Old 11-04-2003, 01:03 AM
tundrabrad's Avatar
Dealer : Bill Wright Toyota Scion
2003 Toyota Tundra
Last Online: 10-29-2005 01:45 AM
tundrabrad is on a distinguished road.
Send a message via AIM to tundrabrad tundrabrad's Photo Albums
Question Mobil 1 75W-90 Synthetic in Limited Slip Diff?? Amsoil??
The Mobil 1 website says their 75W-90 Synthetic Gear Oil offers "excellent limited slip performance".
http://www.mobil.com/USA-English/Lub...rLubricant.asp
Toyota specifies "hypoid gear oil for limited slip differential API GL-5 SAE 90 above 0 degrees F or SAE 80W or 80W-90 below 0 degrees F".
Is anyone using Mobil 1 in their LSD??? Recommendations??? Experiences??? Do any 'friction modifiers' need to be added???
Anyone using Amsoil and their Friction modifier??
________________________
Tundrabrad
Menifee CA
2003 Tundra SR5 Access Cab 4X2 - Stratosphere Mica
Factory Options/Accessories:
Limited Slip Differential * RS3200 Security System * Towing Package * 17" Limited 5 Spoke Alloy Wheels * All Weather Floor Mats * First Aid Kit * Cargo Net * Wheel Locks * Aluminum Skid Plate * Auto Dimming Mirror * Fog Lights * Bed Extender
Mods/Additions:
Sylvania SilverStars * RhinoLiner * OBX Fire Extinguisher * Westin Signature Nerf Bars * Bullring Retractable Tiedowns * Snuglid Tonneau Cover * Coleman 400 watt Power Inverter * Magnafine transmission filter * Hellwig Anti-Sway Bar * SuperPlug
Old 11-04-2003, 01:56 AM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 03:55 AM
RichR is on a distinguished road.
RichR's Photo Albums
Default I have Mobil1 in,
Has been in for 20k.I did need to add LSD additive the first time because of clutch noise.The second I added it first.I do the rear every 10k to keep it clean.
No leaks so far.
RichR
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Old 11-04-2003, 01:57 AM
Dealer : Charles Maund Toyota
2002 Toyota Tundra,
- Other - 2005 infiniti g35 cp
Last Online: 11-12-2009 12:11 AM
mikeinaustin is on a distinguished road.
mikeinaustin's Photo Albums
i've used it in my 2002 lsd and there was some chatter. had to add about 3oz of a lsd modifier to fix the problem - others haven't had to do this.
Old 11-04-2003, 07:22 AM
Last Online: 08-18-2006 10:37 PM
gasman30 is on a distinguished road.
gasman30's Photo Albums
I had to add 4 oz of friction modifier to eliminate the chatter.
Old 11-04-2003, 11:34 PM
davidk's Avatar
Last Online: 10-14-2005 09:24 AM
davidk is on a distinguished road.
davidk's Photo Albums
I changed to Mobil 1 75w90, plus friction modifier purchased from Carson Toyota, and have had chattering for the past 15k. Tried adding another tube of friction modifier and still had chattering.
Just changed oil again (now 30k miles) and used Pennzoil GEARPLUS® SAE 80W-90 GL-5 GEAR LUBRICANT I found at K-Mart by accident. I was planning on using Castrol Hypoy C with a tube of the LSD additive, couldn't find the Castrol product, and the wording on the Pennzoil changed my mind.
"It is designed to reduce or eliminate “chatter” that can sometimes occur in limited slip differentials." says the data sheet at http://www.pzlqs.com/Tech/Pdsheet/In...rLubricant.pdf
The data sheet also states: "In addition, PENNZOIL® GEARPLUS® SAE 80W-90 GL-5 is fully formulated for all limited slip differentials."
The bottle actually states that no LSD additive is required, and in fact is not recommended.
It sounds like this stuff is made to work in LSD's straight out of the bottle.
My chatter disappeared immediately . I will use the same product for my next LSD change.
I will still use Mobil 1 75w90 for the transfer case and front open differential.
Hope this helps.
Old 11-07-2003, 05:15 PM
puppychop3's Avatar
Dealer : Bob Smith Toyota
2002 Toyota Tundra
Last Online: 12-14-2005 01:23 PM
puppychop3 is on a distinguished road.
puppychop3's Photo Albums
I am using Mobil 1 exclusively in the engine and trani but for my LSD I use the following:
Gear oil
http://www.crcindustries.com/product...oductno=SL2462
http://www.crcindustries.com/product...oductno=SL2411
Old 11-09-2003, 01:07 AM
tundrabrad's Avatar
2003 Toyota Tundra
Question Amsoil???
These responses don't inspire much confidence in a switch to Synthetic Mobil 1.
Anyone using Amsoil 80W-90 with or without their friction modifier???
Tundrabrad
Menifee CA
Mods/Additions:
Old 11-09-2003, 10:58 AM
HOTundra's Avatar
Dealer : Tejas Toyota
2002 Toyota Tundra
Last Online: 01-23-2009 09:31 AM
HOTundra will become famous soon enough.
HOTundra's Photo Albums
Yesterday I changed the LSD Differential with Trans X and Mobile 1 Synthetic
for the first time. Very easy, although I did find metal shavings on the magnetic
bolt, but I believe this may be from the manufacture (I hope)! No leaks!
Old 11-09-2003, 10:31 PM
kelltl's Avatar
Last Online: 06-10-2009 10:39 PM
kelltl is on a distinguished road.
kelltl's Photo Albums
Switched to Mobil1 in my LSD about 1K miles ago with no issues so far. I did add friction additive at the beginning though.
Old 11-10-2003, 11:48 AM
lelandstanford's Avatar
2005 Toyota Tacoma
Last Online: Yesterday 09:24 PM
lelandstanford is on a distinguished road.
lelandstanford's Photo Albums
I used Redline 75W90. No additive. No problem. LSD does not engage abruptly like OEM fill.
2005 Tacoma AC 2WD 2.7L 5M
