12,500 miles, what do I look out for?
+ Reply to Thread
Results 1 to 4 of 4
Thread: 12,500 miles, what do I look out for?
  1. #1
    Junior Member craigferriter is on a distinguished road.
    Join Date
    Apr 2003
    Location
    Atlanta
    Posts
    76
    Liked
    0 times
    Rep Power
    11
    Default 12,500 miles, what do I look out for?
    Okay gang. I just hit 12,500 miles on my reg cab v6 2003 tundra. I purchased a 60k warrantee and want to know if there is anything that I should look out for from a maintenance standpoint. I want this truck to last forever.
    I changed the rear diff to mobil 1 and only run mobil 1 oil and filter every 3,000.
    This is all I have done and all I intend to do unless you guys yell at me and tell me I should be doing something else.
    My bigger concern is that I will miss the boat on a warrantee thing and end up eating the cost later.
    Advice?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Obama lies ~ the economy dies H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN's Avatar
    Join Date
    Jul 2003
    Location
    USA
    Age
    52
    Posts
    5,694
    Liked
    77 times
    Rep Power
    12638
    Quote Originally Posted by craigferriter
    Advice?
    Stick to your recomended maintenance schedule, use OEM filters and flush your radiator as required you should be fine.
    Check and see if your truck has any TSB's and make sure you run only high quality, name brand fuel.
    Keep us posted as you go.
    2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
  4. #3
    Veteran Member file014 is on a distinguished road.
    Join Date
    Jul 2003
    Location
    Southeast
    Posts
    871
    Liked
    0 times
    Rep Power
    10
    Advice?
    You've got the same truck I do, or just about. I dont think we have much to worry about with '03's. Just drive and enjoy. I dont even use syn and I think this truck will last a long arse time. You purchased a 60K bumper to bumper warranty? Powertrain comes with 60K warr. from the factory...
  5. #4
    Junior Member woody1 is on a distinguished road.
    Join Date
    Feb 2002
    Location
    San Diego, CA
    Posts
    343
    Liked
    0 times
    Rep Power
    12
    Cool
    I'll hit 132K tomorrow; expect to get 500K+ w/routine maintenance:
    6 months OR 5-7K: Change engine oil, I use Mobil 1
    2 years or 50K: Replace Brake fluid and flush radiator
    4 years: R/R Battery
    50K: Replace Differential Oil and Transmission. Again, I recommend Mobil 1
    50-60K: Tires; now on 3rd set
    75K-100K: Plugs
    90-110K: Change ALL belts, hoses, fuel filter and R/R water pump.
    This schedule has worked for many years on a number of high mileage cars and trucks I've worn out or, in the case of Toyotas, finally grew tired of.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
