Old 07-13-2004, 07:33 PM
Dealer : Toyota of Glendora
2004 Toyota Tundra
Last Online: 04-03-2008 09:06 PM
cuball is on a distinguished road.
cuball's Photo Albums
Default Limited slip diff with 15" spare tire
I'm running 20" wheels on my truck. If I got a flat tire could I use the 15" spare tire on the rear sidewith a limited slip diff? Or do I have to run the 15 up front to prevent dammage to the drivetrain.
White 04 D-Cab Limited. DVD, moonroof, TRD, leather, heated seats, tow package, bed extender, overhead temp/comp, 20" crome Boss wheels, 275/55 Goodyear Eagles, Navigation.
Old 07-13-2004, 08:20 PM
BraneDead's Avatar
Dealer : Laurel Toyota
2002 Toyota Tundra
Last Online: 10-07-2009 09:34 PM
BraneDead is on a distinguished road.
BraneDead's Photo Albums
If your outer diameter is the same on the two tires, then you are straight. Otherwise, the spare with the smaller outer diameter has to go up front.
Black '02 Tundra TRD Limited 4wd
315/75r16 Nitto Mud Grapplers - 16x10 Mickey T Classic IIs - Teamwest/Camburg Coilovers - Total Chaos UCAs - Bilstein 5100 rear shocks - PA 3" Body lift - AEM intake - TRD Headers - JBA Y-pipe - Flowmaster American Thunder catback duals - XM Commander - Line-X UTR
My other ride: 2006 Honda CRF 250R
Old 07-13-2004, 08:42 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 10-01-2009 03:29 PM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
I'd consider your spare a limp along. Even if the outer dia is the same, with the differing wheel dia, the weight distribution may not be the same.
You should consider getting a 5th as a spare, then you have an extra tire to use when you rotate the tires, or for emergency use
Old 07-13-2004, 08:43 PM
TMS2U's Avatar
Moderator
Oh yeah, I think you meant 16" wheel
Old 07-14-2004, 01:15 PM
2004 Toyota Tundra
No my truck came with the old school 15" alloys. I haven't checked the spare yet, I'm assuming its also 15". I know its a steel wheel.
Old 07-14-2004, 01:19 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
15" wheels don't fit any of the tundra models. All models(00-03) came with 16". 04 models come with 17" and definitely not 15".
Mike
http://dyogim.blogspot.com
Old 07-15-2004, 03:54 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Last Online: 05-04-2009 09:43 AM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
I don't think you'll damage the drivetrain, although while running different size tires on the axle with the LSD you will wear the clutch packs excessively. Consider it as the other member said a 'limp along' but if you can get a full size spare (outer diameter) do it. It doesn't have to be the same tire, in fact--you can go with a cheapie for the spare if necessary. If the outer diamter of your wheels is 31" for example, get a 31" spare.
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/LockRightInstall.pdf
2000 Tundra with 175,000 miles and still going!
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
