Old 05-18-2004, 08:45 PM
WillardBubby's Avatar
Dealer : Maplewood Toyota
2006 Toyota Tacoma V6 DC TRD Off Road
Last Online: 10-02-2009 06:13 AM
WillardBubby is on a distinguished road.
WillardBubby's Photo Albums
Question Spark plug replacement for '03 V6
I have a 2003 Tacoma V6 4x4 and I was wondering which spark plugs you guys use. I just bought some Bosch +2 plugs, but I've heard that most of the Japanese vehicle respond best with NGK's.
Does anyone have experience with the Bosch +2's?
I know the truck uses dual ground electrode plugs and I thought that these would work well.
Any suggestions?Recommendations?
Old 05-19-2004, 08:58 AM
Dealer : Toyota of Nashua
2006 Toyota Tacoma
Last Online: 06-25-2009 09:28 PM
RagerXS is on a distinguished road.
Send a message via AIM to RagerXS Send a message via Yahoo to RagerXS RagerXS's Photo Albums
Default Why the Change??
What is wrong with the OEM plugs? I'm pretty sure they are NGK's from the factory...
Contrary to marketing hype, you aren't going to see improved HP or fuel economy from a spark plug change unless the ones you have are either bad or fouled.
~ Fred
"Beware he who would deny you access to information, for in his heart he dreams himself your master."
Old 05-19-2004, 02:26 PM
1999 Toyota Tacoma
Last Online: 07-21-2009 02:35 PM
grillmasterp is on a distinguished road.
grillmasterp's Photo Albums
I'd stay away from the Bosch plugs- (especially the +4's)
They aren't worth the extra money-
Don't last as long as they are advertised-
Don't really offer any added benefits over the OEM's
Just stick with the OEM/ Densos (dual prong )
Old 05-19-2004, 02:29 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
I agree with this:
The last set of those plugs i removed from a toyota, i also had to replace the coil packs. they were melted. Toyota has a patent on the heat range of their spark plugs. That why it is best to use OEM (NGK/DENSO) plugs. Or switch to the recommended IRIDIUM plugs. They work best with a 160 TRD thermostat.
and/or a S/C.
Old 05-29-2004, 04:11 AM
Crazychopstick's Avatar
Dealer : Mitchell Toyota
1997 Toyota 4Runner
Last Online: 09-18-2007 12:40 PM
Crazychopstick is on a distinguished road.
Send a message via AIM to Crazychopstick Crazychopstick's Photo Albums
Do the Densos(dual ground electrodes) need to be gapped?
If so, then how?
Thanks, Chris.
Old 05-29-2004, 04:13 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Default Gap
No they come pre gapped. If ya drop it, just be careful to try to regap it.
Old 05-29-2004, 04:32 AM
1997 Toyota 4Runner
I own a V6 Tundra and I bought some Denso coppers from Autozone for about 10$ and my local Toyota dealership claimed I had to gap them.
Toyota also said I should buy their set(6) instead, for 16$ because only theirs were pre-gapped.
What the heck?
Old 05-29-2004, 09:09 AM
1999 Toyota Tacoma
If so, then how?
Thanks, Chris.
THey are supposedly Pre-Gapped and are boxed with a plastic sleeve protector.
HOWEVER!, I still check the gaps before I install them to make sure- I have found some miss gapped even from the factory-
-How much extra work is it really? And the guage is only about 5 bucks.
For the dual electrodes - I check between the tip of the center to EACH of the side/dual electrodes.
Old 05-29-2004, 08:47 PM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX,
2009 Toyota Camry HV (wife's car)
Last Online: 10-04-2009 05:29 PM
THarms is on a distinguished road.
THarms's Photo Albums
I just replaced mine in my T-100 a couple weeks ago with the OEM Toyota Dual Grounds. 4 of the 6 plugs out of the box were gapped considerably of spec.
On a related note, the oem plugs I took out only had about 25K miles on them and looked pretty bad. All had pitted/burned electrodes which caused extremely wide gaps (no wonder it wasn't idling good and hesitated when accelerating!!). Owners manual says to replace at 30K miles, based on this, I will be atleast checking (and probably replacing) much more often.
Old 05-30-2004, 12:28 PM
bz999's Avatar
Last Online: 04-14-2005 11:45 PM
bz999 is on a distinguished road.
Send a message via AIM to bz999 bz999's Photo Albums
Default Denso IK20's @ .0032" for stock setup!
I have no major engine modifications. I have TRD exhaust and am debating on whether or not to get TRD headers. I am at around 26k miles and was wondering if I should start paying attention to my plugs. I noticed that the Supercharger/7th package recommends using:
TRD PART: 00602-17620-262 Denso IK20 @ .0032"
Could I use those same plugs in my truck with my current setup .. or is that a big "no no"
I was thinking about putting in the TRD thermostat, TRD A/T cooler, and the plugs mentioned above and eventually adding the headers near the end of the summer!
>> I will get picks of my truck up sometime this weekend.
Matt
2003 SR5 Tacoma Double Cab
TRD Exhaust, TRD IS Wheels, SnuglidSL, Intake-Elbow Mod, K&N drop-in Filter, Sylvania SilverStars (PIAA's are better), GrillCraft Grill, Tinted Windows, Dynamat'd doors, Red Painted Calipers.
PURCHASED AT CARSON TOYOTA IN NOVEMBER 2002.
Moved from Anaheim Hills, CA to Austin, TX in September 2003.
Old 06-06-2004, 08:26 PM
1997 Toyota 4Runner
What kind of gauge tool do you use?
