Old 01-26-2004, 10:52 PM
Toy4ever's Avatar
Last Online: 11-06-2005 12:22 AM
Toy4ever is on a distinguished road.
Toy4ever's Photo Albums
Default Driveshaft problem - cause of vibration???
just got under my truck to see if I can find the source of my vibration. I am sure it is not the tires. I have had dunlops, michelins, bf good riches, wranglers, and now wild country's. The truck has always vibrated at certain speeds not to mention when braking. I have noticed two things.
1) My driveshaft seems to have something peeled off of it. Is it a balancing weight??? I am not sure. Look at this http://www.tundrasolutions.com/photo...riveshaft1.JPG
2) My right rear leaf springs are not stacked correctly. I have had them replaced once at around 12000 miles for the same reason????
http://www.tundrasolutions.com/photo...C00546-med.JPG
http://www.tundrasolutions.com/photo...C00547-med.JPG
Checkout my photos for all the pictures and closeups........
moderator note:changed images to links due to size
Old 01-26-2004, 11:44 PM
bri bri is offline
Dealer : Carlson Toyota
2003 Toyota Tundra 4x4 SR5 Access Cab
Last Online: 08-25-2009 11:32 PM
bri is on a distinguished road.
bri's Photo Albums
I have had vibration problems in both my Tundras. On this last one I thought it was the driveshaft, I could actually see the wobble in it when I spun it by hand. The Toyota dealer took it off and sent it out to a driveshaft shop, they seemed to have straightened a bit and balanced it. There was marginal improvement. The biggest single vibration problem I have had are tires. Even with Michelins I've found it took the shop two or three tries with a Hunter Road Force Balancer to get it right. My truck is getting a little better with age, don't know why. On your 2wd I noticed the driveshaft is different. You have no slip spline at the rear like the 4x4. Looks to me like a sticker is comming off the driveshaft. The balance weights are rectangular and metal. I plan to have a good driveshaft shop make me a one piece shaft as soon as my warantee is up. This will eliminate alignment issues with the center carrier bearing (do a seach on this if you are not familiar with that issue). The vib could be from a lot of things, bad brake drum, out of tolerance rear axel, driveshaft, tires, alignment, bad wheel. I doubt it is from the springs though. It's a frustrating problem, a lot of dealers are useless at solving it. If my next truck is a Nissan, my vibrations will be the reason why.
Old 01-27-2004, 12:30 AM
mandzach's Avatar
mandzach
Dealer : Findlay Toyota Scion
2003 Toyota Tundra,
2007 Toyota Tacoma SILVER-DC-OR-4x4
Last Online: 10-13-2007 12:40 AM
mandzach is on a distinguished road.
mandzach's Photo Albums
Default ive heard of this
ask member name v8toilet - if i remember correctly he lost a weight of his drive shaft on the way to the race track - id be at my dealer demanding that they pull the shaft and have it reballanced -id also have them check the front ballance weights if you have a 4x4.
Old 01-27-2004, 02:20 AM
Toy4ever's Avatar
Actually the sticker thing is the same shape as the weights. The same size also. They are round on mine. I was wondering about the tires, but I have been through four sets and now a new set of rims as well. Still does it. I am curious about the rear axle thing though.....hmmmm!!!!
Sold Toyota Tundra.....
Bought a honda.....Good luck everyone...This was one of the best websites I have ever seen for a vehicle as far as information goes. I have learned so much from you guys. Thanks......
Old 01-27-2004, 03:34 PM
Toy4ever's Avatar
Anyone else have any ideas???
Old 01-27-2004, 07:31 PM
bri bri is offline
bri's Photo Albums
Funny about the weights. Maybe they use different one on the 2wd, all mine are rectangular. -Bri
Old 01-27-2004, 11:13 PM
Toy4ever's Avatar
I think it is just a matter of who they purchased the drive shafts from and who balanced them originally....
