Hard shift into 3rd some times and in reverse
+ Reply to Thread
Results 1 to 2 of 2
Thread: Hard shift into 3rd some times and in reverse
  1. #1
    Junior Member tundra2000boy is on a distinguished road.
    Join Date
    Sep 2010
    Location
    pelican rapids
    Posts
    155
    Liked
    6 times
    Rep Power
    3
    Default Hard shift into 3rd some times and in reverse
    I own a 2000 tundra 4.7L 4wd, pretty much every time i shift it in reverse it jerks hards and sometimes going from 2nd to 3rd it will jerk u back pretty hard depending on how much throttle i give it, does that mean my tranny is going out?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,104
    Liked
    2020 times
    Images
    47
    Rep Power
    121449
    Default Re: Hard shift into 3rd some times and in reverse
    Usually, it is a line pressure issue in the valve body or shift solenoids. When was the last time you did a 4qt ATF drain/fill?
    Treat your ATF with Auto-Rx. It does a great job of dissolving solids and holding them in suspension to be drained out. Several members here have had excellent results with it -- me included.
    Link to puchase in my sig below.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
Posting Permissions
  • You may not post replies
  • You may not edit your posts
