Is the 4.7 to be replaced or is a new engine to accompany it?
Topic: Is the 4.7 to be replaced or is a new engine to accompany it?
bradbury
Platinum TS Supporter
Member # 226
Member Rated:
posted 03-01-2002 08:20 PM
The downdrafts might have a slight problem with emissions......
So the Ironman engine for street use might have to be slightly detuned.
Ever so slightly.
Posts: 53 | From: Graham, WA | Registered: Feb 2002 | IP: Logged
cropdoc
TS Supporter
Member # 2410
Rate Member posted 02-28-2002 08:32 PM
Ivans truck was a 4.9 L with 8 downdrafts and 500 hp.
Merv
This habit is worse than drugs..............
Posts: 16 | From: Ontario, Canada | Registered: Feb 2002 | IP: Logged
v8power
TS Member
Member # 1550
Rate Member posted 02-19-2002 01:56 PM
Good question, man. I do know that the Toyo boys are racing 5.0's at the moment. I know because i read their TRD advertisments that claim this. So, I expect a 5.0. Remember when Ivan was racing a v8 engine before the Tundra and 4.7 v8 was even produced? I think Ivan was racing the 4.7. Weve gone from a Lexus/Toyo - 4.0, to a 4.3, to a 4.7 and to a ?. Also, we should not forget the S/C, because that's an easy 300+hp, right? Toyo has many routes for world domination. I hope we see more engine choices - but i like the limited option packages and u get what they got though others don't
Posts: 18 | From: Los Angeles, Ca | Registered: Feb 2002 | IP: Logged
Ric17
TS Member
Member # 730
Rate Member posted 02-19-2002 12:56 PM
With all the talk of the new Tundra engine plant in Alabama and a new larger V8 possibly on the way, will the 4.7 continue or will the new engine replace it entirely?
Posts: 6 | From: Eastern Passage, NS | Registered: Feb 2002 | IP: Logged
