Hello!
+ Reply to Thread
Results 1 to 5 of 5
Thread: Hello!
  1. #1
    Rookie nkyrental is on a distinguished road.
    Join Date
    May 2012
    Location
    Cincinnati
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default Hello!
    New member here with a 2012 Tundra double cab, 4.6L 4x4. Like the truck a lot so far, I've had it for a few months. Do have a question though, I checked the rear differential fluid before we towed our camper to the lake, and when I removed the fill plug, there was audible pressure built up in the differential. So, I checked it a few days later and again enough pressure to hear the air loss when the fill plug was loosened. Anyone have this problem, and wouldn't constant built-up pressure cause future seal leaks? I'm wondering if there are any aftermarket differential vents to replace the 50 cent one on the diff now that would work better. Thanks in advance.
  2. #2
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,478
    Liked
    1379 times
    Blog Entries
    78
    Images
    65
    Rep Power
    183163
    Default Re: Hello!
    Quote Originally Posted by nkyrental View Post
    Not familiar with the second generation set-up but I would be concerned about this. I had three seal failures (replete with washed out bearings and, due to some genius decisions on my half during reassembly - a new rear end) as a result of a clogged breather. I did the breather extension modification and have not had a problem since.
    Welcome to the best Tundra Forum on the internet and congratulations on the best AMERICAN made truck in the world.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  3. #3
    Veteran Member Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,087
    Liked
    305 times
    Images
    1
    Rep Power
    13247
    Default Re: Hello!
    Not sure if the Nissan part would work on the Tundies, but here ya go:
    Minute Mod: Differential Breather - ORN
    Jackson's Rear Diff Breather
    I did those mods on my 80 Toy Hilux, and one of my '88 Toy PU's.
    I'll probably do it on the Tundie.
    To find out if the Nissan part will work, I'll check the part number for the breather vent on an early 90's Toy PU, and compare it with one from a later Tacoma, and the Tundie to see if they are the same. If so, the Nissan part should work.
  4. #4
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,478
    Liked
    1379 times
    Blog Entries
    78
    Images
    65
    Rep Power
    183163
    Default Re: Hello!
    Quote Originally Posted by Stone_Blue View Post
    I just went to Auto Zone and sized up a brass fitting by eyeballing it and got lucky. You will want to go with as large a nipple (Heh heh) as possible and the largest ID tubing that will work with that nipple. I think I went with a 3/8 ID hose.
  5. #5
    Veteran Member Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones is a splendid one to behold. Tones's Avatar
    Join Date
    Dec 2005
    Location
    Houston, TX
    Posts
    565
    Liked
    6 times
    Rep Power
    21
    Default Re: Hello!
    What you are likely hearing is a vacuum being relieved. The breather is a check valve which will relieve pressure as the diff heats up for the very reason you are concerned about. The check valve will not allow external air/water to come back in as the diff cools, creating a vacuum. Perfectly normal. You probably checked it cold? so where would the pressure come from?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
