Break-in Mileage
Topic: Break-in Mileage
nedjames
TS Supporter
Member # 380
posted 03-01-2002 01:14 PM
I also did an early oil change. I replaced the oil and filter and put in a super magnet drainplug at 1000 miles.
Donnelly auto dimming compas/temp mirror, pano mirrors, battery disconnect, Bosch platinum +4 spark plugs, super magnet drain plug, map lights mod, Zaino, bed hammock, senza warning labels
Posts: 33 | From: Louisiana | Registered: Feb 2002 | IP: Logged
gatundra
TS Supporter
Member # 610
Rate Member posted 03-01-2002 11:21 AM
I hate to go against the owner's manual but my thought was that the newer engines had better tolerances and did not need the long break-in periods or the lower rpm's like the older models. I'm still undecided as to whether or not it will harm the engine long term. Any mechanics out there with valuable information?
Posts: 4 | From: Atlanta, GA | Registered: Feb 2002 | IP: Logged
KLS
TS Supporter
Member # 100
posted 03-01-2002 11:09 AM
Don't bother with the manual. Too many big words. All those pages....
Posts: 109 | From: Western Washington St. | Registered: Feb 2002 | IP: Logged
kikyou
TS Member
Member # 2463
Rate Member posted 03-01-2002 10:50 AM
i'm new... not an expert but would it hurt the tundra to hit a high speed like 80? for a long time will the engine be damaged? i dont really understand i havent had the time to read the manual...
Posts: 41 | From: 12345 blank st. | Registered: Feb 2002 | IP: Logged
basmith
TS Supporter
Member # 75
Member Rated:
posted 03-01-2002 08:42 AM
I bought my truck in Los Angeles and live in Tucson. I drove no higher than 60 mph the whole way home. Usually the trip takes 6 hours but it took me 10 hours to get home. It sucked but at least I know I did no harm to the truck. It sucks going 60 when the speed limit is 75 but I love my truck and I don't want to hurt it.
Tundras are sweeeeeet!
Posts: 70 | From: Arizona | Registered: Feb 2002 | IP: Logged
nwaring
TS Supporter
Member # 185
Member Rated:
posted 03-01-2002 08:03 AM
I worried about this also. I bought the truck in Winston-Salem NC and had 500 miles to get it home. It did get a lot of RPM variance on the West Virginia turnpike though. I'll do my oil soon too.
White 2002 (1/25/02) 4X2 SR5 Access Cab, V8, TRD, Conven Pkg, LSD, ABS, Liner, 3in1 Stereo, CC Seats, Tow Pkg, Prot Pkg........A.R.E. LSII Lid
Posts: 18 | From: NE Ohio | Registered: Feb 2002 | IP: Logged
gatundra
TS Supporter
Member # 610
Rate Member posted 03-01-2002 07:05 AM
Thanks Gary. I think I will take your advice and change the oil on my return. I should have about 850-1000 miles on it by then. I just hope the 80 mph will not harm anything long term.
Gary Foreman
TS Supporter
Member # 304
Rate Member posted 03-01-2002 06:58 AM
I had the same delima. Only had 200 miles on it and had to make a trip, 400 miles, highway speeds sometimes 80 (and that was just going with the flow). I wouldn't worry about it. I did drop the oil at 1000 though.
Gary Foreman
2001 SR5, Desert Sand
Line-X, Leer 700
Posts: 24 | From: Northern VA | Registered: Feb 2002 | IP: Logged
gatundra
TS Supporter
Member # 610
Rate Member posted 03-01-2002 06:42 AM
Thanks for the reply userw5. I don't know if I can keep it to 60-65 though! Once I get on the highway, I usually maintain about 70-75 because I am anxious to get to my destination. The speed limit is 70 for most of the trip and I hate to go below the limit.
userw5
Platinum TS Supporter
Member # 48
Member Rated:
posted 03-01-2002 06:31 AM
quote:
Originally posted by gatundra:
I am trying to break in my Tundra per the owner's manual by keeping speed and rpm's low for the first 1000 miles. Unfortunately, I have to take a trip this weekend on the interstate and would like to know what everyone thinks about high speeds with only 350 miles logged so far. Will I harm the engine???
It shouldn't harm it at all. Just remember to vary your speed and rpm. I would keep it around 60-65mph. I do not think it will hurt it if you have to go a little faster to pass someone. You just do not want to maintain high speeds for an extended period. If there is anyway to vary your route you may want to take some back roads, or maybe a scenic route.
Posts: 70 | From: Richmond, VA | Registered: Feb 2002 | IP: Logged
gatundra
TS Supporter
Member # 610
Rate Member posted 03-01-2002 06:09 AM
