This is a discussion thread titled "Topic: Oil Filter Study", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-28-2002, 04:02 PM
nhparrot's Avatar
Assistant Administrator
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
Last Online: Today 04:59 AM
nhparrot's Photo Albums
Default Topic: Oil Filter Study
Tundra 5150
TS Supporter
Member # 98
Member Rated:
posted 03-03-2002 08:29 PM
Weight was a factor taken into consideration. While I have yet to weigh these two filters on a scale, the -20004 is heavier.
Glenn, I sent you an E-mail.
Posts: 17 | From: Sacramento, CA | Registered: Feb 2002 | IP: Logged
georgeseq
TS Supporter
Member # 1424
Member Rated:
posted 03-01-2002 04:42 PM
Regarding filter measurements. One very simple suggestion is simply weighing the filters, complete. Then weighing the filter media once the filters have been opened up. I have found through the years some amazing differences in filter construction, quality, just by comparing weight..
George
Posts: 13 | From: Columbus, ohio | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Platinum TS Supporter
Member # 12
posted 03-01-2002 03:15 AM
Michael,
What things are you planning onlooking at regarding filters? I was thinking along these lines for a project when I finshed my air filter study.
~Glenn~
Moderator
Please consider a TS Supporter or Platinum TS Supporter subscription
Posts: 493 | From: New Hampshire | Registered: Feb 2002 | IP: Logged
Tundra 5150
TS Supporter
Member # 98
Member Rated:
posted 02-28-2002 09:57 PM
I posted this earlier in the Tundra Solutions forum in reply to "Toyota Oil Filter Part Number". I thought that I'd give this post it's own thread here in the I-force V8 section as I plan to expand this oil filter study. Anyways here's what I came up with so far:
There are two Toyota brand filters available for the 4.7 liter engine.
My engine still has the filter from the factory and it is a 90915-20004.
Also available for it is the 90915-YZZB5.
I bought both of these filters because I plan to do a unofficial oil filter construction study for the Tundra application. So far I can only offer external observations on these two filters. They are as follows:
The -20004 is about a 1/4 inch taller than the -YZZB5 and appears to have a metal end cap (looking thru the bottom hole.) The gasket and backflow valve are made of a orange rubber material. The filter media is high quality with it's pleats reinforced by plastic. Made in Japan. It cost $9.65 from a local dealer.
The -YZZB5 is shorter and appears to have a plastic grid reinforced paper end cap. It seems to have the same high quality media as the -20004. The gasket and backflow valve are made of a black rubber material. Made in Japan. This filter costs $4.91 from the local dealer.
Both of these filters backflow valves held pressure well when forced back onto their seats. However, when pressure was applied in the proper direction of flow, the -20004 valve opened with noticably less effort. Meaning that oil should flow easier in this filter. Nothing is really conclusive of this particular flow test as the filter was tested with compressed air and vacuum pump while screwed on a pipe nipple.
I plan to have our machine shop cut these filters open as soon as I acquire other brands for the Tundra application
Bookmarks
