This is a discussion thread titled "Throttle Body Cleaner", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-28-2002, 03:47 PM
nhparrot's Avatar
Assistant Administrator
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
Last Online: Today 04:58 AM
nhparrot's Photo Albums
Default Throttle Body Cleaner
Topic: Throttle Body Cleaner
RagerXS
Supporting Vendor
Member # 470
Member Rated:
posted 03-19-2002 12:19 PM
The AMSOIL Power Foam is designed specifically for this purpose. It works so well that a Ford dealership I know of uses it instead of their own Motorcraft equivalent...
~ Fred
www.NewEnglandSynthetics.com
"Certified AMSOIL Dealer"
Tundra Solutions Sponsor
Posts: 73 | From: Wakefield, MA | Registered: Feb 2002 | IP: Logged
DJ
TS Supporter
Member # 1071
Member Rated:
posted 03-18-2002 07:36 PM
quote:
Originally posted by hovisimo:
when i cleaned mine, it didn't appear to have any coating, it just looked like bare aluminum. an old toothbrush would work well for cleaning the inside, i'm going to try it next time i clean mine.
Been there, done that. A toothbrush loosens the crud nicely but it won't remove it from the throat. That's what the paper towels do. With a good cleaner, such as Gumout carb cleaner, you won't need the brush but you'll still need the paper towels.
Posts: 36 | From: Angel Fire, NM | Registered: Feb 2002 | IP: Logged
hovisimo
TS Supporter
Member # 378
Member Rated:
posted 03-18-2002 08:19 AM
quote:
Originally posted by Ricey:
Just an FYI on cleaning throttle bodies. I noticed in a report from a manufacturer that they are now coating the inside walls of throttle bodies and don't recommend cleaning them with carb cleaner because this will eat away the coating. I DON'T KNOW if the Tundra has this coating but it might be something to look into.
Ricey
-Ryan
my page
Posts: 248 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
bradbury
Platinum TS Supporter
Member # 226
Member Rated:
posted 03-05-2002 08:00 PM
Good to know....this may take a little looking into.
I was able to wipe some away at first inspection with a finger-so I may just use a rag and some water.
Thanks.
Posts: 53 | From: Graham, WA | Registered: Feb 2002 | IP: Logged
Ricey
TS Supporter
Member # 203
Member Rated:
posted 03-05-2002 04:45 AM
Ricey
Posts: 37 | From: N. Attleboro, MA | Registered: Feb 2002 | IP: Logged
JRSTUNDRA
TS Supporter
Member # 83
Member Rated:
posted 03-04-2002 07:02 AM
quote:
Originally posted by bradbury:
That's exactly the post I remembered, just I couldn't remember the details.
Thank you.
You`re welcome.
Jose
Posts: 39 | From: San Francisco, CA | Registered: Feb 2002 | IP: Logged
bradbury
Member # 226
Member Rated:
posted 03-04-2002 06:31 AM
Thank you.
JRSTUNDRA
TS Supporter
Member # 83
Member Rated:
posted 03-03-2002 07:41 PM
I remember this having been a topic before the crash...who here has cleaned their throttle body, at what mileage and with which brand of cleaner?
I saved this before the crash. It`s by TS member DJ.
CLEAN YOUR THROTTLE BODY
I suggest you clean your body.It`s easy, and the "gook" builup can give you a rough and slow idle.
It`s easy. Get a spray bottle of any good carb cleaner. Remove the pretty cover over the throttle body, then loosen the clamp holding the air intake on it , pull the air intake toward you (hard) to pop it loose, and finally pull it upwards and out of the way. A hose is clamped
to the top of this air intake, so just remove the bolt and move it out the way, too.
Use a long-shaft screwdriver to hold the throttle butterfly open, but DON`T scrape it on the edges. Wad up a paper towel and hold it with a surgical clamp (you really don`t want to let go of it in the intake manifold). Use the tube
with the carb cleaner spray and direct the spray carefully. Spray it a few seconds directly onto the inner surface where the throttle butterfly works, then swab it out with the paper towel. Replace the paper towel and do it again. Keep it up until all the surfaces are clean and dry-- it should take only a few minutes.
Then put it back together and start it up . If you did it right, it`ll be smooth at start. If you overspray and underwiped, it`ll be rough for a short time as the overspray is pulled through the cylinders.
I did mine just yesterday, with 27,xxx miles on it. The idle is smooth, like new, and the idle speed picked up about 200 RPM.
Jose
bradbury
Member # 226
Member Rated:
posted 03-03-2002 03:32 PM
Bookmarks
