Fuel Filter Location ???
+ Reply to Thread
Results 1 to 11 of 11
Thread: Fuel Filter Location ???
  1. #1
    Junior Member mit42ls is on a distinguished road. mit42ls's Avatar
    Join Date
    Mar 2004
    Location
    Cameron, NC
    Age
    34
    Posts
    99
    Liked
    0 times
    Rep Power
    10
    Default Fuel Filter Location ???
    I wanted to change my fuel filter out but I dont know if Im just blind or what. I tried looking for it on the firewall since that were the fuel filters are for all my other cars but didnt see it. Need help locating it, anyone know where it is ???
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member fooddude is on a distinguished road. fooddude's Avatar
    Join Date
    Apr 2004
    Location
    Orange County, CA
    Posts
    265
    Liked
    0 times
    Rep Power
    10
    Haven't checked myself...but try following the fuel lines coming from the fuel rail, injectors, fuel pressure regultor, etc.
    Get down, Do you?
  4. #3
    Supporter MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally has done just about everything...and then some. MustangSally's Avatar
    Join Date
    May 2001
    Location
    Over Yonder
    Posts
    955
    Liked
    2 times
    Rep Power
    1070
    Quote Originally Posted by mit42ls
    TUNDRA FUEL FILTER V8 PART NO. 23030-62010 (small no maintenance item located under the fuel injection system at the intake manifold-small one at the engine under the intake that is extremely difficult to get to)
    FUEL FILTER (located on the driver's side frame rail under the cab near the driver's door-inline filter on the frame rail-NAPA direct replacement for the stock filter (approx. $20 - dealer $40)
    ~MS
    ~~MustangSally~~
    2001 Tundra Limited
    TRD 4x4
    Imperial Jade Mica/Thunder Gray Metallic
  5. #4
    Join Date
    Mar 2004
    Location
    Cameron, NC
    Age
    34
    Posts
    99
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Thank you very much, that was exactly what I needed to know.
  6. #5
    Veteran Member mitchr is on a distinguished road. mitchr's Avatar
    Join Date
    Feb 2002
    Location
    Kingsport, TN
    Posts
    640
    Liked
    0 times
    Rep Power
    12
    What is the recommended maintenance interval on the fuel filter?
  7. #6
    Leader of Group Evil DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven wants you off his porch. DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    47 times
    Images
    22
    Rep Power
    34450
    recommended maintenance, or realistic maintenance? realistically, consider changing it at 90k, maybe. also, i think theyre under 10 bucks at autozone...kind of a pain to change actually.
    -s
    GFX by FreedomEagle50
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  8. #7
    Supporter akauth is on the right track.
    Join Date
    Feb 2002
    Location
    Silicon Valley, CA
    Posts
    1,803
    Liked
    0 times
    Rep Power
    13
    Quote Originally Posted by DevinSixtySeven
    -s
    Technically, you should pull the pump fuse and then run the engine to bleed the pressure out of the fuel line. That's the right way to do it. After that it's easy to disconnect and it's very accessible on the inside of the frame rail, driver side, right about where the box meets the cab. Climbing underneath you can't miss it.
    Realistically, wrap an old t-shirt or towel around the hose ends and then loosen the fittings. Gas will *definitely* squirt out though!
    The second choice is NOT the CARB compliant choice though but it is easier and slightly messier. Obvoiusly, be careful with the flameable materials.
    Maybe you can use the gas soaked rag to clean something greasy and messy if you think about it. Though gasoline, again, is not an approved solvent due to the flameability. But it works great!
    Alan
  9. #8
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    10,421
    Liked
    47 times
    Images
    22
    Rep Power
    34450
    gasoline is GREAT stuff for gleaning packing grease off old guns.
    the first method works fine, i think that's actually what i did, or something similar. anyway, i ran it til the engine stopped, then disconnected the fuel filter. a little gas will still dribble and make a mess, since the filter will be full, so use gloves or something. squirting gasoline and gas vapors are no joke! wrapping the filter is a good idea, i didnt do that myself, just used a catch pan, the wrap is a better idea.
    putting it back together is a pain, youll see, and theres really no good way to describe the process...just fiddle with it. when youre ready to tighten it down, get it snug, then as thunder grey tundra put it, "crank the crap out of it" (i send him a pm a while back asking for help cuz mine leaked at first).
    -s
    Manual Hubs
    OB's cup size: 36DD
  10. #9
    Junior Member m0000 is on a distinguished road.
    Join Date
    May 2003
    Location
    Denver, CO
    Posts
    315
    Liked
    0 times
    Rep Power
    11
    So there is a 2nd filter under the intake manifold? (am I reading this threat right?)
    How would I have ever known that? Should I get the factory manuals?
  11. #10
    Lurking Member blehr is on a distinguished road. blehr's Avatar
    Join Date
    Jun 2009
    Location
    westminster
    Posts
    20
    Liked
    0 times
    Rep Power
    4
    Default Re: Fuel Filter Location ???
    Are there 2 filters? Change them both, wich one is most important?
  12. #11
    Rookie paulkyoko is on a distinguished road.
    Join Date
    Apr 2010
    Location
    Newport News, Virginia
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    How often should I change my fuel filter
Posting Permissions
  • You may not post replies
  • You may not edit your posts
