Old 03-01-2002, 07:39 PM
Dealer : Lake Charles Toyota
2001 Toyota Sequoia
Last Online: 08-15-2009 03:17 PM
doctormdds is on a distinguished road.
doctormdds's Photo Albums
Default Power Steering Fluid
I have switched to Mobil 1 for my engine oil, ATF, and Gear Lube for the differential. Can I use Mobil 1 ATF for the power steering unit? If I remember correctly the owner's manual specifies Dexron II or Dexron III. What is everyone using to top off the power steering reservoir? Thanks to all.
Stan
Old 03-02-2002, 05:47 PM
shortlid's Avatar
Dealer : Rockingham Toyota
2004 Toyota Highlander V6, 4WD, 7-pass
Last Online: 11-12-2009 09:11 PM
shortlid is on a distinguished road.
shortlid's Photo Albums
Default Re: Power Steering Fluid
Ya, you can use a baster to suck the old stuff out and swap with synthetic ATF!
I use to work at TMMI, Just bought a '04 Highlander 7 pass, 4WD for my family wioth 106k on the clock. Can you help me take it to 300k?
Old 03-05-2002, 09:05 PM
Last Online: 12-31-1969 07:00 PM
tonysSeq is on a distinguished road.
tonysSeq's Photo Albums
Is this correct? We can use Mobil ATF fluid for the braking fluid? Is it the same as Braking fluid?
Old 03-06-2002, 05:23 AM
Dealer : Phil Wright Toyota
Last Online: 05-10-2009 12:08 AM
arkie6 is on a distinguished road.
Send a message via Yahoo to arkie6 arkie6's Photo Albums
quote:
No. Most definitely not.
Only use DOT 3 or DOT 4 brake fluid for the brake fluid resorvoir. Do not use DOT 5 silicon brake fluid since it is not compatible with the existing brake fluid.
Here is a link that discusses brake fluids http://www.shotimes.com/SHO3brakefluid.html
You can use a Dexron III Automatic Transmission Fluid (ATF) in your power steering resorvoir (check your owners manual - all this stuff is in there). Mobil 1 Synthetic ATF is Dexron III rated and a good choice for your power steering unit.
