Truck will not go into 4-Lo
+ Reply to Thread
Results 1 to 10 of 10
Thread: Truck will not go into 4-Lo
  1. #1
    Junior Member jday4 is on a distinguished road.
    Join Date
    Oct 2002
    Location
    Morgantown, WV
    Age
    34
    Posts
    63
    Liked
    0 times
    Rep Power
    11
    Default Truck will not go into 4-Lo
    This winter I needed to use 4-Lo and after putting the truck into Neutral and pushing the button, nothing happened. I have only used 4Lo a couple of times, but can anyone answer this question for me (I can't remember). When you push the 4Lo button in your truck does the button stay down like the 4Hi button or not. The reason why I'm asking this, is because I had a new stereo put in this summer and the button doesn't act the same as the 4Hi. (my 4Hi works just fine). I'm going to take the dash apart and see if this is the problem, but any if someone could tell me what the 4-Lo button should do when you push it, that would be nice. (i get no light and and it just pushes right back out).
    Thanks,
    Jeremy
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    48 times
    Images
    22
    Rep Power
    34450
    flip down your driver's side sun shade and see if there's an orange card with shift instructions like on my 00 .
    otherwise, 2hi->press 4hi->set e-brake->shift to neutral->press 4lo
    alarm will sound or light will flash if error. if light flashes when engaging 4hi, roll forward slowly, if doesnt engage, you have a problem.
    oh yeah...almost forgot...jump out of truck->apply gloves->set hubs to 4x4 unless shifting to 2lo
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  4. #3
    Junior Member arkie6 is on a distinguished road.
    Join Date
    Oct 1999
    Location
    Russellville, Arkansas
    Age
    47
    Posts
    436
    Liked
    0 times
    Rep Power
    14
    Quote Originally Posted by DeepStealth
    Set the emergency brake? Hmmm. Are you sure? On mine, all I have to do is mash on the brake pedal.
  5. #4
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    48 times
    Images
    22
    Rep Power
    34450
    whichever ...so long as truck's not moving
    Manual Hubs
    OB's cup size: 36DD
  6. #5
    Join Date
    Oct 1999
    Location
    Age
    47
    Posts
    436
    Liked
    0 times
    Rep Power
    14
    Quote Originally Posted by hovisimo
    i rarely use the brakes and never use the e-brake (doesn't work) when shifting to 4lo, just put it in N and coasted to a stop, as long as i wasn't on an incline.
    Mine won't go into 4LO unless the brake pedal is fully depressed - the light just flashes. There is an electrical interlock that requires (if functioning properly) that the brake pedal to be deprressed.
  7. #6
    Supporter moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9 is a glorious beacon of light. moosehead9's Avatar
    Join Date
    Sep 2002
    Location
    grottoes,va
    Age
    51
    Posts
    80
    Liked
    0 times
    Rep Power
    249
    I have an 03 Tundra and can't find anything in the owners manual that says to set the parking brake before shifting into or out of 4LO. It says to stop vehicle, shift to
    neutral and hold brake then push 4HI button and when the light indicates 4Hi is engaged then push 4LO button. I can't find anything in the factory repair manual that says there is an interlock on the parking brake or service brake for 4LO. Mine will shift to 4LO with the parking brake released and my foot off the service brake. I tried it on
    level ground with the vehicle stopped and in neutral I pushed the 4LO button and it went right into 4LO very quickly. I was already in 4HI before I stopped. Your 00 model may be different however. I doubt it though, and it sounds like you do have a problem of some sort.
  8. #7
    Join Date
    Oct 1999
    Location
    Age
    47
    Posts
    436
    Liked
    0 times
    Rep Power
    14
    It was stated previously, but another point to stress is that you must be engaged in 4HI before you attempt to engage 4LO. And 4HI can be difficult to engage at times if you are not moving. When you engage 4HI, you engage the front differential as well as the transfer case. If you are stopped and the teeth on the front differential disconnect are not exactly aligned, the front differential will not engage and you will just get a blinking "4HI" indicator. Usually, just moving the truck a few feet will fix this. Best solution is to engage 4HI while the vehicle is moving without any load on the drivetrain (I usually put the transmission in "N" and coast when going into and out of 4HI to ensure that no load exists on the drivetrain).
  9. #8
    Join Date
    Oct 2002
    Location
    Morgantown, WV
    Age
    34
    Posts
    63
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Default Here's my sign
    After taking my dash apart and trying to figure out if there was something wrong with the button, I read some of these posts and feel like an idiot. There was nothing wrong. I was used to my Dad's chevy which only requires the vehicle to be in neutral before putting into 4-Lo. Thanks for the posts anyhow.
    Jeremy
  10. #9
    Guest simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister has a brilliant future. simon barsinister's Avatar
    Join Date
    Oct 2003
    Location
    quincy, ma
    Posts
    50
    Liked
    0 times
    Rep Power
    0
    Default 4wd lo usage
    Have any of you guys used 4wd lo regularly? I just recently used it in a snowy parking lot and noticed it shifts hard (jerks) from 1st to 2nd and 2nd to 3rd? I pointed my side view mirrors to the rear wheels to check for wheel slippage and saw none.
    Anyone else experience this or is it just me? Didn't know if this was normal and would like to get the opinion of someone who uses it.
  11. #10
    Join Date
    Oct 2003
    Location
    quincy, ma
    Posts
    50
    Liked
    0 times
    Rep Power
    0
    Would be nice if they made the V8 with a stick shift. You get much better control in 4wd lo. I don't see the advantage with an automatic, especially with the hard shifts, unless you keep it under 10mph in first gear.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
