Old 03-12-2004, 01:34 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Default T100 Drag link/Steering relay rod safety related failure *PICS*
Heads up T100 owners.
It seems there is a problem with 4WD T100 drag links (Toyota calls it a "steering relay rod").
Mine snapped today. When this happens - you can't steer!
Lucky for me this occured as I was pulling into a service bay at very low speed.
The same thing happened about a year ago to one of the mechanics at the shop I use.
He has a '95 4WD T100, mine is a '96. He reported the issue to Toyota and never got a response.
We filed a report to the NHTSA Office of Defects Investigation.
PICTURES
As you can see the replacement rod is about 1/4" wider.
That tells me Toyota is aware of the problem
I now have five confirmed failures. The break is in the same place on all 5.
Has anyone else had this happen??? -- Please post your details.
(Moderators please note: I was not sure of the best place to post this information on TS)
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Old 03-12-2004, 02:07 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:02 PM
Images: 22
that looks like a *very* clean break. is there any visible necking? was there any warning, or was it completely catastrophic? (edit: i meant catastrophic as in failure, not as in accident fortunately!)
i'm sure there are a few metallurgists around here, anyone have any input?
-s
GFX by FreedomEagle50
Manual Hubs
Old 03-12-2004, 02:38 PM
H2O_MAN's Avatar
-s
No warning. It just snapped.
It could have been catastophic at speed.
You would not be able to steer, front brakes would be a joke!
I guess you could yank on the E brake and hope for the best.
I hope the metallurgists on this forum have a look.
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
Old 03-13-2004, 03:35 PM
H2O_MAN's Avatar
Maybe this post should be in Handling, Suspension & Brakes.
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
Old 03-13-2004, 10:59 PM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX,
2009 Toyota Camry HV (wife's car)
Last Online: 10-04-2009 05:29 PM
THarms is on a distinguished road.
THarms's Photo Albums
Thanks for the heads up... I'm going to inspect them on my '95 T100 4x4 first thing in the morning... agree that it does look like a clean break except for that little "divot" at the top/middle... is that "divot" part of the original design or had it rusted down that far on its own due to a design defect? Except for the headgasket TSB, this truck has been indestructible... atleast up until now...
How much work is it to change them out?? and how much do the replacement parts cost? (I'm going to replace them, I just would like to prepare myself mentally for the sticker shock...)
Old 03-14-2004, 03:03 AM
warrior's Avatar
Here for the long haul...
Dealer : Peterson Toyota
2001 Toyota Tundra,
2005 Toyota Corolla
Last Online: 01-23-2009 07:38 AM
warrior is on a distinguished road.
warrior's Photo Albums
Default Just 4wd?
Is this just related to 4wd or should 2wd be looked into as well? My mom owns a 93 ( I think that is the year) T100 2wd and I would like to give her a heads up if it would pertain to her model. Is there a recall on that yet? Thanks
Old 03-14-2004, 07:38 AM
H2O_MAN's Avatar
So far 4WD only. I would still inspect a 2WD rod.
Go to this NHTSA site: http://www-odi.nhtsa.dot.gov/cars/pr...lain/index.cfm
That is the complaint section. Go to view complaints and go through the process of entering vehicle year/make/model. Then it will give you a drop down menu of complaint areas. Just check in steering, steering linkage, steering linkage-drag link, each years list is a little different. You will be surprised by the number of complaints. They are just summaries so some say lost steering but others specify the drag link.One in 97 is from a structural engineer if that lends any authenticity.
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
Old 03-14-2004, 02:15 PM
THarms's Avatar
not to make light of the severity of this issue... but came across this one report on the NHTSA sight under the Sequoia sections:
Make : TOYOTA Model : SEQUOIA Year : 2001
Crash : No Fire : No Number of Injuries: 1
ODI ID Number : 890971 Date of Failure: June 9, 2001
Component: AIR BAGS:FRONTAL
Summary:
CONSUMER'S WIFE WAS DRIVING AT APPROXIMATELY 440 MPH WHEN ANOTHER VEHICLE TRAVELLING 60 MPH RAN A RED LIGHT AND TURNED INTO CONSUMER'S VEHICLE, HITTING IT HEAD-ON. FRONT END WAS SEVERELY DAMAGED, PUSHING RADIATOR THROUGH THE ENGINE. AIRBAGS DIDN'T DEPLOY. CONSUMER WAS INJURED. MANUFACTURER HAS APOLOGIZED, AND WILL SEND SOMEONE OUT TO INSPECT VEHICLE. AMOUNT OF DAMAGE WAS $23629. VEHICLE WILL TAKE APPROXIMATELY 9 MONTHS TO BE TOTALLY REPAIRED. *AK TOYOTA ISSUED A LETTER TO CONSUMER STATING THAT THE SRS OPERATED AS DESIGNED. *SLC
Mine doesn't do anywhere near 440MPH... maybe it is worth adding those TRD headers and a K&N intake!!
Old 03-14-2004, 05:47 PM
Images: 22
acciddental doubble keyy .
Manual Hubs
Old 03-29-2004, 12:53 AM
Dealer : Toyota of Santa Cruz
2000 Toyota Tundra,
2005 Toyota 4Runner Sheri's
Last Online: 10-02-2007 09:55 PM
fits the family is on a distinguished road.
fits the family's Photo Albums
Default t-100 relay rod
Before my Tundra I had a T-100 the same thing happened to me. Pulling off the road into a driveway slow speed it snapped. Same spot as yours did. I replaced it myself and did relize the new one is longer. I sold the truck to my cousin so keep us posted on what toyota says.
Thanks,
F.T.F.
Old 04-01-2004, 04:27 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Last Online: 05-04-2009 09:43 AM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
PICTURES
Yikes,
Glad you're okay and that it happened at very low speed...
Anybody have any idea if this is one of the parts that Toyota carried over in the redesign from the T100 to the Tundra?
Old 04-05-2004, 02:57 AM
2000 Toyota Tundra,
Default relay rod
When mine broke i was going very slow but wasn't wheeling it. I just simply went to make a u-turn in a driveway. Little bump Snap No Steering talk about sinking feeling. Any way after inspecting the pieces you could see where 2 little spots of rust had started to form signs of being slightly cracked for awhile I always thought that the incident was related to the 33" tires. The new relay rod I installed was slightly thicker and slightly longer. hope this helps
F.T.F.
Old 04-29-2006, 05:42 PM
Dealer : Big Two Toyota & Scion of Chandler
1996 Toyota T100
Last Online: 04-29-2006 06:05 PM
raorto is on a distinguished road.
raorto's Photo Albums
Default Re: T100 Drag link/Steering relay rod safety related failure *PICS*
Mine just broke the other day, luckly I was just pulled out of a parking lot and heard a couple of bangs about 200 yards later no steering. One thing I noticed just, about a day before the failure was that the steering wheel was coming out of alignment to track straight, at the time I thought I just needed a alignment.
Rich
Old 08-31-2007, 12:24 AM
Dealer : Titus-Will Toyota Sls
1993 Toyota Truck
Last Online: 08-31-2007 12:24 AM
markimusprime is on a distinguished road.
markimusprime's Photo Albums
just got a recall notice "certain 1989 through 1995 model year truck 4wd steering relay rod safety recall follow up notice"
Old 01-18-2008, 11:33 AM
Dealer : Page Toyota
1993 Toyota Truck
Last Online: 01-18-2008 11:25 AM
cbburtraw is on a distinguished road.
cbburtraw's Photo Albums
i just got a notice today from toyota same as markimusprime. also the guy who gave me the truck (this was a few months ago) got the notice like 2 weeks after he gave it to me so he also sent the letter to me. guess its pretty important, it sounds pretty bad. plus i do a lot of effort steering like getting into my very tight driveway spot
what is a steering relay rod? my uncle is a mechanic and he even says he has no clue what it is
