Originally Posted by gnb
You are probably right.
However, I recommend a clear hose because you will be able to see the first signs of air/bubbles. You want to shut your engine off immediately at the first sight of air/bubbles as this is a sign of pump cavitation ( bad).
Having a helper is recommended to signal to shut down the engine.
AT is too expensive to risk cavitating the pump and consequential damage.
Once you do it, you'll find that you're making it out to be much more difficult than it really is. It's not even close to being in the same league as bleeding brakes (two man method).
I did it at night by the overhead light in the garage shining out into my driveway so I don't think I would have seen any bubbles in a clear hose anyway. It was one step better than by flashlight on a pitch black street. The only problem I had was I had to walk the dipstick into the light to read the clean fluid (it's practically invisible) and I wished I'd thought about marking my catch container so that I knew when I was filling it by two quarts at a time. If you mark a stick ahead of time and poke it in the bucket if you're in the dark like I was you can walk the stick to the light to see how much you actually took. Obviously daylight makes thing much easier!
You'll find that you can *easily* connect to the upper cooler connector with a 3 foot transmission hose (or whatever the "out" on the cooler is, if you have one, you don't need to splice it to any hose that way). Put that line into a large 2 1/2 gallon plus container. Leave your driver door open, turn on the key and run the engine for 10 seconds or so (until you get two quarts... do it for 5 seconds the first time to be conservative), put two quarts in through dipstick (or whatever you took out), reach in the driver door again and run the engine for about 10 seconds (Sorry, I didn't time it exactly - once you get the first amount you know to go longer or shorter the next time you turn the key. I just did it by "feel". Count by thousands if you want.)
The only thing that I would have changed with the way that I did it was that I'd make some way that you can tell when you've put 2 quarts into the "catch container". The first "cycle" I had to empty it and measure what I drained so I could adjust to take 2 quarts the rest of the time. Then you know to refill it with slightly more or less than two quarts of fluid each time. Just eyeball it all until you get to the end. *THEN* (at the end) make sure that you haven't overfilled - if you underfill you can always add a little more later.
But in the end all that matters is that you have 4 gallons of waste trans fluid and you put 16 quarts in (one way or another). When you know you've pulled a gallon (two cycles), double check that you've put one gallon in. When you hit two gallons, ditto.
Double check the fluid level before you close everything up (as now you can easily take any extra out by running the engine a second or two) and do a "gross" check again the next morning when it's cold, then check it again in the parking lot when you get to work and you've been running it for 20 minutes at least.
The only thing I'd add is that if you change it on a hill (that's fine, rear is downhill) that you look at the dipstick when it's all cold so you get the "hill measurement" and then when you're done and the engine's cold again the next morning that you make sure that the fluid is roughly at that same place (assuming you're still parked in the same spot on the hill) as it was before you started. Of course always double check the fluid when it's properly warm (I'd even (over) check it two or three times during the week when it's warm/hot. It's often hard to see the clean fluid and you might misread it once. After that check it occasionally, but regularly.)
The other thing I'd add is that since the key is in the ignition and the door is open you'll want to pull the key out a little so that the "key in the ignition and the driver door is open" alarm doesn't keep sounding while you're filling the trans fluid.
Alan
