Old 05-13-2004, 01:28 PM
RoundTuit's Avatar
Dealer : Antwerpens Toyota Village
2004 Toyota Tundra,
2000 Lexus RX300
Last Online: 08-12-2008 02:57 PM
RoundTuit is on a distinguished road.
RoundTuit's Photo Albums
Default Transmission ATF Flush vs. Drain & Refill
My wife's RX300 recently turned 90,000 and it is time for a major service. The last time I checked the ATF I noticed that it was getting very dark and was anticipating a complete ATF flush, which would be consistent with the consensus here which seems to recommend a flush every 30,000 miles. I also reviewed the service records and noted that a flush had never been done, so I was certain that would be recommended by the dealership.
I was reviewing the Lexus dealership recommended service items (which, by the way, are more stringent and extensive than those required by the Lexus owner's manual) and noted that the pertinent item simply said "perform automatic transmission service." So, I called the dealership to find out what this really means, and the answer was "drain and refill.". I asked why they don't recommend a complete flush and replacement of the ATF and was told that this may cause problems in a high-mileage transmission since it loosens and moves debris around in the transmission, etc.
Since we don't have our vehicles serviced at the dealership anyway, I called our independent mechanic to find out what his recommendation was, and got much the same story -- i.e., this can dislodge metal particles that can get stuck in solenoids, etc. His practice is to inspect the ATF at frequent intervals and to drain and refill as necessary to keep the ATF healthy.
With so much discussion on this forum about flushing, I was surprised to hear this, but perhaps it makes sense. Just wondering what your thoughts are.
Old 05-13-2004, 05:47 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
They are right, especially if a solvent-type quickie cleaner product is used before the transmission flush. I have not heard of any problem caused by using www.auto-rx.net for a slow, complete transmission cleaning before a complete flush--I've done it myself with good results.
I've had very good results using www.auto-rx.com to clean a high-mileage engine.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 07-01-2008, 04:57 AM
2007 Toyota Yaris
Last Online: 11-27-2008 07:52 AM
anna_bell is on a distinguished road.
anna_bell's Photo Albums
Default Flush - HELP!
Hi,
I'm new here, i really need some help.
According to my mechanic, my Yaris needs an engine flush, i read a few articles that say this is not recommended, for example -
Flush engine - transmission - FixYa
I don't know what to do, I'm sure you guys have the knowledge & experience to help me, please give me advice.
Thank you so much,
Anna
Old 07-01-2008, 05:10 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
Default Re: Transmission ATF Flush vs. Drain & Refill
None of the car makers recommend using engine oil additives or engine cleaners. Example: Honda Owner Manual: http://i5.photobucket.com/albums/y18...ech/accord.jpg
If you change the engine oil every 3000-5000 miles or 6 months, the internal engine parts will stay clean for unlimited years and miles. Here's proof:
http://i5.photobucket.com/albums/y18...ch/conv18r.jpg
Old 07-01-2008, 09:09 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra AC V8
Last Online: 10-10-2009 09:59 PM
Tones is on a distinguished road.
Tones's Photo Albums
Engine flushes are usually a scam. Your engine just needs regular oil changes. How many miles are on your vehicle? Why does he recommend the flush? Does he think you have sludge?
