autoRX or Lucas for tranny?
+ Reply to Thread
Results 1 to 8 of 8
Thread: autoRX or Lucas for tranny?
  1. #1
    Junior Member onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all. onsitehunt is a name known to all.
    Join Date
    Apr 2011
    Location
    winfield, MO
    Posts
    65
    Liked
    3 times
    Rep Power
    348
    Default autoRX or Lucas for tranny?
    ok. 291,000 miles starting to get some shirting problems at 55-65 mph on my 2001 tundra.. besides digging into trany to replace parts. should i add Auto RX or Lucas tranny treatment? Or just drop the pan, clean it and replace with mobil1 atf. I am really thinking that i may be geting close to time to sell it and get a new truck what are your results using the tranny treatments. thanks eveyone for their opinions.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member ddvk is on the right track. ddvk is on the right track.
    Join Date
    Oct 2006
    Location
    Austin, TX
    Age
    39
    Posts
    477
    Liked
    1 times
    Rep Power
    7
    Default Re: autoRX or Lucas for tranny?
    Drop pan, replace magnets and fresh new Castrol Import MV ATF will take it to 350K (none of those u mentioned are necessary). Never abuse the tranny it is on it last leg of its life!!!
  4. #3
    Join Date
    Apr 2011
    Location
    winfield, MO
    Posts
    65
    Liked
    3 times
    Rep Power
    348
    Thread Starter
    I agree, its getting up there.
  5. #4
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,109
    Liked
    2023 times
    Images
    47
    Rep Power
    121449
    Quote Originally Posted by ddvk View Post
    Pure armchair opinion on your part. Have you used either of the products mentioned?
    Auto-Rx is an excellent product for cleaning occluded transmission fluid orifices and passages, a major cause of harsh shifts, slipping, etc as the pressures drop and the clutch plates don't get engaged with sufficient force. There are quite a few members here who have had excellent results (me included). It no doubt saved my tranny from an early grave.
    To the OP: if you are experiencing harsh shift points, try the ARX treatment.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #5
    Join Date
    Oct 2006
    Location
    Austin, TX
    Age
    39
    Posts
    477
    Liked
    1 times
    Rep Power
    7
    I don't believe in any "treatments" in a tranny. ATFs have enough soup in them to clean up any gunk in the valve body. Thats just my opinion!!!
  7. #6
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,109
    Liked
    2023 times
    Images
    47
    Rep Power
    121449
    You don't "believe" just on general principle?
    ATF provides hydraulic pressure, lubrication and cooling to the transmission & torque converter. Over time, especially if the ATF is repeatedly taken to the upper range of its operating temperatures through towing etc, it can shear and burn, and the byproducts can lodge in the VB orifices and galleries thus reducing line pressures, clutch pack engagement, etc. It doesn't take much to cause it either.
    I can tell you from personal experience that ARX does work to eliminate harsh shifting, slipping, etc.
  8. #7
    Hall of Fame Member Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,680
    Liked
    1517 times
    Images
    5
    Rep Power
    263671
    Hi Duffy Atkinson.
    What if one enjoys harsh shifts?
    Attention environmentalists, reduce emissions from this:
  9. #8
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,109
    Liked
    2023 times
    Images
    47
    Rep Power
    121449
    Quote Originally Posted by Mr. Creosote View Post
    Hi Duffy Atkinson.
    Hi Burger!
    Then I think one should dump a small can of ddvk's soup in their tranny and call it a day!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
