Motor sputtered out
+ Reply to Thread
Results 1 to 10 of 10
Thread: Motor sputtered out
  1. #1
    Lurking Member TRDon is on a distinguished road. TRDon's Avatar
    Join Date
    Aug 2003
    Location
    St Paul, MN
    Age
    32
    Posts
    24
    Liked
    0 times
    Rep Power
    10
    Question Motor sputtered out
    I have an 03 with the V8 and had an issue for the first time. I know this is no big deal but was curious. I started my truck after it sat for 2-3 hours and it fired and died right away. I turned the key again and all was good. I am not concerned but just curious if this has happened to anyone else or if someone knows what happened. Not like it should matter but I changed to synthetic oil 2 days ago. Thanks in advance!!
    My other car.....isn't a car.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold. red's tundra is a splendid one to behold.
    Join Date
    Mar 2000
    Location
    Hidden Valley Lake, CA
    Age
    35
    Posts
    671
    Liked
    0 times
    Rep Power
    30
    I've had it happen before, but it is usually when I don't hold the key long enough. It starts real quick and dies. It seems if I let go a split second too soon it does it.
  4. #3
    Supporter ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik's Avatar
    Join Date
    Feb 2002
    Location
    Twin Cities, MN
    Posts
    1,446
    Liked
    25 times
    Images
    4
    Rep Power
    973
    That happened to me once 2 months after I bought my truck.Sometimes wierd things happen. Unless it does that regularly you should be fine.
    The cranking on start-up is always followed by a big vroom. But sometimes it's followed by a put-put-put and then a soft vroom.
  5. #4
    Junior Member JeffD is on a distinguished road. JeffD's Avatar
    Join Date
    Jul 2002
    Location
    Jupiter, Fl
    Age
    40
    Posts
    417
    Liked
    0 times
    Rep Power
    11
    The first tundra I test drove did that, and mine does it every once and a while - I think it is when I don't hold the key long enough
    2000 4x4 LTD AC Sunfire Red - Sold w/ 200K
    2005 4x4 LTD AC Phantom grey w/ dark grey - Sold w/ 20K
    Alpine CDA-9835, W/ KCA-420i, Focal 165KP front, Focal 165V Rear speakers. powered by 2 MMats SQ2150 amps. Alpine MRD-M501 powering a JL Stealthbox with Infinity Perfect 10D VQ
    Sound deadened everything with Cascade VB2HD, and Dynamat Extreme
    2005 G35 Sedan 6MT - Returned due to paint work on a 'new' car.
    2006 G35 Sedan 6MT - all stock. Where do I hook up the trailer and where's the bass?
  6. #5
    Supporter Verndog is on a distinguished road. Verndog's Avatar
    Join Date
    Jun 2003
    Location
    Auburn, Wa.
    Posts
    1,379
    Liked
    1 times
    Rep Power
    11
    Quote Originally Posted by JeffD
    The 2003 starter is different. All you have to do is turn the key, and even if you let go it keeps cranking until it starts. So that shouldn't be an issue with newer models. Mine has never died, so I can't really say.
    Kevin
    2003 Silver Sky TRD SR5 V8 4x4 Access Cab
    My 69 Mach 1 Pics
    Factory Options:
    TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
    Appearance Mods:
    PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
    Performance Mods:
    Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
  7. #6
    Junior Member Marcellus is on a distinguished road. Marcellus's Avatar
    Join Date
    Oct 2003
    Location
    Orange County
    Age
    26
    Posts
    91
    Liked
    0 times
    Rep Power
    10
    Default not entirely true
    I've had occasions where I would turn the key and let go right away, the engine would sputter and die. It doesn't crank until it starts. If you notice this, just push the key over and hold it until the engine starts up.
  8. #7
    Supporter LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002's Avatar
    Join Date
    Jan 2003
    Location
    Plymouth, MN
    Age
    72
    Posts
    2,196
    Liked
    9 times
    Images
    17
    Rep Power
    1317
    Must be a gremlin. My 2000 does it and I don't think it's from early key release. Mine does it often enough that I make certain I hold the key till it starts.
    2003 Camry SE V6 Navigation, Sirius, Lunar Mist
    Optima 34R battery
    Turn signals are meant to indicate intent not result.
  9. #8
    Join Date
    Feb 2002
    Location
    Twin Cities, MN
    Posts
    1,446
    Liked
    25 times
    Images
    4
    Rep Power
    973
    Maybe a MN thing.
  10. #9
    Join Date
    Jan 2003
    Location
    Plymouth, MN
    Age
    72
    Posts
    2,196
    Liked
    9 times
    Images
    17
    Rep Power
    1317
    Quote Originally Posted by ricqik
    Maybe a MN thing.
    Probably related to the same gremlin that resides with the Vikings.
    Optima 34R battery
  11. #10
    Junior Member Don H is on a distinguished road.
    Join Date
    Feb 2002
    Location
    West Allis, Wisconsin
    Age
    69
    Posts
    133
    Liked
    3 times
    Rep Power
    12
    Maybe 6 times in 3 years mine has failed to start on the first try. Always after sitting for 3 to 5 hours, never after sitting over night. When it did start the engine would run a little rough for a few seconds like it was partially flooded. Has happened in both winter and summer. I thought that maybe I was releasing the key to soon except one time I realized the engine wasn't starting and held the key for what seemed to be twice as long as normal before it started. Same thing, ran rough for a few seconds. I mentioned this to a Toyota mechanic and said that I thought I might have my foot on the gas pedal without realizing it (I had heard that can cause a problem with fuel injected engines) and he said that would make no difference in the Tundra. Didn't ask him why but I'll bet the throttle motor does its own thing on startup in spite of someones big feet.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
