Topic: Tranny Fluid
RagerXS
Supporting Vendor
Member # 470
Member Rated:
posted 02-19-2002 11:46 AM
Well, I know for a fact that Castrol Syntec isn't fully synthetic (but gets to claim it is because it is at least 75% or something like that).
I know Mobil 1 engine oils are fully synthetic. I have previously heard that Mobil 1 ATF and gear lubes were not fully synthetic, but I'm not sure whether this is true or not. I seem to remember that at the time it was supposedly on the product labeling.
However, I trust and respect George and if he says all Mobil 1 products are fully synthetic then I believe him. It is also possible that maybe they weren't at one time but are now, in which case the current product is the one we care about...
Just avoid the 'me too' synthetics. A good synthetic would be Mobil 1 or Royal Purple. A premium synthetic would be AMSOIL, Redline, Motul, or Neo. Beyond that still is the AMSOIL Series 2000 (but there is no Series 2000 ATF).
Regardless, make sure you get synthetic transmission fluid into your tranny. In fact, if someone were to ask me to pick one component on a Tundra for synthetics I'd say the automatic transmission without hesitation.
~ Fred
www.NewEnglandSynthetics.com
"Certified AMSOIL Dealer"
Tundra Solutions Sponsor
Posts: 73 | From: Wakefield, MA | Registered: Feb 2002 | IP: Logged
georgeseq
TS Supporter
Member # 1424
Member Rated:
posted 02-18-2002 06:45 AM
Mobil makes both mineral based & synthetic ATF, Grease, gear oils. All Mobil 1 products are synthetic. Period.. I do not recall any discussions of Mobil 1 being anything but synthetic.. Highly recommend the Mobil 1 synthetic ATF as it is compatible with the OEM original and is API "Certified" which some of the other full synthetic ATF's are not. If there is ever a warranty issue with Toyota, one is completely safe with the Mobil 1 series as all are API 'certified'...
George, STLE CLS
Posts: 13 | From: Columbus, ohio | Registered: Feb 2002 | IP: Logged
TundraWolf
TS Supporter
Member # 30
Member Rated:
posted 02-14-2002 07:25 PM
Fred,
If you don't mind, will you speak to synthetic products versus "Synthetic" products. I do want to change my other lubes at some point and want to go with a good synthetic ATF and lube. I currently use Mobile 1 in the engine but remember members mentioning that Mobile 1 was mostly Dino oil and not Synthetic for the ATF, gear lube and greases. Is that true? Which brands do have true Synthetics? (I know, I know .... AMSOIL ) Others?
Thanks,
Kim
2002 Thunder Gray SR5 4x4. Dreaming of Line-X and a SnugTop.
Posts: 41 | From: Klamath Falls, OR | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Platinum TS Supporter
Member # 12
posted 02-14-2002 03:45 PM
Fred,
Got mine done at the Sullivan Tire in Derry, NH. Was able to bring in my own fluid, but it did cost $75. If I had known about the 2-bucket method then, I probably would have done it myself.
~Glenn~
Moderator
Please consider a TS Supporter or Platinum TS Supporter subscription
Posts: 493 | From: New Hampshire | Registered: Feb 2002 | IP: Logged
RagerXS
Supporting Vendor
Member # 470
Member Rated:
posted 02-14-2002 01:57 PM
What does the flush machine do that the 2 bucket method doesn't? I think that any process that changes all the fluid in the tranny is what matters.
That said, $50 is cheap because I haven't found a quote less than $100 and several shops said 'we only use our fluid'.
If you use AMSOIL synthetic ATF, it is a lifetime fluid. You can be more than assured that if you did the pan drain and fill every 30K miles (even though unnecessary) your transmission will likely outlast the body...
~ Fred
Tomcat17
TS Supporter
Member # 1054
Rate Member posted 02-14-2002 07:11 AM
I just had a complete flush and fill of my Transmission's fluid at the dealer using there flush/fill machine. I purchased my 14 qts. of Mobil 1 ATF from Pep Boys for $90 and the dealer charged me $50 to flush and fill with my fluid through use of their machine. All in all I think this is the best approach since this will get out any particles that might be in the system. I'm sure the 2 bucket trick works just as well but I'd heard from a master mechanic that this method was more effective cleaning out the system. Who knows, all I know is that the transmission seems to shift a little more smoothly than before. I would experience a rough or hard shift from 1st to 2nd sometimes. This has completely gone away now. This truck is worth the $150 or so that it costs to switch to synthetic ATF. I also am using Mobil 1 synthetic oil for the engine. You be the judge for you own vehicle.
Posts: 7 | From: Virginia Beach, VA | Registered: Feb 2002 | IP: Logged
lelandstanford
TS Supporter
Member # 539
Member Rated:
posted 02-14-2002 07:03 AM
quote:
Originally posted by Javahead:
Can someone describe the two bucket method again? I'm going to change mine this weekend. Thanks in advance.
Dave
Try this link:
http://www.ford-diesel.com/faq/1999f...ance-AutoT.htm
Factory Add-Ons:
running boards, RS3000+
Aftermarket Add-Ons: Bumper Opening Screen, Tint, Carbon Metallic Brake Pads
Mods: DRL & DEF Disabled, Fog Light 2C, Map Lights, Headrests
Posts: 64 | From: Houston, TX | Registered: Feb 2002 | IP: Logged
TundraMan 2001
Member # 484
Member Rated:
posted 02-14-2002 04:22 AM
I am posting in reference to the full flush.
Has anyone had this procedure done?
How much did it cost for synthetic?
Thanks for the info.
Bob
CLICK ON MY TUNDRA FOR MORE PHOTOS
2001 Limited 2wd Access Cab, TRD Package, Alpine/MB Quart/JL Audio/Phoenix Gold Stereo System, TRD Wheels (even the spare), TRD Dual Exhaust, TRD Air Filter, 1" EZ Lift Spacers, Line-X Bedliner, Uniden Radar Detector, Hellwig Swaybar, Muth Signal Mirrors & ARE Fiberglass
tonneau cover.
Posts: 65 | From: Fort Worth, TX | Registered: Feb 2002 | IP: Logged
userw5
Member # 48
Member Rated:
posted 02-13-2002 12:11 PM
quote:
Originally posted by KDTundra:
There was much discusion about this before the server crashed. My question is, if you want to go synthetic and a "pan change" is only 4 qts or so and the whole system (torque converter plus) is about 14 qts, is it worth going synthetic with a "pan change"? I'm a big Mobil 1 supporter. Have been convinced by a brother who runs it in engine, transfer case, differentials, etc that its the way to go if you plan on owning it for the lifetime of the vehicle. What do you all think?
Kev.
Kev,
I definitely think it is worth it to do he pan change method of your trans to synthetic. I have been doing my Tundra that way. Each time I change the oil & filter I change 4 qts in the trans. Yes, It may take a little longer and cost a little more, but most people probably don't even change their trans fluid until 30k miles, if that.
It is very easy to remove the pan plug, let drain, then re-install the plug. You will need a long funnel with a skinny bottom to fit into the trans dipstick tube. I put a towel below the opening of the tube, hold the funnel in place and slowly pour in the trans fluid. (4qts)
Some one posted the calculation here a
while back, and in about 7-9 pan changes your trans will be over 90% synthetic. That should be more than adequate.
As for the transfer case and diffs, go ahead and change those too.
Good Luck,
Jeff
Posts: 70 | From: Richmond, VA | Registered: Feb 2002 | IP: Logged
Javahead
TS Supporter
Member # 681
Rate Member posted 02-13-2002 10:27 AM
Dave
Posts: 4 | From: Anaheim, CA, USA | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Member # 12
posted 02-12-2002 06:50 PM
If you want synthetic in your tranny, I suggest you do a full change-over rather than 4 qts at a time. Doing 4 qts at a time will take a long time to get to a 100% synthetic state.
Easiest method for a complete switch over is the "two-bucket" method mentioned on the old site.
~Glenn~
Moderator
KDTundra
TS Supporter
Member # 599
Member Rated:
posted 02-12-2002 05:02 PM
Kev.
Posts: 15 | From: Fulton, Missouri | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Member # 12
posted 02-12-2002 04:50 PM
Full flush and fill is 13-14 qts. Just a pan drain and fill is 4 qts.
~Glenn~
Moderator
Tunda
TS Supporter
Member # 99
Member Rated:
posted 02-12-2002 04:48 PM
I remember other TS members who replaced their ATF said it took 3.5 to 4 qts. and not 2.1 qts.
Posts: 15 | From: Hawaii | Registered: Feb 2002 | IP: Logged
ballgeier
TS Member
Member # 717
Rate Member posted 02-12-2002 02:58 PM
Anyone know the atf capacity of the 2001 tundra?
Its not 2.1 qts. like the owners manual says.
Posts: 12 | From: Ohio | Registered: Feb 2002 | IP: Logged
