Old 03-28-2002, 03:54 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 11:27 AM
nhparrot's Photo Albums
Default rattling noise
Topic: rattling noise
aika
TS Supporter
Member # 87
Member Rated:
posted 03-08-2002 10:56 AM
well it kind of sounds like its coming from below my truck or something like that. im going to have my brother sit in the truck while i get under the thing and into the hood and all that good stuff. im hoping i can figure out what it is...
Posts: 154 | From: San Diego, CA | Registered: Feb 2002 | IP: Logged
bradbury
Platinum TS Supporter
Member # 226
Member Rated:
posted 03-04-2002 07:08 PM
Check that the cover that says "4.7l V8" over the throttle body is tight....I had a noise under similar conditions and found one of the nuts was loose. Tightened it, and the rattle went away.
Posts: 53 | From: Graham, WA | Registered: Feb 2002 | IP: Logged
aika
TS Supporter
Member # 87
Member Rated:
posted 03-04-2002 05:12 PM
i have a sort of rattling noise after i rev my engnie while its coming down from higher rpms. do you think this may be the cover for the cat or something like that? ill have to get under it to figure it out. also, im getting a little squeal i think every time my rear driver's side wheel turns over. im hoping its just dirt or something on the drums or something thats going to go away- any thoughts? if i have to replace my rear brake pads im going to sh@* myself...
