pinging noise
Topic: pinging noise
Ricey
TS Supporter
Member # 203
Member Rated:
posted 03-02-2002 12:57 PM
David V,
I started a thread in the "I Force V8" forum called "Diesel Knock Tracking", keep us posted there with your developments if it is indeed the dreaded "knocking" noise. There's a small percentage of us with it. Best of luck.
Ricey
Posts: 37 | From: N. Attleboro, MA | Registered: Feb 2002 | IP: Logged
david V
TS Member
Member # 2519
Rate Member posted 03-01-2002 09:45 PM
cool thanks. i dont belive it normal, it seems to get louder and lounder the older it gets. thanks
Posts: 2 | From: Simi Valley, CA | Registered: Mar 2002 | IP: Logged
TundraGuy
TS Supporter
Member # 11
posted 03-01-2002 08:35 PM
Well, if it's not an exhaust/header leak, and if it's not severe pinging(unlikely) it could be 'piston slap' or 'wrist pin' noise.
Do a search in this forum and the iForce forum on 'piston slap' for more information.
Some people say piston slap is not a big deal, but I can't imagine that the piston banging around the cylinder can be good.
Sean
'02 Tundra Ltd 4x4, Black/Oak, Huper Optik Stark 30 tint, more mods to come...
Posts: 91 | From: Austin, TX | Registered: Feb 2002 | IP: Logged
david V
TS Member
Member # 2519
Rate Member posted 03-01-2002 07:29 PM
Ok, i have a question for you, My dad has a tundra 2wd v-8 acces cab, When it cold and only cold, it makes a loud pinging sound, when accelrating. He taken it to a couple dealers and they have replaced the drivshaft, the exaust system headers. they cant figure it out and we really dont trust the dealer. has any one else had this issue or a problem similar? also the brakes. it has 25k and it one it forth set? sorry fpor all the questions,
thanks david V
