This is a discussion thread titled "Changing Shift Points", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-17-2004, 01:45 PM
Dealer : Wilson Oldsmobile Cadillac Toyota
2004 Toyota Tundra
Last Online: 02-17-2006 05:36 PM
knutson is on a distinguished road.
knutson's Photo Albums
Default Changing Shift Points
does anybody know if you can change the shift points of the a340e. ie,through the ecu...i have an 04 tundra and i like the way it shifts from 1-2,2-3 when it's cold...it's real fast (low rpm change) and smooth. then of course when it warms up it's back to normal..(harder shifts and higher rpm levels).
Old 08-17-2004, 02:06 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
Last Online: 10-12-2008 11:01 AM
RockyMtnRay's Photo Albums
Possibly. One member has claimed that Jet Performance has cracked Toyota's proprietary programming code for the ECU...and could therefore theoretically reprogram the transmssion shifting. Many other members have expressed a lot of doubt about whether Jet actually has cracked the ECU code, and if they have, how good a job they're doing of reprogramming the ECU. If you go this route, you'll be a pioneer venturing into basically unknown territory. Let us know if you do and how well it works out for you.
The reason the ECU shifts as it does is to minimize emissions when the engine is cold.
Ray
Old 08-17-2004, 02:20 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Today 03:11 PM
DevinSixtySeven is a splendid one to behold. DevinSixtySeven is a splendid one to behold.
the shift parameters (rpm and vacuum) are posted in the garage, might make a good starting point.
GFX by FreedomEagle50
Manual Hubs
Old 08-17-2004, 04:53 PM
2004 Toyota Tundra
not sure what u mean by this...please advise...
Old 08-18-2004, 08:52 PM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
I've read on TS that the change in shift points is controlled by a temperature sensor. The temperature sensor can possibly be "tricked" by inserting a resistor in the circuit. If that works, some of the downside might be continued "open loop" operation (with poor mileage) and increased wear on the tranny due to the soft shifts. If you get really good with your right foot, you can pretty much tailor the shifts yourself.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 08-19-2004, 03:23 PM
2004 Toyota Tundra
i believe u r absolutely correct in that it is controlled by a temp sensor,only when the tranny is "cold" does it shift smooth and at a very low rpm range-it's like 1-2 2-3 r right behind each other.what would happen if i disconnect(can you even) or elimanate the sensor alltogether.or is that a no-no..
Old 08-20-2004, 01:18 AM
Dude Boy's Avatar
2000 Toyota Tundra,
My understanding is that the soft shifts are the result of the computer reducing the line pressure in the transmission. If you ran it that way all the time, the life of the clutch packs would be shortened. I think it's best for the tranny to just get used to it and live with it. If you search for posts by Mudog715 containing the word transmission, you should find some info on how the transmission is controlled. He has modified his truck to give softer shifts while in 4WD LO, by disconnecting the sensor that determines when low range is selected. You might even be able to email him or send a PM, but I don't believe he has been active on TS for a year or so.
Bookmarks
