This is a discussion thread titled "adding limited slip to '00 Tundra", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 12-29-2003, 02:21 PM
Last Online: 02-11-2005 03:31 PM
Steve King is on a distinguished road.
Steve King's Photo Albums
Default adding limited slip to '00 Tundra
Hey folks -- I've done some searches but am still a bit confused....
I have a 2000 Tundra 2WD LTD. Great truck. But, I often tow my 4500lb boat, and on some ramps, I must admit I have problems with slipping. I have to either have bystanders stand in the bed, or on my rear bumper, or else really plan carefully for high tide, etc -- neither is much fun.
I'm thinking that one problem, is the 2000 Tundra's don't have limited slip differential.
1) How much would this help me on slippery boat ramps? In general?
2) It seems possible to add LSD using some $440.00 part by Eaton. Is this true? What kind of $$$ are we talking for installation? I'm certainly no mechanic, and would need to get it professionally done.
Many thanks, all, and have a great New Year.
Steve
Old 12-29-2003, 02:28 PM
H2O_MAN's Avatar
Official Taste Tester
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is on a distinguished road.
H2O_MAN's Photo Albums
Hey Steve,
Check this thread you will find a link to the Kazuma/TRD/Eaton LSD for $230.00
Yes, an LSD will help you in general and on a boat ramp.
The LSD is second only to a locker when it comes to traction.
Installation can run $500.00 @ the dealer. DIY or indi shop and save.
Good luck.
You can choose not to drink from the WHITES ONLY water fountain.
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Old T100 items for sale
Old 12-29-2003, 04:40 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
get a ARB locker and have full power to the rear and a compressor as well
Old 12-29-2003, 05:03 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Steve,
Is one wheel spinning on the boat ramp, or both? If one wheel, a limited slip differential will send power to the non-spinning wheel...but may make both spin if both have equally slippery traction. If both are already spinning on the ramp, an LSD will not help.
The LSD comes in two forms...one is complete, ready to bolt in, and costs more. The other requires set up by a competent differential specialist. It costs less but the labor is more.
I'd suggest contacting your dealer and local differential specialty shops for out-the-door prices.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 12-29-2003, 06:03 PM
Originally Posted by KLS
Steve,
Ken
Ken, it's hard to say...I'm almost always behind the wheel, and usually
once traction breaks, it's gone, and it seems both wheels are spinning.
No fun -- I wish I had 4x4. Don't get me wrong -- a lot of ramps are just
fine, and the Tundra pulls nicely on the road.
I assume the $229 version pointed to by '7.62mm' is the 2nd version of
LSD? I called a small Toyota specialist shop in my area, who I typically use for service, and they quoted something like 10 hours of labor (@$75) to
'do it right', which would put me at around $1k. I doubt they've ever done this before; not to a Tundra, certainly.
I don't really have a spare grand to toss in, for an experiment (just had to pay parts and labor for two 02 sensors which just went bad on the truck), but *if* LSD will pay dividends in general driving situations, *and* help with most of the ramp situations, I'd sure consider it.
I realize this is a tough question to answer.
Sounds like a need to start calling some shops, too, and find a place that specializes in this.
Old 12-30-2003, 07:07 AM
TRDKEAU's Avatar
2006 Toyota 4Runner
Get a ARB full locker, cheaper than a grand and you could possibly re-gear @ the same time w/out paying for labor.
Old 12-30-2003, 04:14 PM
I'm sorry, TRDKEAU -- that's greek to me.
A full locker? This is something I'd engage manually when I needed it? Otherwise, I'd never notice the thing?
A couple of heavy sand bags in the bed of my truck, for days when I use the ramp is beginning to look better and better. <sigh>
Old 12-30-2003, 07:24 PM
TRDKEAU's Avatar
2006 Toyota 4Runner
sand bags or better tires would be the first step I would take.
The ARB locker locks your rear differential providing equal amount of power to BOTH tires when locker is enegaged thru a air compressor. A switch is mounted in your dash panel to lock and unlock rear.
But... if your only concerns are the couple of days out of the year, try LSD or the bags.
Some say a 2wd with full lockers might be as beneficial as a 4wd with a open diff in some cases.
Old 12-30-2003, 08:02 PM
Dealer : Elmore Toyota Scion
Last Online: 10-31-2008 07:06 PM
eapthien is on a distinguished road.
eapthien's Photo Albums
Take a look at the Powertrax no-slip locker, this might be a good fit for you and installation on these is fairly simple.
2000 Tundra Limited4x4
Ext. Donahoes cranked to 2.5"
Total Chaos UCA's
11 pack Deavers
Bilstein 5100's
Diff space drop
930 cv boots
Rack Bushings
And soon to come....
Demello Custom Winch Bumper
Old 01-15-2004, 12:52 AM
mmarlatt's Avatar
Dealer : Lithia Toyota of Vacaville
2003 Toyota Tundra
Last Online: 12-10-2008 08:06 PM
mmarlatt is on a distinguished road.
Send a message via AIM to mmarlatt mmarlatt's Photo Albums
I have three questions that maybe someone can help with.
1) I have a V6 with 4.08:1 gearing would adding the LSD change my gearing?
2) If it does change my gearing what would a 3.92:1 do to me in a V6? The 3.92:1 gearing is what the manual says for a V8 with LSD.
3) The Tacoma TRD Prerunners have a rear differential locker. Can this locker be installed in a Tundra? Would I want to even consider installing it?
Thanks,
Matt
Old 01-15-2004, 06:42 AM
Dealer : Phil Wright Toyota
Last Online: 07-04-2008 02:00 PM
arkie6 is on a distinguished road.
Send a message via Yahoo to arkie6 arkie6's Photo Albums
In general, no. The TRD/Eaton LSD unit and maybe some other aftermarket units that retail for ~$300 do not contain the ring and pinion gears and therefore require considerable setup of the gear mesh via shims and bearing replacement when installing it (read that as probably not DIY unless you have done it before or have a factory shop manual and are an above average DIYer with lots of tools). TRD did offer an LSD on exchange basis that included the entire differential "pumpkin" which includes the ring and pinion gears already assembled. This retailed for around ~$800 plus a core exhange and required that you send in your old pumpkin to get your core back. I would consider this LSD swapout DIY.
Not a big change in gearing, but I wouldn't recommend going in that direction, especially if you ever consider putting larger tires on the truck which will effective raise your gear ratio (equivalent to lowering the rear differential ratio #) or pull a load.
Nope, won't fit the Tundra. Different size (smaller) differential entirely.
Old 01-15-2004, 11:12 AM
mmarlatt's Avatar
2003 Toyota Tundra
Very good info, thanks!
Bookmarks
