This is a discussion thread titled "Is $89.95 for a Transmission flush a good deal?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 10-24-2003, 07:02 PM
Bayou Thunder's Avatar
Last Online: 11-28-2008 11:23 PM
Bayou Thunder is on a distinguished road.
Send a message via AIM to Bayou Thunder Bayou Thunder's Photo Albums
Default Is $89.95 for a Transmission flush a good deal?
Called one of the local Toyota Dealerships and they will do a full Transmission flush for $89.95. I asked if I needed to provide the fluid and they said no, it was included. What have some of you payed for your flushes and does this sound like a good deal?
Clay
Old 10-24-2003, 07:07 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
Last Online: Today 01:05 AM
mustang67408 will become famous soon enough. mustang67408 will become famous soon enough.
Default $$$ trans flush
We charge $129.95 for a trans flush, here at my dealership.
We hook up a machine with the engine running that exchanges the fluid. Normally i run between 10-20 qts thru or until it becomes red again.
Please dont anyone bark at me about the price, I am a indian and the Big CHIEF's make the prices.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
Old 10-25-2003, 09:28 AM
so40's Avatar
Dealer : Gray Daniels Toyota
2001 Toyota Tundra,
2007 Toyota Camry XLE V6,
2007 Toyota Yaris "S" Sedan
Last Online: 05-09-2008 10:14 PM
so40 is on a distinguished road.
Send a message via ICQ to so40 so40's Photo Albums
Default Good Price
Clay
Why don't you do it yourself? The price doesn't sound bad at all. Most places around here get 69-79 dollars for a "regular service" which is just dropping the pan and putting in a new filter (on cars that have them). As you know that doesn't get any of the old fluid except what was in the pan.
Using the machine is better and the labor is probably less than the labor for the regular change or about the same. You can do it yourself in about an hour or so (with a helper) and it will only cost you 14-15 quarts of whatever fluid you decide to use. This way you know it is done correctly. Easy instructions are in the garage section, but I bet you already knew that.
Mike
Experience is the best teacher, IF you can afford the tuition!
White 2001 4X4 LTD/TRD. Fog and map light mods. S&S Autochrome headers and Y-Pipe, ASP UD Pulley,SpinTech single/dual out with rear exit. PPD T-Body and Fuse covers. MT Classic ll's with 265X75X16 Maxxis Mudders, Wheelers front coils, RAS on rear springs & Ride Rite air springs. Powertrax No Slip Locker. Mobil 1 Synthetic throughout!
Old 10-27-2003, 02:58 AM
makana81's Avatar
Last Online: 07-08-2005 06:38 PM
makana81 is on a distinguished road.
makana81's Photo Albums
As mentioned earlier, it's very easy to complete yourself. I swapped out my fluids in approximately 25 minutes. I used my car remote starter to assist with the truck starting and stopping.
Good Luck on your choice!
Old 10-27-2003, 05:06 PM
Dealer : Charles Maund Toyota
2002 Toyota Tundra,
- Other - 2005 infiniti g35 cp
Last Online: Yesterday 01:19 PM
mikeinaustin is on a distinguished road.
mikeinaustin's Photo Albums
just verify that they aren't simply removing the transmission drain plug (which will only get you around 4qts replaced out of the 16qts [approx #'s]).
Old 10-27-2003, 06:58 PM
stcj's Avatar
Dealer : Ira Toyota of Danvers
2003 Toyota Tundra
Last Online: 09-19-2008 06:30 AM
stcj is on a distinguished road.
stcj's Photo Albums
I would pay $89.95 for a flush, If that is what they really do.
Old 10-27-2003, 07:14 PM
Dealer : Stevens Creek Toyota
Last Online: 11-25-2008 12:55 AM
akauth is on a distinguished road.
akauth's Photo Albums
Clay
$90 seems like a great price for a dealer flush. Usually it's quite a bit over $100 for sure.
You can go to one of the jiffy lube type places and pay that much without the knowldedge that a dealer has. So it seems like a pretty fair price to have dealer personnel do it.
Alan
Old 10-27-2003, 08:13 PM
I asked the person at the dealership twice if they removed all of the transmission fluid and flushed everything, not just remove the drain plug and change 3 or 4 quarts. He said they do a complete flush. My regular dealership doesn't even offer a full flush service so I called the other place and they do do it. It sounds like a good price to me and is worth me not having to take the time and get the know how to flush it myself. If I just wanted to change the fluid I would do it myself, but an entire flush I will leave up to the dealership.
Clay
Old 10-29-2003, 08:40 PM
Dealer : Galaxy Toyota
2003 Toyota 4Runner
Last Online: 05-18-2008 09:08 AM
freezy74 is on a distinguished road.
freezy74's Photo Albums
i am a writer at a dealer and we charge $139.95+tax for that same service
Bookmarks
