This is a discussion thread titled "Header gasket crack causing....................", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-23-2003, 03:19 PM
marks tundra
Guest
Posts: n/a
marks tundra's Photo Albums
Thumbs up Header gasket crack causing....................
knocking noise in engine compartment when truck is cold, and after it cools down after running.After re-torqueing header bolts last week, my buddie and i really felt there was an internal problem....piston slap or possible bearing problem.I brought the truck by the dealer last friday so the serv manager could here what i was talking about.He insisted that although it did sound like a clack,clack/knock,knock he said it sounded also as if it was air passing through a diaphram of some sort(his interpretation)and also garranteed it was not an internal engine issue.So that being said i went to my buddies shop and removed the passenger side header from the engine.What do you think we found? The very last exhaust port on the gasket was cracked!I then emailed ss auto chrome were i purchased them on ebay to inquire buying replacement header gaskets or if using toyota would be better.They repied back saying the gaskets are on shortage and using a factory crush gasket would be the way to go.They use a standard paper gasket for cost cutting reasons.So my advise to all of you are , first make sure the knocking your hearing really isn't your exhaust....believe me, i really thought it was a knock....that's how real it sounds, and for all of you that want to put headers on, regardless of brand, use the stock toyota aluminum gasket,you'll eliminate any exhaust leaks from premature gasket failure.Good Luck all of you with this possible same problem. Mark
Old 12-23-2003, 07:46 PM
thunder gray tundra's Avatar
2006 Toyota 4Runner
Last Online: 08-26-2008 02:30 AM
thunder gray tundra is on a distinguished road.
Send a message via MSN to thunder gray tundra Send a message via Yahoo to thunder gray tundra thunder gray tundra's Photo Albums
What do you think about no gaskets.On old 350 chevy motors when we would put some headers on we would just leave the gasket off and bolt it to the heads.It worked better and it never had any leaks.
2000 SR5 4.7L 4x4 Tundra w/daystar level kit and add a leaf rear,Three inch body lift,Eagle Alloy 16x10 wheels,315/75/16,Pioneer dvd gps system,Front clear corner lamps,rear Altezza tail lamps,40s flowmaster mufflers single in dual out,Stone mountain headers,Helix thottle body spacer,K&N cool air intake system,Dyno-214 hp at rear wheels,Viper alarm W/remote start,Cobra radar detector,And to top it off,my Tundra has a B!tchin driver. My website www.truckinutz.com
Old 12-24-2003, 12:39 AM
2006 Toyota 4Runner
Originally Posted by hovisimo
i wouldn't try it. that's a lot of labor to toy with such an idea. logically, if they leak with the gaskets, they'd leak worse without the gaskets.
Thats not true.I have put headers on lots of vehicle and they always blow out the gasket.Every time,Remove the gasket and the surfaces meet better.As long as everything is nice and flat(smooth surfaces) it wont leak and there is no gasket to blow out.I have the shorty headers on my truck and I installed them with the gasket it came with but if it ever burns out I would use a small bead of high temp silicone and no gasket.Ever new car has thin metal gaskets between the heads and the manifolds.I wouldnt even call it a gasket,but thats what they have.Sorry to disagree but its just my opinion.
Old 12-24-2003, 10:31 AM
d0truji's Avatar
Dealer : Karl Malone Toyota
2003 Toyota Tundra
Last Online: 12-13-2007 03:13 PM
d0truji is on a distinguished road.
d0truji's Photo Albums
How long did you have your headers on before they started leaking?
TRD Supercharger, TRD Boost Gauge, TRD Duals, 2.5 Inch Cornfed Front End Lift, TRD rear AAL's, Stone Mountain Racing Headers, Wet Okole Seat Covers (Front And Back), Clear Corners, BFG 285/75/16 AT's, American Racing Atlas Rims, Rino Liner.
Old 12-24-2003, 01:54 PM
bomber's Avatar
Dealer : Cobb County Toyota Scion
Last Online: 04-18-2008 09:13 AM
bomber is on a distinguished road.
bomber's Photo Albums
I just removed the Autochrome headers the last two days to install the new S&S long tube headers. On the autochromes I retorqued everything after a two week period and when I removed the Autochromes, the exhaust nuts had loosened and there was blow by on the left front header gasket that was causing the same noise you describe. I used the gaskets that came with the headers and wouldn't use them again, period. I would also not reuse the exhaust nut since the locking device is pretty well shot aftet one use, i.e. if you can remove them with just your fingers, replace them.
FWIW,
bomber
Bookmarks
