This is a discussion thread titled "No Throttle responce; Engine light on", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-01-2003, 12:19 PM
mitchr's Avatar
Dealer : Phil Bachman Toyota
mitchr's Photo Albums
Last Online: 07-08-2008 09:53 AM
mitchr is on a distinguished road.
Default No Throttle responce; Engine light on
It has happened two times when I started the truck on a cold morning. I started out this morning and about a half a mile from my house the truck would not go and the engine was still idleing but very fast. The check engine light came on. I could floor the accelerator and the engine would respond slightly. I shut it off and when I started it back up it was OK. The first time it done this I took it to AutoZone(dealer could not get to me untill the next day) and it came back with a code on for the throttle postioning sensor. I am taking it in to dealer tomorow. Has anyone else had this problem or hear of it before....Mitch
Old 12-01-2003, 02:36 PM
Eddie's Avatar
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Eddie's Photo Albums
Eddie is on a distinguished road.
It's happened to Lexus SUVs with the same engine,the TPS is the culprit.
Old 12-03-2003, 10:13 AM
mitchr's Avatar
Toyota dealer said it was the Throttle PEDAL sensor not position sensor. It is expensive at $275+$85 labor. It is the part on the throttle body that your throttle cable comes to and it has all of three screws holding it. I am going to read my Haynes manual again but i think i might be able to do it for less than $85 myself. The bottom line is (IMHO) that this is more B.S. that don't need to be on the Tundra just something to tear up. ..Mitch
Old 12-03-2003, 05:43 PM
Eddie's Avatar
2000 Toyota Tundra,
Sorry,next time I'll say it could be one of the two.
Did they say it's the Throttle/Pedal position sensor or the Accelerator Pedal position sensor? Regardless they're basically the same sensor,5-volt constant voltage with a signal range of 0-5 volts,and are connected to the same shaft.
Old 12-03-2003, 07:31 PM
dupont24's Avatar
Dealer : Bennett Toyota
2003 Toyota Tundra
dupont24's Photo Albums
Last Online: 11-09-2007 06:31 PM
dupont24 is on a distinguished road.
I'll tell ya, your better off replacing the whole throttle body, it's hell to change just the sensor! I've tried twice and both time ended up replacing the throttle body, both were on L/C's.
Old 12-04-2003, 09:49 PM
mitchr's Avatar
You must be thinking about another type of sensor. All I have to do is disconnect the throttle cable and remove three screws. Why would I want to replace the throttle body?
Old 12-10-2003, 06:04 PM
mitchr's Avatar
I replaced the throttle pedal sensor myself today; it took about 15 minutes. The worst part of it was paying for the sensor, which I got at 25% of dealer price, which still cost $186+tax. I hope this was the cure...Mitch
Old 12-10-2003, 07:18 PM
dupont24's Avatar
2003 Toyota Tundra
The sensor has to be adjusted correctly, or the light will continue to come on. The TPS is very difficult too!
Old 12-10-2003, 07:34 PM
mitchr's Avatar
Rsvees, you are talking about the throttle position sensor. It does require very carefull calibration and a special tool for doing it. I replaced the throttle PEDAL sensor which is very simple to replace. It is the part that your throttle cable goes to and moves back and forth as you press the throttle with your foot....Mitch
Old 12-10-2003, 07:38 PM
dupont24's Avatar
2003 Toyota Tundra
Well, maybe I could be wrong........ I coulda swore the L/C I did had to be adjusted too.
Old 12-10-2003, 07:44 PM
mitchr's Avatar
I hope so, but I have been wrong before too. If you get a chance look into it and let me know for sure..Thanks, Mitch
Old 12-10-2003, 07:48 PM
dupont24's Avatar
2003 Toyota Tundra
The L/C could be diff too, we had a recall on all 03 Jap built cars for accell position sensor problems, so maybe they're different, you'll find out for sure in a couple days! I will see if I can find out though.
Old 12-10-2003, 10:12 PM
SATundra's Avatar
Dealer : Alamo Toyota
SATundra's Photo Albums
Last Online: Today 01:04 AM
SATundra is on a distinguished road.
I just picked up my truck from the dealership yesterday. Had the same problem.. driving along and no power, push accelerator nothing, but truck was idiling, all instrument readings were normal. Lasted about 15 seconds each time it happened then back to normal. The motor never died either time it happened.
The part # they replaced was - "22060-50011 lever assy, throttle", but in the repair notes it says "replaced accel position sensor". So im not really sure which part they replaced. The truck now has MUCH better pedal response. It NEVER felt like it has had this much power even when it was brand new. A night and day difference FOR SURE.
Dont think that was the "problem" though because it did it again once today but only for about 2 seconds, was kind of like a hiccup. Every time it has happened I have been on the highway driving at a constant and normal speed. The check engine light was already on because of a bad O2 sensor so Im not sure if it came on or not.
BTW my truck has 50k miles on it. Glad I have the "extended warranty". All I payed was my $50 deductable, and THEY payed for my O2 sensor to be replaced AND the throttle lever assembly at there cost of $491.22.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 12-11-2003, 11:24 AM
mitchr's Avatar
This may become a problem like the O2 sensors. My truck has 40,000 on it but I do alot of city driving...Mitch
Old 01-14-2004, 05:05 PM
Dealer : Lorensen Toyota
2008 Toyota Tundra Timberland Mica
mtelow's Photo Albums
Last Online: 06-11-2008 02:11 PM
mtelow is on a distinguished road.
Default replaced accerator pedal sensor
Just replaced my accelerator pedal sensor. WOW, what a difference. My truck never had so much power and throttle response, even when it was new. I have to be careful not to spin the tires from a dead stop. Just like the post above, I wonder if this part was faulty from the start? Now I hope it cures the cold start problem. Going to be -5F tomorrow morning, I'm keeping my fingers crossed.
