Old 03-28-2002, 04:20 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 07:17 AM
nhparrot's Photo Albums
Default Toyota Oil Filter Part Number
Topic: Toyota Oil Filter Part Number
Tundra 5150
TS Supporter
Member # 98
Member Rated:
posted 02-28-2002 07:51 PM
There are two Toyota brand filters available for the 4.7 liter engine.
My engine still has the filter from the factory and it is a 90915-20004.
Also available for it is the 90915-YZZB5.
I bought both of these filters because I plan to do a unofficial oil filter construction study for the Tundra application. So far I can only offer external observations on these two filters. They are as follows:
The -20004 is about a 1/4 inch taller than the -YZZB5 and appears to have a metal end cap (looking thru the bottom hole.) The gasket and backflow valve are made of a orange rubber material. The filter media is high quality with it's pleats reinforced by plastic. Made in Japan. It cost $9.65 from a local dealer.
The -YZZB5 is shorter and appears to have a plastic grid reinforced paper end cap. It seems to have the same high quality media as the -20004. The gasket and backflow valve are made of a black rubber material. Made in Japan. This filter costs $4.91 from the local dealer.
Both of these filters backflow valves held pressure well when forced back onto their seats. However, when pressure was applied in the proper direction of flow, the -20004 valve opened with noticably less effort. Meaning that oil should flow easier in this filter. Nothing is really conclusive of this particular flow test as the filter was tested with compressed air and vacuum pump while screwed on a pipe nipple.
I plan to have our machine shop cut these filters open as soon as I acquire other brands for the Tundra application.
Posts: 17 | From: Sacramento, CA | Registered: Feb 2002 | IP: Logged
Garfield
TS Member
Member # 1108
posted 02-25-2002 08:20 PM
Fourrunner 1996 v-6 and 2001 Tundra are the same filter in the Amsoil style could be different in the Toyota style.
Posts: 8 | From: Canada | Registered: Feb 2002 | IP: Logged
tundra.gator
TS Member
Member # 1180
Rate Member posted 02-25-2002 01:17 PM
Thanks!!
Posts: 3 | From: Atlanta, GA | Registered: Feb 2002 | IP: Logged
aguevarra
TS Supporter
Member # 115
Member Rated:
posted 02-24-2002 06:56 PM
The part number for the 4.7 liter Toyota oil filter is 90915-YZZB5.
**2001 Limited TRD**
TRD duals, TRD air filter, Line-X bedliner, clear corners
Posts: 36 | From: Aliso Viejo, CA | Registered: Feb 2002 | IP: Logged
tundra.gator
TS Member
Member # 1180
Rate Member posted 02-24-2002 06:52 PM
Does anyone know the part number for the Tundra 4.7L Toyota oil filter? I have a box of Toyota filters that I purchased for my Sienna, which I sold, and I seem to recall someone telling me that the filters were the same on the Sienna and Tundra.
TIA!
Gator
