Gear Oil Confusion
Most of the mileage on my 02 V8 2WD Extracab with the limited slip differential is towing a 26' 4500 lb travel trailer so my original plas was to change the transmission and differential fluid every 15K. The owner's manual calls for straight 90 weight gear oil, API GL-5, down to 0 farenheit, 80/90 for colder. I was going to use synthetic, but fortunately, saw the posts on this forum about the seal issues on pre-03 Tundras. Now comes the confusion:
1) No one seems to sell a straight 90 weight gear oil. 80/90 seems to be the closest widely available product. I called the local dealer's parts department and was told they only get gear oil in 50 gallon drums. I then asked their service department what weight they use in the LSDs and was told 75/90 with a top end treatment for the limited slip. They didn't even know that the manual calls for straight 90 weight.
2) All of the local auto parts stores carry a 80/90 that requries an additional treatment for the limited slip.
3) Wal-Mart has a Penzzoil 80/90 API GL-5 dino gear oil that is formulated for LSDs, no top treatment required or recomended.
I went with the Penzzoil and plan to change it every other oil change since it is a) a lighter oil, b) cheap, c) easy.
Has anyone else had this problem? Do you know what the dealer is putting in your differential? Does anyone have a better solution? Also, why is the Tundra differential rated for a 15K oil change and the Seqoia rated at only 5K? The dealer said it was because the Seqoia is heavier. Based on that logic I should be changing my differential oil every 2500 with the engine oil (which sounds nuts to me.)
That said, the Tundra has proved to be an excellent tow vehicle. I added AirLift bags with a compressor and a sway bar. Combined with a good weight distributing hitch and a Prodigy brake controller it easily pulls our camper at highway speeds (never in OD, I'll trade mileage for longevity.) Even for those that don't tow, the air bags really smooth out the ride.
Thanks for suffering through a long post. I appreciate any answers.
