Old 12-22-2003, 11:08 AM
rizico's Avatar
Dealer : San Marcos Toyota Scion
2003 Toyota Tundra,
2007 Toyota Camry the Wifey's
Last Online: 09-15-2009 05:43 PM
Images: 2
rizico is on a distinguished road.
Send a message via MSN to rizico rizico's Photo Albums
Exclamation Burning oil!!
I have an 03' Tundra, Saturday afternoon after the truck had been sitting from the previous night, I started it and it turned over about 3 times (usual) and the fourth sounded real weak, but it started anyway, but when it did it blew a thick puff of blue smoke out of my tailpipe(s), and it continued to smoke when I accelerated for the next 3 minutes or so, getting thinner and thinner as it stopped. Also as soon as I started it my oil pressure was unusually high about 3/4 of the way to the top, thats about where it rides when I am going 70-80 mph, but I was idleing and the truck was not idleing high, the oil pressure worked it's way back down slowly over the next 5 minutes or so, back to "normal" range. I started it 3 or 4 more times that day and it was fine, so I was gonna write it off as a stuck valve and wasn't worried about it, but the next morning (Sunday)it did it again, it wasn't as severe as far as smoking (it still did though) but the oil pressure was high again. This morning (Monday) it was fine, although I wouldn't have been able to see smoke since it was dark, but the oil press. was fine. Does this sound like something I need to get looked at ASAP? or can it wait till next week?? I don't want to not have my truck throught the holidays, but I am definately gonna have my dealership look at it eventually.
~Johnny-Don~
My Webpage
Exterior-SS Nerf Bars, Bed rails, Delta tool chest, Sylvania silverstars in headlights (removed, burned out too often), Flowmaster Muffler w/2 SS corvette tips, MY foglight mod, K&N FIPK
Interior-Pioneer AVIC-D2, Grey marble dash kit, fluorescent lights, DVD player, AVIC D@ Navigation, TV tuner, Remote start security system, 600w power inverter, 800w Kenwood amplifier, 10" Kicker SoloBaric in custom (My own design & Work!) box
Factory/Port-LSD, power slider, 17" split-spoke alloys, color-keyed:grille, bumper, mirrors, and side moldings, steering wheel audio controls, limited seats, heated side-view mirrors, compass/temp rearview mirror, tow package, heavy duty battery/alternator, in-dash 6cd changer/tape player, tint by Madico, custom glass etching, permavin security, RS3200 VIP security.
Old 12-22-2003, 06:09 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Last Online: 10-30-2009 07:17 PM
Verndog is on a distinguished road.
Verndog's Photo Albums
My oil pressure always goes to 3/4 at cold idle,(cold idle is between 1000-1200 RPM) only after real warm does it drop to normal 1/4+ mark...I don't think that has anything to do with it. The obvious question is, how old is your oil, and what weight you running. Some mild momentary smoke at startup can be considered normal, even in newer engines, in fact I believe 1/2 quart every 3k is considered normal in many vehicles.
Also....you should leave the pedal alone at startup...and lay off for at least 1 min....reving engine at startup is the fastest way to engine damage known...it takes a good 20 secs. to get oil completely circulating.
I dont get any smoke...not even a puff, I recomend changing oil, and running synthetic if your not already....other then that usually valve seals could be allowing a bit to drop into cylinder after cooling off.
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 12-30-2003, 12:30 AM
zebra1550's Avatar
Dealer : Performance Toyota Of Lavista
2005 Toyota Tacoma
Last Online: 11-13-2009 04:58 AM
zebra1550 is on a distinguished road.
zebra1550's Photo Albums
I think these truck have to be the richest running trucks on the road. I started up my truck this morning and watched it run while standing in my garage. My truck's exhaust was bright,thick& white and smelled like a snowblower, really rich in gasoline. It ran this way for 1-2 minutes, then switched over to the usual transparent/white exhaust and the gasoline smell went away. My truck only has 14K miles, but maybe I need to change over to a platinum plug?
2010 Toyota Tacoma Double Cab 4X4
Magnetic Gray Short Bed w/TRD Off Road Package, Color Matched Hard Tonneau Cover
Old 12-31-2003, 11:10 AM
rizico's Avatar
2003 Toyota Tundra,
Images: 2
Mine hasn't done it again since the last time I posted about it, and I think your right about running rich, I don't know if its becasue I pay more attention to the muffler now, but the truck always has some sort of exhaust "smoke" for the first 1-2 minutes after startup, must be normal. As far as the plugs go, I think the iridiums that are already in our truck are prefered over platimums.
~Johnny-Don~
My Webpage
Old 12-31-2003, 11:28 AM
zebra1550's Avatar
2005 Toyota Tacoma
I was not aware that iridium plugs came stock in our trucks. I always assumed that they came stock with regular tipped plugs. Did you ever pull any of your plugs to confirm this? It would be great if I already had the iridiums in my truck because I was just thinking of installing iridiums.
Old 12-31-2003, 01:36 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Copper plugs are standard. No one has reported any benefit from platinum or iridium plugs except longer plug life, and the coppers are good for 30,000.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 12-31-2003, 02:42 PM
rizico's Avatar
2003 Toyota Tundra,
Images: 2
I'm sorry, for some reason I was thinking that my truck came with iridiums, thats why I haven't even thought about changing them (32,000). I will try to figure out why I thought this, and I will definately be getting new ones soon.
~Johnny-Don~
My Webpage
Old 12-31-2003, 04:54 PM
zebra1550's Avatar
2005 Toyota Tacoma
No problem....it never hurts to throw an idea out there and get some feedback. The only reason I would swithch to and iridium or platinum would be to get more miles out of a better plug. I swapped my wife's 4runner over to platinums when I bought it just so I would'nt have to mess with it for a long time. I'll probably do the same with the Tundra soon.
