Old 03-28-2002, 04:50 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:24 AM
nhparrot's Photo Albums
Default Tundra ATF Question
Topic: Tundra ATF Question
Mohamed
TS Member
Member # 589
Rate Member posted 02-13-2002 02:22 PM
Also, what you can do is actually lift the front end while the drain plug is out. It will get more fluid out especially out the torque converters, since the "T" will be more of at an angle.
Are you okay...you've been hit, you've been struck by a...SMOOTH CRIMINAL
Other pics of My Tundra
Posts: 95 | From: Carmichael, CA | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Platinum TS Supporter
Member # 12
posted 02-12-2002 07:04 PM
ballgeier
4 qts on a pan drain and fill
~Glenn~
Moderator
Please consider a TS Supporter or Platinum TS Supporter subscription
Posts: 493 | From: New Hampshire | Registered: Feb 2002 | IP: Logged
Bugser
Member # 296
Member Rated:
posted 02-12-2002 02:52 PM
I'd ask this question in the Tundra Solutions forum. (First one on the page) It gets a LOT more traffic!!
Sorry I couldn't be more help with your question!
2000 Tundra, V8, SR5 Access Cab, Blue/Gray 2 Tone Paint, running boards, Color Keyed Fender Flares,Tinted Windows, Bed liner, K&N Air Filter, Borla Dual Exhaust, Reese Towing Package, VIP RS 3000 Security System, JVC Cassette Deck/12 Disc Changer, JVC 9 Band Equalizer, 6 1/2" 3 Way Speakers & Tweeters in Doors, 600 Watt 4 Channel Amp, 500 Watt 2 Channel Amp. and 450 Watt Subwoofer. Replaced OEM Horns, Power Outlet Mod. Map Light Mod. 17X8 Rage 160 Polished Rims and 275/60/17 Continental Tires!!
Posts: 189 | From: NC Sandhills | Registered: Feb 2002 | IP: Logged
ballgeier
TS Member
Member # 717
Rate Member posted 02-12-2002 02:03 PM
This weekend I decided to change the tranny fluid in my 2001 Tundra. So I got out the ol' owners manual and checked fluid capacity of the transmission. It said "drain and refill=2.1 U.S. Qts". so I headed off to pep boys and bought three qts.
Drained the tranny and noticed that it seemed like alot more than 2 qts were coming out.
I poured in 2 qts and it was way low.
Continued to add the entire third qt and it was still a little low.
How much does it actually hold? I did not pump it out of the torque converter, which holds more.
Posts: 12 | From: Ohio | Registered: Feb 2002 | IP: Logged
Old 06-18-2002, 10:28 PM
bkoneski47's Avatar
Last Online: 06-27-2005 09:30 PM
bkoneski47 is on a distinguished road.
bkoneski47's Photo Albums
Same thing happened with my change. I had to add about 3 1/2 quarts to get it up to within range on the stick.
