Old 03-28-2002, 04:27 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 02:18 PM
nhparrot's Photo Albums
Default Belt Noise
Topic: Belt Noise
dogzpaws
TS Supporter
Member # 383
Member Rated:
posted 02-27-2002 04:07 PM
I had the same problem - the squeak would go away after a truck warmed up or after a couple of minutes. I ended up leaving the truck at the dealer overnight with clear instructions that they were to listen to it at startup. They changed the tensioner and belt and the problem went away (that was about 20k miles ago). I have noticed recently that the squeal may be coming back. It seems to be off and on.
If you have a dealer that gives you the line that he hasn't heard of that problem before, have them call my dealer, they found my problem and fixed it!
Bob Baker Toyota
Lemon Grove, California
Phone: (619) 287-2400
Fax: (619) 265-3199
dogzpaws
2000 Tundra SR5 Access Cab V8 4x4 Jade
Posts: 29 | From: La Mesa, CA | Registered: Feb 2002 | IP: Logged
hovisimo
TS Supporter
Member # 378
Member Rated:
posted 02-25-2002 02:20 PM
i've had the belt squeal all winter. it only occurs when it's 45 or colder, with the warmer weather coming, how can i get the dealership to fix it if they can't diagnose it because they can't hear anything? the truck has to sit overnight and be started on a cold morning for the noise to occur. i'm at 45k miles and can't afford to wait till next winter (out of warranty) even if the noise doesn't occur when it's warm. how can i get them to fix it?
-Ryan
my page
Posts: 248 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
Groundpounder
TS Supporter
Member # 150
Rate Member posted 02-23-2002 10:31 PM
Same problem.Instead its worse on cold mornings.When the truck has been running for five minutes or so it goes away.Never there when I get to the dealer.Also dealer hasn't heard of this kind of problem before.Someday.
Posts: 4 | From: Aurora, OR | Registered: Feb 2002 | IP: Logged
phattundra
TS Supporter
Member # 799
Rate Member posted 02-22-2002 05:44 PM
My 2000 Tundra had the belt noise mainly in the morning. It started with about 16K on the truck and it sounded like a bird was stuck in the fan. Dealer replaced the serpintine belt. No problem since.
Posts: 2 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
BCW
TS Member
Member # 868
Rate Member posted 02-13-2002 03:41 PM
I had the same problem on my 2000 Tundra about 20K ago. The dealer replaced the belt tensioner but the problem didn't go away. Returned and had the belt replaced. No problem since.
Posts: 8 | From: Los Angeles, California | Registered: Feb 2002 | IP: Logged
dogzpaws
TS Supporter
Member # 383
Member Rated:
posted 02-12-2002 06:36 PM
This has been a fairly common problem with the belts. My tensioner went bad quite a while ago (say 15,000 miles). They changed the tensioner under warantee (make sure you insist on a new belt as well since the bad tensioner could have adversely worn the belt). However, I've noticed recently that it appears the noise is starting to come back. I'm beginning to wonder if this is going to be a chronic problem.
dogzpaws
Big-O
TS Member
Member # 695
posted 02-12-2002 01:53 PM
I've had a squeek comming from the belts. I had taken it into the dealership a few times. Every time I took it in the noise would stop. I put some of that belt dressing on the belts, and the noise got louder! Took it to the shop again. The noise stopped! Finaly, they figured the noise was comming from the belt tensioner. They are going to replace it for me. Thank goodness!
Posts: 14 | From: Salt Lake City | Registered: Feb 2002 | IP: Logged
Old 05-11-2006, 02:04 PM
Dealer : Cobb County Toyota Scion
2008 Toyota Tundra SR5 Crew Max 5.7,
2008 Toyota Sequoia SR5 5.7,
2008 Toyota 4Runner SR5 4.0
Last Online: 11-18-2009 07:38 AM
mca1989 is on a distinguished road.
mca1989's Photo Albums
Default Re: Belt Noise
what are the steps to changing the belt ?
49state model 2003 4.7L engine
Old 05-11-2006, 07:31 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 04:19 PM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
My 06 does it too. Some belt dressing quietens it down for a few days but it comes back. Typically it is heard around 1200-1500 rpm and moreso on a cold engine.
