This is a discussion thread titled "TRD supercharger for the 04 DC", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
I've done some search on the discussion forum trying to find out if the TRD supercharger is available for the 04 DC...
here is what I found out..
previous - 02 supercharger is different than 03 because injectors and computers are different..
however, I don't know if the 03 supercharger will fit the 04.. (I saw one auction on ebay selling the 03 supercharger and in the description, it stated that it won't work on the 04 model ??? )
anyways, I am just trying to clear things up and see if you guys have any updated info on this matter..
if you guys can provide a place to purchase or the part # will be great..
thanks again
Richard
I'm positive there's an S/C for the 04'. Trailer Boats magazine tested a supercharged (dealer installed) Double Cab in the Feb. 2004 issue.
__________________ 2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
thanks again
Richard
You are correct, a 2003 doesn't fit on a 2004. I believe the last three #'s for the D/C 2004 kit is 622. My dealer made that mistake and I had to wait an extra week for the correct unit to be shipped from California. It almost killed me to wait but boy was it worth the wait. Between the S/C, the headers, and the dual exhaust (all TRD) this thing is a missle, What a hoot to drive. Take the plunge! Mike
The difference from year to year is the fuel mapping...The exhaust emmisions get stricter. Also there are differences in the connectors that they use between componentry. I have a 2000 LTD, and the charger I got was for the 2003. They are swapping out the harware,Piggyback ECU and a few other things that I'm not up on.The Tech at TRD told me each kit is specific to the year of truck.2000-2002 are the same, and the 2003 and 2004 each have thier own specific part#
mike
Originally Posted by JDMRICE
thank you guys for clear things up...
but do you guys know what's the difference?..I am just curious...because I thought it's suppose to be the same motor..?? why make difference s/c kit??
and Michael, what kind of header and exhaust do you have?...thanks
Richard
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
Richard
My system is TRD front to back. TRD headers and TRD dual exhaust. I'm not sure what the difference between the two S/C's are but they had the 2003 bolted on to my engine and when they went to plug in electrical connections they realized they had a problem, My service manager said that TRD changes the pin locations in the connections just about every year. He said that if he took the time he could splice it together but he decided to do the right thing. I hope this helps to answer your question. Mike
There is no difference in the s/c itself...but the piggy back ECU and how it's programmed makes the thing fast or a slug....depending on the fuel air ratio's and shift points. They have been detuning them since they first came out. It's as if the early ones came with more aggressive mapping, then they realized that the things were too fast.
mike
I have been on the fence about getting a supercharger rolled into the cost of my new 2004 Tundra DC SR5 4Wd. I plan on keeping the truck for around seven years and I am worried about the life of the Supercharger. Do you guys think the Supercharger/Engine will be good for 175,000 miles. Also, will the system hold quality as far as resale. Just wondering. I think adding a supercharger to the 2004 DC Tundra will make it one bad a$$ truck from a H.P. and a towing standpoint. Not to mention, you will be able to get a Unichip Plug N Play to add even more H.P. and torque here in the near future.
Previous Trucks Owned:
1990 Toyota Xtra-Cab 2wd (145,000 miles)
1996 Toyota Tacoma Ext. Cab 4wd (171,000 miles)
2004 Toyota Tundra DC 4wd (Phantom Grey - 48,700 miles and counting)
Toyota truck user for 16 years and counting..........
Also known as Thibodeaux at the Fuge.
Gig'em Ag's (Class of '94)
Modifications on DC to date:
3" Toytec lift, 1.5" Add-A-Leaf, Line X, Eagle Alloys Series 101 16x8 (3.60 B.S.), 285/75/R16's Cooper Discoverer ST's
i must vent and this seems like a good thread to do it on. what in the F#!K is wrong with trd ? i mean there is no positive info anywhere on there products and there applications - dont leave me web page links showing trd products cause ive seen them all - its just that every trd page is diffrent and never has up to date info on them - ever try to buy level 2 trd parts ? haaaaa dont even try to buy level 3 trd sport parts from japan on line its a JOKE!
befor i bought my 03 tundra i researched for 2 years, yes 2 years ! , on what vehicle to buy keeping it mostly stock and having the fastest 4x4 that was still reliable daily driver. i looked at sti's and evo's and settled on the tundra mostly because it was alot safer in case of a wreck ( full frame ) .. guess i should have researched more because i missed how much of a joke TRD is and how toyota dealerships (99% of them) are complete a$$holes to the public/customers due to what i see as product sells itself so we (sales/service) can be lazy,ignorant,waste of human life, pos !
i went to a Mitsh. dealer looking at an evo and the sales guy told me everything about the car - im talking down to the lobe of the camshaft- he also stated 2 of there service guys drag built up evos and hold state record for 1/4 mile..... ever find a toyota dealer like that ? for gods sake my toyota dealer does not even know what trd makes... they need to look up parts and make phone calls for a freakin trd oil filter application ! im so sick of toyota and trd that i made them purchase there 7yr./100,000 mi. warr. back from me at full price. guess what - i got my $1100.00 check in the mail after fighting with them and now im still fighting with my dealer to pay me back my $70.00 of tax i paid for the warr. ! go to a ford svt site or a subaru sti/wrx site or any other performance site and compare it with TRD its sad.
most of you already know all about what im saying here and i think if we have 20,000+ members in this club we should ban together and make a statement that we want to see improvment on the whole from toyota and trd because i know they lost a customer with me unless serious changes are made- what a joke ! oh ya one more rant - go to toyotas web site and try to build your own tundra haaaaaaaaaaaaaa i thought japan new how to build things better than usa- try building a corp. wab page that works to start Toyota !
I hate to say it but you are right on some points . My dealer has no clue about this truck. I have to tell them what to do. Of course my dealer doesn't know any thing about TRD, I've bought more stuff from Carsons. As far as TRD web site you are absolutly right , I have no clue what they really sell. I'm not any computer genuis but I can find my way around. But due to the poor web sites I spent an hour yesterday trying to find a TRD drop in air filter for my 4runner without luck. They are missing out on a lot of business, oh well their loss
mattom just noticed your not far from me - if your ever upstate let me know befor hand and we can hook up and compare notes.
I'm up that way all time snowboarding. I would love to actually see a supercharger in person . Maybe I'll get talked into buying one
If I knew I could have had it installed new and financed I'd have got it without hesitation . Matt
Apparently the 2004 V8 S/C has come down in price. I spoke to a dealer in Edmonton today and was told it was a few thousand Canadian less in cost. Get this....the v8 charger(for my 2000) is $9200.00 plus 7% GST plus install plus boost guage. The install is 8 hours at dealer shop rate of 86.00/hr.... Total cost out the door for my 2000 would have been 10,800.00 Canadian. For the 2004, they said a few grand less. Thank god I found one online....
ya well i rolled it into my loan also my girl works at the credit union no questions just signed on the line got it all-s/c,dual trd,trd headers all into the loan then came time for the dealer to get me the parts and ohhhhhhh sir we cant seem to order 03' headers cause ouuuuuggghh they dont make them , lmao - i already new that when i ordered the truck- so i say to the sales guy , well i want to be repaid for the headers and the dual exhuast , ( that was my tax on the rig paid for by the loan ) damn toyota guys are god darn dumb
anyways next time your up near syracuse drop me a pm and we can get together - im laid off till march so winter time is wide open
