-2002 03:31 AM
dboy4ever,
The 4wd has 7 grease fittings on the propeller shafts, 2 on the front and 5 on the rear. I do not think there are lube points on a 2wd.
~Glenn~
Moderator
Please consider a TS Supporter or Platinum TS Supporter subscription
Posts: 493 | From: New Hampshire | Registered: Feb 2002 | IP: Logged
dboy4ever
Moderator
TS Supporter
Member # 37
Member Rated:
posted 02-26-2002 02:11 AM
Are these items specific to the 4WD model? 'Cuz I looked up both the maintenance guide and the shop manual, and neither stated "lubricate propeller shaft" for 2WD. Does that mean the 2WD drive shaft never needs lubrication?? Hope someone with knowledge could clarify this. Thanks.
quote:
Originally posted by nhparrot:
Lubricate propeller shaft
Re-torque propeller shaft bolt and drive shaft bolt
Inspect CV Boots
Chris
V6 Forum Moderator
2001 Tundra Jade Acc. Cab SR5 V6 5spd 2WD
TRD Bilstein shocks, PowerTrax locker, Husky floor liners
Posts: 118 | From: Oakland, CA | Registered: Feb 2002 | IP: Logged
networkguy
TS Supporter
Member # 34
Member Rated:
posted 02-25-2002 10:58 PM
Replace automatic transmission fluid
Replace brake fluid
Replace front differential oil, rear differential oil and transfer case oil
Pretty much this stuff I can handle the rest on what I already know..
-Mark
Posts: 32 | From: Alpharetta, GA | Registered: Feb 2002 | IP: Logged
hovisimo
TS Supporter
Member # 378
Member Rated:
posted 02-25-2002 02:57 PM
d@mn, i'm at 45k, i should get around to doing this stuff. glenn, any advice or how-tos on torquing and lubing the prop and driveshaft bolts is appreciated, i'm sure i can do this myself. also, how can i change the front diff oil and the transfer case oil? i haven't ever looked at either of these, i replaced the rear diff oil with synthetic, i have a 90 gallon drum of mobil 1 gear oil so i might was well go to town on the front and the t-case. do these take the same oil as the rear diff? much thanks in advance!
-Ryan
my page
Posts: 248 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Member # 12
posted 02-25-2002 07:51 AM
Mark,
What specifically do you want to know?
~Glenn~
Moderator
networkguy
TS Supporter
Member # 34
Member Rated:
posted 02-24-2002 10:15 PM
networkguy
TS Supporter
Member # 34
Member Rated:
posted 02-18-2002 09:17 PM
Any good sources on where I can look to do these tasks? the rest i think i can handle on my own. I have a pretty tool stocked garage at a buddy's house too.
Thanks for the insight, I hit 30k yesterday...
Replace brake fluid
molecule
Member # 129
Member Rated:
posted 02-18-2002 06:33 PM
Glenn
The next time give me some notice I'll send you the monthly add from one of the local dealers with their price's , might get you a better discount.
One of the benifits of living here in Toyota country is I can take my car in the AM without an appointment and get it back by 5 pm .
Tried to get the oil changed in Ohio and New Jersey at the dealer while I was passing thru
they both thought I was nuts their appointments were out 3-4 days . Had to settle for Jiffy Lube and watched them like a hawk.
Bill
Sunfire red SR5 ,V8,Snug-top EXPO shell, black side bars,bug deflector,most badges removed.
" If I knew I was going to live this long I would have taken better care of myself "
Posts: 61 | From: Torrance, CA | Registered: Feb 2002 | IP: Logged
TundraDome
TS Supporter
Member # 1281
Member Rated:
posted 02-18-2002 06:30 PM
I hear you Spanky, and I think you're echoing the thoughts of nhParrot -- It seems like I'm so busy at times; long hours at work, that I can't find the time or the energy. On the other hand, if its fairly simple to do, I should probably look into doing it myself. I bet over 50% of the TS members perform basic Tundra maintenance themeselves.
-- TundraDome
SpaNky
TS Supporter
Member # 948
Rate Member posted 02-18-2002 06:18 PM
Changing plugs, tranny fluid & filter is a piece of cake on Tundra. Just put in the Bosch Platinum 4+ runs great with these plugs.
Save some money, go alacarte if you can.
Posts: 3 | From: Cornfiled o' the Midwest | Registered: Feb 2002 | IP: Logged
TundraDome
TS Supporter
Member # 1281
Member Rated:
posted 02-18-2002 05:38 PM
I had the 30K service done today, so your advice was just in time. Got the service for $340 with a little haggling . . .Still was high but it sure beats $425. They couldn't believe the SoCal speical, but I wouldn't relent. Finally, I gave them the old, "I come here all the time, I hope that loyalty is worth something," and it was.
Another BTW, had the brake drums machined. This is my 3rd time dealing with the brakes (Truck pulses when braking and moving down hill), first time machined; second time replaced drums; and now machined again . . . Something tells me the problem is not solved yet.
Again, thanks for your input -- It sure helped.
-- TundraDome
