Old 10-24-2003, 04:52 AM
SigShooter's Avatar
Dealer : Toyota of Grand Rapids
2005 Toyota Camry
Last Online: 11-22-2007 06:25 PM
SigShooter is on a distinguished road.
SigShooter's Photo Albums
Post First oil change and messy.
Did the first oil change yesterday, have just under 1000 miles on the truck. Any tips on how to change the filter without having oil drain all over the skidplate? I really don't want to take the skidplate off every time. Also how many grease fitting on the driveshaft? I didn't grease anything yet but I found four fittings.
Thanks....Dennis
2005 Camry SE V6. 3.3 V6,Moonroof, JBL 6 Disc changer, perforated leather seats, 17 inch rims, rear spoiler, power seat, windows locks mirrors, keyless entry.
Old 10-24-2003, 06:50 AM
Dealer : Acton Toyota of Littleton
2006 Toyota Avalon,
2003 Toyota Highlander,
2007 Toyota Corolla
Last Online: 09-08-2008 07:16 AM
MMitsock is on a distinguished road.
MMitsock's Photo Albums
I have found the best thing is to take off the skid plate. It only has 5 bolts holding it on and you get to see the bottom of the engine to make sure nothing is leaking.
The drive shaft has 8 grease points, 2 on the front shaft, one at each end of the main shaft as well as one at the rear spline and 3 in the center Cardin joint.
Old 10-24-2003, 08:42 AM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel,
2009 Toyota Matrix Pontiac Vibe
Last Online: 10-20-2009 03:43 PM
file014 may have some regrets.
file014's Photo Albums
once you break the oil filter lose and its not yet dripping, put plastic bag under it to catch the drippings. or maybe a cut off milk gallon or 2 liter bottle.
Old 10-24-2003, 08:51 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Yesterday 10:50 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
Thanks....Dennis
I change my filter without removing the skidplate by using a plastic half gallon ice cream container. I loosen the filter enough to where the oil will drain with the container positioned between the gasketed area and the end of the filter. When it's finished I remove the filter and place it in the container. The plastic container is pliable enough that it can be flexed to fit through the underhood opening above the filter location. I'm certain there are other plastic containers of comparable size that would work.
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 10-24-2003, 09:17 AM
sdmahr's Avatar
Dealer : Frank Smith Toyota
Last Online: 12-13-2007 04:23 PM
sdmahr is on a distinguished road.
sdmahr's Photo Albums
GIVE IN TO THE PLATE
Say this over and over again while you stare aimlessly into the sky !
I tried EVERYTHING to keep from making a mess. The only sure-fire method for me is to remove the darn thing. No more mess, easy access, good time to do inspection, and only takes minutes once you do it a few times.
Hey, go ahead and try the "other methods"....maybe one will work for you.
Good Luck !
Old 10-24-2003, 09:26 AM
aguevarra's Avatar
Dealer : Carson Toyota Scion
2001 Toyota Tundra,
2002 Toyota 4Runner
Last Online: 11-08-2009 05:17 PM
Images: 2
aguevarra is on a distinguished road.
aguevarra's Photo Albums
LMAO . I agree totally. I've been taking off the skidplate from my first oil change and no mess. Real easy too. You may spend 10 minutes taking it off the first time but after that, 3-4 minutes tops.
2001 Limited Tundra 2WD Ivan Stewart
Mods: TRD dual exhaust, TRD headers, Donahoe Racing coilovers, Bilstein 5100 rear shocks, Total Chaos Uniball upper A-arms, Hellwig swaybar, BFG A/T 285's, Line-X, TRD air filter, Jet Accu Speed calibrator, PPD billet TB and fuse cover, Sylvania Silverstar head/fog lights, clear corners,
Old 10-24-2003, 10:26 AM
Brian M's Avatar
Dealer : Sand Dollar Toyota Scion
2003 Toyota Sequoia
Last Online: 06-09-2009 11:24 PM
Brian M is on a distinguished road.
Send a message via AIM to Brian M Send a message via Yahoo to Brian M Brian M's Photo Albums
FYI....
When they change them at the dealership they take off the plate.
2003 Sequoia SR5 - Phantom Gray
2006 F150 SuperCrew Lariat - Black/Gold
Old 10-24-2003, 10:45 AM
biggary's Avatar
Dealer : Earnhardt Toyota
2001 Toyota Tundra,
2004 Toyota Camry-Solara
Last Online: 10-25-2009 12:04 PM
biggary is on a distinguished road.
biggary's Photo Albums
Thanks....Dennis
I located a vacant space in the wheel well area adjacent to the oil filter and, using a 4.5 inch hole saw, made an access hole large enough for me to get my hand in and loosen/tighten/catch drips, etc. (I recommend using an old hole saw that you don't mind destroying because they generally aren't made for cutting metal and they're expensive. And, of course, after you cut the hole, you'll need to file the opening and remove any remaining sharp edges.) This allows me easy access to the oil filter and I'm able to clean up drips before they run down the skid plate onto the garage floor.
Factory: Leather, Tow Pkg., Tundra Floor Mats, RS 3000 Security, Six Disc In-dash CD Changer, TRD Off Road Package, Toyota bed extender, auto-dimming mirror, and running boards
Add-ons: INYATI bed liner, Lund hood deflector, Stainless Billet grille, Full tint, Tundra Door sill protectors, Putco s/s bed caps, Delta polished aluminum tool box, Whelen four-way strobe, Bridgestone Dueler A/T Revos 275/70/16's, Throttle Body and Relay/Fuse Billet Covers
Performance: True Flow intake and air filter, 20% Underdrive pulley, Jet Hot SS Autochrome Headers, Power Stop Cross-drilled Rotors & Maxxis Pads, Flowmaster cat-back dual exhaust.
Audio: Alpine V12 amp, Kicker two-way front speakers, Rockford-Fosgate two-way rear speakers, Boston Rally Neo 3r tweets, Phoenix Gold 500.1 sub amp, Twin Rockford-Fosgate 8's in a Q Logic sub enclosure, sound deadening, XM SKYFi2 Satellite Radio
Suspension: Revtek 2.5" suspension lift ,1.5" rear leveling block, Hellwig anti-sway bar w/ ADDCO end links, TRD Red/Blue shocks, TRD Add-a-leafs
Mods: Rear seat angle, Dome/ Dash/Fog/DRL and Cargo Light Mods,Under carriage lights, Ignition Key and Open Door Chime Mods, Silverstar head and fog lamps, Power tailgate lock
Old 10-24-2003, 12:11 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:02 PM
Images: 22
from the throwing-money-at-the-problem department, the skid row skid plate has a drain hole and allows side access to the filter.
that thing with the soda bottle is essential!
GFX by FreedomEagle50
Manual Hubs
Old 10-25-2003, 07:06 AM
SigShooter's Avatar
2005 Toyota Camry
Are you saying that there is another skid plate available that is called the skidrow skidplate? If so where might I purchase one?
Thanks...Dennis
Old 10-25-2003, 08:54 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
4wd?...eight fittings. You'll need a needle adapter for the grease gun coupler to do the front driveshaft fittings, unless the design has been changed on the '03.
Just remove the skid plate...it's not a big deal.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 10-25-2003, 09:23 PM
wes 03's Avatar
Dealer : Durant Toyota
2003 Toyota Tundra
Last Online: 03-06-2008 10:02 AM
wes 03 is on a distinguished road.
Send a message via AIM to wes 03 Send a message via Yahoo to wes 03 wes 03's Photo Albums
ive been thinking of gettin an oil filter relocation kit, anyone else done this or thought of it?
wes
Old 10-25-2003, 10:39 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 11-14-2009 08:18 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
wes
Try the "search":
http://www.tundrasolutions.com/forum...searchid=28553
This one looks like some good info: Oil filter relocation - thread size?
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 10-27-2003, 12:38 AM
Last Online: 12-09-2006 04:30 AM
Bradley is on a distinguished road.
Bradley's Photo Albums
Default Oil Filter change
I agree, removing the skid plate is not required, the small amount of oil can be wiped off and will stop any rust from forming on it.
Old 10-27-2003, 12:30 PM
Images: 22
yeah, they're about 150 bucks...www.skidplates.com . however, as long as you remember to lube the bolts for the stock plate, you shouldn't have a problem...the dealership changes i've had, they just let the stock plate hang from the front clips or whatever's on there (i don't remember, it's been quite a while since i had the stock plate). using the soda bottle trick means a lot less mess, and you can hole-saw a drain hole in the stock plate as well. much cheaper than 150 bucks.
-sean
Manual Hubs
