This is a discussion thread titled "Supercharger maintenance", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-20-2004, 08:59 PM
sprj8008's Avatar
Toy Junkie
Dealer : High River Toyota
2002 Toyota 4Runner,
2003 Toyota Sequoia
Last Online: 12-23-2008 11:05 PM
sprj8008 is on a distinguished road.
sprj8008's Photo Albums
Default Supercharger maintenance
I've got 20,000km on the engine now. Are their any recommended service requirements for the supercharger?
Is it a closed unit?
Jason
Old 01-20-2004, 10:24 PM
zebra1550's Avatar
Dealer : Performance Toyota Of Lavista
2005 Toyota Tacoma
Last Online: 11-06-2008 08:47 PM
zebra1550 is on a distinguished road.
zebra1550's Photo Albums
most don't require any service until 100,000 miles, at which time a change of the gear oil in the nose is recommended. You could change the oil sooner if you want. Try www.gadgetonline.com for more info.
2005 Toyota Tacoma Double Cab 4X4
Speedway Blue Short Bed w/TRD Off Road Package, 2006 Tundra Wheels with 265/75R16 BFG AT KO's, Python 2-Way Remote Starter, Color Matched Hard Tonneau Cover
Old 01-20-2004, 11:25 PM
scdtrd's Avatar
Dealer : Lagrange Toyota
Last Online: 07-31-2008 05:34 PM
scdtrd is on a distinguished road.
scdtrd's Photo Albums
Jason
I had the 3.4L S/C on my Tacoma and it had 75,000 on it. I called Judd at Manguson and ordered the replacement oil kit. Judd is very nice and was a bit leary in talking to me. His reservation was that TRD SOLD the S/C and I really should go to TRD for replacement oil and parts. I told Judd that I knew what I was doing and that the S/C was out of warrenty anyway. He sold me the kit for $30.00 (It was so long ago, that is in the ball park). Anyway.. TRD wanted like 3x more or something. In speaking with Judd he said that if I had a problem with it, I could have it rebuilt for $500.00 (again, old quote) and a replacement nose cone was like $300.00 (old quote). TRD.... MUCH HIGHER.
So, I called my Toyota bud David, and he and I pulled the S/C and replaced the oil. Took like 2hr start to finish.. off, replace oil, put back, crankup.
The S/C for the V6 Tundra and the V6 Tacoma is an Eaton M45. Here is Manguson's page on that one. http://www.magnusonproducts.com/mp45.htm
The S/C itself is made by Eaton, but Manguson designed and adapted it for the 3.4L V6 for Toytota on behalf of TRD. The V8 S/C is an Eaton M90 http://www.magnusonproducts.com/mp90.htm and the same concept applies here as well. Here is Eaton's web info on their Automotive S/C line. http://www.automotive.eaton.com/prod...rchargers.html
As far as wear and tear on the S/C itself, the main culprit for S/C failure is over spinning the rotors too much. The rotors are a twisted tri lobe design. Basically, the tri lobe helps in the sealing and the air delivery pressure pulse. The twist further eliminates the pressure pulse and helps smooth out the air delivery in the plenum. The rotors are the real "high dollar" part of the S/C. They are light weight, and of an alloy that resists heat expansion. They are coated with a protective resin. If you over drive the rotors, for more boost, the compressed air gets hotter. If you run too high a boost, then you can thermally strip the coating. The clearance between the rotor and the S/C housing is VERY close. If the coating is frayed, then the S/C housing can get scared, reducing the "seal" and reducing the effective boost. If you look at the pages I added here, you can see the delta rise in tempature vs. boost level for all RPM ranges in service. Notice the rotors are spinning VERY fast, and that is THEIR specs. Imagine how fast they are going if you over drive it and the temps created! All in all, the sealed unit is VERY durable, well designed and built. You should not worry about the S/C until 75,000 to 90,000 miles are on it. Just make sure you keep a GOOD air filter in place.
I hope this helps you!
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Bookmarks
