Resetting Check Engine Light
+ Reply to Thread
Results 1 to 8 of 8
Thread: Resetting Check Engine Light
  1. #1
    Lurking Member garys2 is on a distinguished road.
    Join Date
    Jun 2002
    Location
    Stoughton, MA
    Age
    59
    Posts
    20
    Liked
    0 times
    Rep Power
    11
    Default Resetting Check Engine Light
    After I got gas the other day my Check Engine light came on. It didn't take me long to figure out that the gas station guy had forgot to put the gas cap back on. I ended up buying a new one and put it on. The Check Engine light is still on. Will this reset itself after x amount of engine start cycles, do I need to take it to the dealer to have them reset it with a scan tool, or is there another way to do this.
    The truck is a 2001 Tundra V8 2WD. If that makes a difference.
    Thanks,
    Gary
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Joe
    Joe is offline
    Veteran Member Joe is on a distinguished road. Joe's Avatar
    Join Date
    Feb 2002
    Location
    South of Winnipeg
    Posts
    545
    Liked
    1 times
    Rep Power
    12
    It should reset itself after a couple of starts. Mine reset itself after 45 minutes of driving. The faster method is to disconnect the negative cable from your battery - I don't know if there's a time element involved but I wouldn't think you would have to wait more than 5 minutes before you reconnected the cable.
  4. #3
    Join Date
    Jun 2002
    Location
    Stoughton, MA
    Age
    59
    Posts
    20
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Thanks. It hasn't reset yet, but I'll wait a few days. I don't think it's anything but the lack of a gas cap. At least I hope not.
    Gary
  5. #4
    Supporter THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms's Avatar
    Join Date
    Nov 2003
    Location
    KS
    Posts
    540
    Liked
    0 times
    Rep Power
    32
    yep.. just disconnect one of your battery terminals for 15-min... unfortunately you will lose your radio presets as well though.
    Alternative is to borrow/buy an ODB reader (they loan them out at our local Autozone). Most of these readers have a reset button that allows you to reset the computer electronically.
  6. #5
    Join Date
    Jun 2002
    Location
    Stoughton, MA
    Age
    59
    Posts
    20
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    The light reset this afternoon. I think part of my problem was that I use the remote start most of the time. That might not count as a key turn. So, I just started to use the key and after a few starts the light went out.
    All is well.
    Gary
  7. #6
    Junior Member woody1 is on a distinguished road.
    Join Date
    Feb 2002
    Location
    San Diego, CA
    Posts
    343
    Liked
    0 times
    Rep Power
    12
    Duuuuuh, I just had the same problem.
    Forgot to put on gas cap and the CEL came on. Bought new cap; called service advisor who told me it was proably the missing cap causing the CEL and would cost $75 to scan and reset. After two days it reset itself. Thanks guys.
  8. #7
    Junior Member lunagr is on a distinguished road. lunagr's Avatar
    Join Date
    Jun 2004
    Location
    Big Bear Lake, CA
    Posts
    248
    Liked
    0 times
    Rep Power
    9
    Exclamation Eeek!
    Quote Originally Posted by woody1
    ..called service advisor who told me it was proably the missing cap causing the CEL and would cost $75 to scan and reset...
    Which dealer was that? (you might just want to hint rather than name 'em). I just might want to avoid that one...
    Steve
    "I don't understand everything that I know about it"
  9. #8
    Rookie jaybird141 is on a distinguished road.
    Join Date
    Aug 2006
    Location
    Bay area, CA
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Re: Resetting Check Engine Light
    75 bucks, wow! I borrowed my buddies $40 dollar tester for free.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
