This is a discussion thread titled "Resonator for Smog in California", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-12-2004, 02:01 AM
tundradcabtrd's Avatar
Dealer : Moreno Valley Toyota Scion
2005 Toyota Tacoma
tundradcabtrd's Photo Albums
Last Online: 11-20-2008 02:20 AM
tundradcabtrd is on a distinguished road.
Default Resonator for Smog in California
I have an 04 Tundra Double with 2 Cats and 1 Resonator. I cut the resonator off so my Flowmaster could sound louder. Will I still be able to pass Smog in California now that I cut the resonator off? How often are you supposed to get Smog tests in California.?
Old 03-12-2004, 02:54 AM
Rlockyer's Avatar
Dealer : Crown Toyota Scion
2004 Toyota RAV4
Rlockyer's Photo Albums
Rlockyer is on a distinguished road.
Every other year, beginning when the vehicle is 5 years old, however, whether the year is even or odd is determined by the VIN number, but if that would put the first year on the 6th year, then you'll get hit with a test to renew the 4th year. My '00 Echo actually came due for a test this year, even though it's first registration was May of 2000.
As to whether you'll pass smog or not, it depends on the tester. If you get randomly selected for a test-only station, they will be more likely to peg you than if you just go to the local mechanic, however, I have had test-only not even look under the car.
Technically, you've modified the exhaust system which is a failure.
2003 SR5 TRD V8
Traded in, 8-20-2005 with 125k trouble-free.
Old 03-12-2004, 10:31 AM
Dealer : Poway Toyota
2004 Toyota Tundra
dezert_rida's Photo Albums
Last Online: 11-19-2008 01:35 AM
dezert_rida is on a distinguished road.
Send a message via Yahoo to dezert_rida
The resonator has nothing do due with emissions. Its a straight through muffler for noise suppression. As long as the cats are in place, you can run anything you want behind it. You could run straight duals behind if you wanted.
Old 03-12-2004, 11:55 AM
Agent WD-40's Avatar
Dealer : Fox Toyota of Rochester
Agent WD-40's Photo Albums
Last Online: 09-20-2008 05:04 PM
Agent WD-40 is on a distinguished road.
I thought all CA vehicles came with 3 cats. The resonator on the non Ca models was replaced with a cat on a CA model. If you removed the extra cat the you may not pass. Look in that picture below, it us my truck. The first thing on the way back to the back is the extra cat that CA models come with. The next thing is a resonator that came on my TRD exahust. The last thing (the big one) is the muffler. Which one did you cut off? I always thought that the CA trucks had 3 cats, but that may have changed. The resonator came with the TRD exahust, not from the factory.
http://www.tundrasolutions.com/photo...cat/500/page/4
Old 03-12-2004, 12:30 PM
Inactive Account
Dealer : Bill Wright Toyota Scion
2003 Toyota Tundra
Patton's Photo Albums
Last Online: 05-09-2006 10:43 PM
Patton is on a distinguished road.
Toyota redesigned the converter system in '03'. More efficient converters off the manifolds did away with the 3rd cat downstream. Ca Tundras now have a resonator in place of that older 3rd cat. Anythin 'cat-back' , which is now behind the two main cats will be fine.
Old 03-12-2004, 12:46 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 04:30 PM
can the old cats be swapped for the new cats on an older non-ca model?
-s
GFX by FreedomEagle50
Manual Hubs
Old 03-12-2004, 05:22 PM
2005 Toyota Tacoma
i cant speak for other trucks but the 04 has 2 cats a a resonator i confirmed this with a muffler shop.
Old 03-12-2004, 07:42 PM
Interesting. I learned something new. The resonator won't have an effect on smog. It will change noise though. It is just a hollow can.
Old 03-14-2004, 06:09 PM
rxvcgiii's Avatar
Dealer : Frontier Toyota
2006 Toyota 4Runner
rxvcgiii's Photo Albums
Last Online: 08-17-2008 02:54 PM
rxvcgiii is on a distinguished road.
Send a message via AIM to rxvcgiii
So that would mean 00-02 models have three semi-inefficient cats while 03-04 models have two efficient cats. In that case, if I did away with my third cat (and resonator), my truck has less of a chance of passing smog than a 03-04... correct?
Armada 176 AR5s Skis, Look P12 Jib Bindings, Rossignol Bandit B1 Boots, Scott Poles... in the bed of a 2000 V8 Tundra 2x4 Access Cab with:
JBA Titanium Coated Headers, Stone Mountain Racing Y-Pipe, Flowmaster 50 Exhuast, Teamwest Sway-A-Way Coilovers, Camburg Upper Control Arms, Wheeler's Add-A-Leafs, AEM Brute Force Intake, MB Quarts, US Acoustics Amp, Bazooka Tube, Lots of Dynamat, A.R.E. LSII Tonneau Cover, Sir Michaels Rollpan, Bushwacker Flares, Shaved BSM, Billet Grilles, Mickey Thompson Classic Locks, 305/70/16 Pro-Comp X-Terrains, Lots of little things here and there. Future Projects: Color-Coded White Rear Bumper and Tailgate handle, Revalve SAWs, Deaver 11 Leaf Packs, Bilstein 5100 Rear Shocks.
All this info repeated here!
Old 03-14-2004, 10:08 PM
2004 Toyota Tundra
RX, you wont pass the visual check if you remove your 3rd cat for sure. Its possible it would pass the tail pipe test with 2 cats. The 03 and ups have larger cats below the manifolds, making them more efficient than previous years. This is nice for those of us(myself included) that want to do 3" piping from the Y back legally.
