Old 08-26-2004, 10:30 PM
Tarpon's Avatar
Dealer : Cloninger Toyota
2006 Toyota 4Runner,
2002 Toyota Tundra
Last Online: 08-15-2007 08:57 PM
Tarpon is on a distinguished road.
Send a message via AIM to Tarpon Tarpon's Photo Albums
Question Tell me about lockers
I hear all this great stuff about lockers and LSD's. I love offroading and am mainly on muddy trails down here in the south. What exactly will a lockker do? Can they be automatically or manually turned on and off. Will a locker or LSD be more beneficial? I'd say 1/4 of the time I'm offroad and plan on modding more and more to become a more serious offroader. Thanks for the info. - Ben
2001 Silver Tundra SR5
Mods:slimline ventvisors, TRD dual exhaust, TSC Toolbox, Protech 1" diff. drop spacer, Protech EZlift 2.5 in spacers, wheelers AAL, Extreme Alloy 1879 wheels, 285/75/16 Procomp Xterrains, Powertrax No-Slip, Hi-Lift Jack
Future Mods:Daystar 1 inch body lift, TeamWest coilovers, Camburg Uniballs, 4.56 gears, underdrive pulley, skidrow plates
Old 08-26-2004, 11:01 PM
Genthar's Avatar
Last Online: 11-05-2009 09:51 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
Check the offroad forum faq...has a lot of good information for offroaders.
Genthar
Old 08-27-2004, 10:33 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Definitely check out the offroad forum. In any case if you are going to be in mud a lot, a locker will do better hands down. As far as being turned on and off, ARB makes one. For a full time locker, you can get a Lockright Locker or The Powertrax. The powertrax is pretty much exactly like the lockright. However, there's a mechanism that cuts out the "click, click,..." in the locker when turning corners. I have the Lockright and it is easy to install yourself. It was affordable and does it's job offroad. A locker will send equal amount of force to each side of the tire all the time. If you are going around a corner, the locker will disengage and that's why you hear the "clicking" sound but, if you are on the gas around the corner, the locker will stay engaged. A bit scary when you are on pavement.
Mike
http://dyogim.blogspot.com
Old 08-27-2004, 04:22 PM
fooddude's Avatar
Dealer : Power Toyota Irvine
Last Online: 07-01-2006 03:36 PM
fooddude is on a distinguished road.
fooddude's Photo Albums
Just curious, will the electronic locker 3rd member from the Tacoma prerunner work/bolt-on to a Tundra rear-end?
Get down, Do you?
Old 08-27-2004, 04:34 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Not sure! I've wondered that as well. I don't see why it wouldn't. The rear ends are the same, except the tundra is wider.
Mike
Old 08-27-2004, 08:10 PM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
I think I read somewhere that the rear ends were different between the tundra and tacoma. Which would make sense since the locker is not an available option for the Tundra.
Ill see if I can find it again and post.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
Old 08-27-2004, 10:00 PM
Dealer : Poway Toyota
2004 Toyota Tundra
Last Online: 03-06-2009 10:15 AM
dezert_rida is on a distinguished road.
Send a message via Yahoo to dezert_rida dezert_rida's Photo Albums
Default Some facts about rear ends
No, the Tacoma TRD electric diff is not interchangeable with the Tundra housing.
TRD Tacos use 88-95 V6 8" ring gears.
Standard Tacos use the larger 210MM diffs like our Tundras. Those diffs swap between the two trucks with the difference being the housing and shafts on the Tundra are wider.
The driveline shop i dealt with had never done a Tundra rear end before, but they have now! I got one regeared, locked and new bearings put in it for $880 with tax parts and labor. Thats with me supplying the diff obviously.
The Tundra diff has no threaded adjustments to move the ring gear to and from the pinion gear. You must use shims to adjust that, which makes the labor costly. The bearings are also expensive.
