Old 03-28-2002, 03:40 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 08:35 PM
nhparrot's Photo Albums
Default rear wheel HP?
Topic: rear wheel HP?
trundra23
TS Supporter
Member # 1999
posted 03-22-2002 02:53 PM
In Off-Road magazine Oct. 01: hp & Trq ratings where tested by a Dynopack Chassis Dyno meter. It bolts to the rear wheel studs. which gives true readings to the rear axle. Results: 285.8 lb-ft of torque (81 mph) at 3,593 rpm and 220.7 (93 mph) at 4,112 rpm.
Posts: 12 | From: Yakima, WA | Registered: Feb 2002 | IP: Logged
Yellbird
TS Supporter
Member # 125
posted 03-21-2002 09:37 PM
It's my understanding with the automatic trans you lose about 17% of your hp by the time it gets to the wheels.
That should put it around 202hp or so at the wheels when stock.
Posts: 12 | From: Chicago, IL | Registered: Feb 2002 | IP: Logged
trundra23
TS Supporter
Member # 1999
posted 03-20-2002 09:48 PM
Are the Dyno results from the JBa headers to the rear wheels or the Flywheel?I thought the 4.7 had 245 to the fly wheel and about 218-225 to the rear wheels. Does any buddy know any different?
