If I understand your question correctly, you will need to first determine the hose size needed from the cooler that you will be using, then use the same fitting size. I’m not positive, but I believe the z series has included 2 fittings, (3/8 and ½). As much as I like Summit Racing, my preference is to go to a speed and marine shop and look at what is in the box. With any luck, you may have a shop closer than Sacramento.
I’m most interested in what type gauge pod you will be using. Let us know. Thanks
