Castrol Oil 10w-30 here for the Warm South Texas weather which is almost year round. As for filter choices? They're limited and usually purchase a Wicks, I think thats how its spelled, as my oil filter. Its either that or Fram which I refuse to buy.
So far I've got about 20k miles and I've been changing the oil every 3k miles.
2003 White Tundra Sr5 v8
-stock for now.
Also not switching to syn oil untill it is broken in is an old wives tail. Syn oil is good, but you engine is still going to wear in or break in. Syn does not stop all wear.
Toyota suggests that if you change to synthetic wait until you have surpassed the first recommended change - 5000 miles for proper break in of seals, rings, etc. Synthetic oil reduces wear by a factor of 4.
I changed the factory fill at 1000 miles to Castrol GTX 5W-30, did an additional change at 2500 with GTX and moved to Mobil 1 SuperSyn 5W-30 at 5000. I use Toyota, Purolator PureOne or Bosch Premium filters.
I have Amsoil Synthetic 75W-90 (w/ BG LSII limited slip additive) in my LSD. Mobil 1 Synthetic ATF in the power steering and change out 4 quarts of Toyota T-IV in the tranny every 15,000 miles. OK, so maintenance is a hobby!
You will void your powertrain warranty if you exceed 7500 miles between oil and filter changes. After the warranty expires...the interval is up to you!
Although intuitively it would seem that the salesman should know what he is talking about, for the most part this will never be the case. There is no reason to leave factory oil in for any amount of time.
Synthetic doesn't stop wear but it does slow it down a lot. Even Redline oil engineers (which is probably one of the best oils ever - it's just so darn expensive) recommend that you wait to put their synthetic in unless the engineers designed for OEM fill with synthetic.
On a diesel the break in is even more important because of the high compression. There you should wait until about 10,000 miles and then practically stop future wear with synthetic.
You are right it WILL break in anyway, but it's going to take longer than it should if you put synthetic in too soon. Your fuel consumption levels out earlier if you wait.
You will void your powertrain warranty if you exceed 7500 miles between oil and filter changes. After the warranty expires...the interval is up to you! Brad
Not exactly. If you exceed 7500 mile oil drain interval and have an oil related problem, yes, that warranty claim will likely be denied. If you have good oil analyses beyond 7500, you have shown that the oil was still good. You have protected your warranty. They can't get away with denying the claim in that case. They can't "void the powertrain warranty" on the transmission, differential, and other none-engine powertrain parts because of engine oil changes.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Oil is the second cheapest fluid you put in your vehicle next to gasoline. Why try to push the envelope? If you are keeping your unit for an extended period of time it's a no brainer.
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
I run the cheapest "known brand" oil i can find which is Chevron Supreme, ~~ $12 per case of 12 at COSTCO. The Hornet is pushing ~ 112,000 miles, no engine probs as of yet.
Cheers,
-RH
Toy Truck owner since 1975.
~~ 900,000 total Toy miles to date with no engine probs except the head gasket recall on our 1991 [ truck & 4Runner ] V6's.
Your right. Look at the high end vehicles that come with synthetic from the factory. If it retarded engine break in, they would not put it in as a factory fill.
Motor Oil
The myths, facts, and mysteries of the slippery stuff that keeps your engine happy.
By Gordon Jennings, Originally published in Motorcyclist, October 1996
Here's the bottom line when it comes to motor oils: you really cant go wrong by following the recommendations given in your owner's manual. Your motorcycle's maker has dyno-tested its engine with a crankcase full of the specified oil, or one with the same American Petroleum Institute (API) rating. You can be sure that particular oil will do the job. Will it do the job better than any other oil? Will it do the job if the engine is no longer as its manufacturer made it? Not Necessarily, as you will learn by reading further.
The API's ratings once went from 'SA' (guaranteed to be oil) through the alphabet to 'SE' and was extended to 'SE/CC' (you cant drive a nail through a film of this stuff.) Today the API has fewer performance grades, only 'SH' and 'SG' for spark-ignition engines, with an 'SH/CD' rating for oils good enough to be used in passenger-car diesels. The motor oils bearing these API markings have been test-certified for today's engines, which are in turn constructed with these oils in mind.
You should be aware that motor oils are now being compounded not just for lubrication, but to improve fuel economy as well. Oils have always been compounded with a thought for fluid drag; this is the first time its been made a priority. The API has two economy ratings: "energy conserving" for motor oils that yield a 1.5% reduction in fuel consumption as compared with a reference oil; "energy conserving II" is an oil that provides a 2.7% drop in fuel consumption.
As you might expect, energy conserving oils drag reduction benefits also show up as increases horsepower. Both thermal and mechanical losses diminish the power liberated in the combustion process on its way to the output shaft. The work of pumping air in and out of the engine accounts for the majority of the mechanical losses. The rest is mostly lost to fluid drag on the piston, which is, all other things being equal, largely a function of oil viscosity.
Friction exists even in the absence of actual contact between opposed surfaces. The cylinder wall's oil film normally prevents it from being touched by the piston, it is a source of friction itself, if we take that to mean a resistance to relative motion. Millions of molecules on each side of the gap try to stick together and get pulled apart. The sum of millions of molecule's minute resistance to separation comprises viscous drag, the source of most friction in a running engine.
Viscosity aside, the most important property of an oil is that it be "oily." Introducing any liquid between a piston and cylinder wall, for example, will reduce friction between the two surfaces. The degree to which friction will be reduced is, broadly speaking, a function of the liquid's viscosity. But maple syrup and motor oil of essentially identical viscosity do not lubricate equally, as you discover by rubbing samples of each between thumb and forefinger.
If "oiliness" were the only quality to be considered in choosing motor oils, we'd be squeezing all ours from castor beans. Castor oil, the smell of which once perfumed the air at motor races, is the oiliest of oils and it remains in some respects the supreme lubricant. It does oxidize too readily, however, forming ring-sticking gums and varnishes, and daubing fouling deposits on spark plugs. In a running engine, castor oil goes right to work gluing piston rings in their grooves and slathering gum and varnish everywhere. You wouldn't want it in any engine that can survive without its help.
But castor oil, a mixture of ricinoleic and triricinoleic glycerides, plus 10-12% of other fatty acids, remains one of the best lubricants for 2-stroke racing engines. Castor oil clings to metal with such tenacity it cannot be removed except by machining. It is an exceptionally effective film lubricant.
Oil forming a hydrodynamic wedge between surfaces keeps pistons and bushing-type bearings from metal-to-metal contact. Viscosity pulls the oil between a moving piston and its adjacent cylinder wall, or a shaft and a bearing, and pressurizes the gap. The pressure increases with viscosity and speed, and a well-designed engine almost totally prevents scrubbing contact.
The qualifying "almost" is needed because hydrodynamic action is not present in an engine at start-up, and it collapses around the pistons and rings at the end of their strokes. Under these conditions, parts are protected only by film lubrication, which is provided by the dipolarity of the oil molecules. The molecules behave like tiny magnets and adhere to ferrous metals and each other.
One of the great improvements in motor oils came circa 1950, when when the detergent/dispersant additives developed for diesels came into more general use. Alas these brought with them unfortunate consequences for old, high-milage engines. In those, the detergents sometimes dislodged great clots of oxidized oil filth to clog filters and oil passages. Engine failures caused by detritus liberated in this manner put additive oils in bad repute, with the results that some people still buy and use straight non-additive oils.
The first oil additive was probably the spoonful of sulfur old-time truck operators tossed into axle and transmission housings. The sulfur reacted with gear-tooth steel to give the gears an iron sulfide film. The film was important because the relative speeds between meshing gears is too low to form a fluid wedge strong enough to resist the extremely high gear-tooth loads.
Engines also have points at which loadings can exceed the carrying capacity of the fluid wedge. Take the tiny contact area between the exhaust cam and follower, for example. The load there rises to roughly 1500 pounds for every ounce of valvetrain weight at high engine speeds. Full throttle adds 80 pounds of load for every square inch of valve head area, meaning the load focused on the cam/follower can reach pressures in the order of 20,000 pounds per square inch.
Cams would have to spin much faster than they do (half crank speed) to work up a fluid wedge capable of carrying such high loadings. So the job has to be done with film lubrication, which means a more viscous oil, one with special properties (castor) or an extreme pressure (EP) additive. It's obvious that film lubrication is important, where some of us go wrong is in leaping to the conclusion that those who compound motor oils have overlooked this very point.
Dealer's shelves usually have a selection of flasks filled with liquids I like to call "mouse milk." This stuff reduces the friction in your wallet enough to make money slip out of it, but may not do anything else. About the best you can hope from mouse milk is that it will either be more of the same additives already in good-quality motor oils, or at least not get in the way of the additives that can do something useful.
Film-condition additives usually are chemically and/or thermally reactive. The sulfur- and phosphorus-based compounds react with iron to form slippery iron sulfides, as previously noted, or wear-resistant iron phosphides. Fatty acids, like those in castor oils, react with iron to make low-friction iron soaps.
Thermally reactive "liquid metals" like molybdenum dithiophospate, are oil-soluble chemical compounds; molybdenum sulfide, on the other hand, is a cheap dry-slide lubricant sometimes used in greases. If you put MOS or other dry-slide lubricant powders like colloidal graphite in motor oil, these solids may settle or filter out. Worse, they may become a barrier blocking the more effective reactive additives.
The liquid metals dissolve in oil, like salt in water, and remain in solution at all normal engine operating temperatures. But when friction heats the liquid metal compounds they come apart and their metallic component is plated on the hot spot. This stops the most potent, least obvious wear process in today's filter-protected engines: direct, scrubbing contact between a cam and follower, gear teeth, etc. This contact results in wear largely due to friction welding: Friction melts pinpoint areas of metal on both sides of the contact area, and they weld themselves together. These minute welded particles then break away, and after enough of them are carried off by the oil, the parts need replacement.
The role of liquid metals--usually molybdenum, tungsten, or zinc compounds--is both to interfere with friction welding, and to sacrifice itself to the wear that would otherwise devour engine parts. Unfortunately, phosphorous compounds degrade catalytic converter performance, so the feds limit the amount of additives like zinc dialkyldithiophosphate in motor oils. But in nearly all instances there is enough to last from one oil change to the next.
In the years before we had effective micron-level air and oil filtering, abrasive engine wear was a problem. The typical spark-ignition engine sucks in 10,000 gallons of air for every gallon of fuel it consumes. If you dont filter that air, it carries grit into your bike's engine post-haste. The larger particles do little damage unless they get caught between a valve and its seat, pitting both severely.
Virtually all dust particles are silica or silicon oxide, an extraordinarily hard substance with plenty of sharp edges. Engines with inadequate (or non-existent) air filters eat a huge amount of this grit. The good news is, most of it leaves with the exhaust gases. The bad news? What does stay can do severe damage, whether its in the wrong place or carried around in the wrong oil.
Modern air and oil filters trap just about everything larger than a micron (1/1,000,000th of a meter, or 0.000039 inch) in diameter. Particles of that size are enveloped by the oil film separating an engine's moving parts. Even a very light oil provides this protection. SAE 5 seems watery, but it has a film depth of not less than 0.001 inch, deep enough to submerge particles smaller than 26 microns.
Abrasive wear was a bigger problem back when the typical motorcycle air filter was a coarse screen capable of stopping nothing much smaller than pea gravel. The old gravel strainers gave free passage to the 20-micron grit that does the worst damage, especially to piston rings.
Fine grit was/is still a great killer of roller cranks. Grit becomes embedded in bearing cages and makes them depressingly effective crankpin grinders. You can prevent this kind of damage by using the thick oils, SAE 30 and above, envisioned and reccommended by the people who built these old engines.
Thick, high-viscosity oils are good for enveloping grit. They also do a great job of sealing and cushioning, which are two important functions of all motor oils (much more 30 years ago than today). The aluminum piston alloys in use circa 1960 had high expansion rates and poor high temperature strength. Accordingly, they needed to be surrounded by thick oil, to seal the fire trying to blow past the generous clearances--and to keep them from rattling in their bores.
Thick oils spread the concentrated loads between roller bearings and their races. The mechanism of rolling-element bearing failure usually is "brinelling," fatigue-related flaking, of the inner bearing race. Under load, the race under the roller (or ball) yields minutely as the bearing turns, just as a paved street yields to the weight of a passing truck. And in time the bearing race, much like the street, begins to break up.
Plain insert-type bearings can also fall victim to fatigue failure. You can bring about their early demise by feeding them a too-thick oil, which will turn into a too-thin oil in the bearing. The oil in plain bearings, whether connecting rod inserts or the floating bushings in a supercharger, is heated by fluid shearing. If the oil's viscosity and bearing clearance are properly matched, there will be sufficient oil flowing past the bearing to keep it cool.
When you pour SAE 40 into an engine designed for SAE 10-30, you may intend to protect its bearings with the thicker oil. But the increased oil viscosity , and resulting reduction of flow, can overheat the bearing. The metals used in plain bearings--copper, lead, and aluminum--typically lose half their ambient temperature strength at 200 degrees F. Copper-lead bearings are stressed near their elastic limit at redline crank speeds, even with crankcase oil temperatures below 250 degrees F. Pour in some thick oil, or a "mouse milk" viscosity index improver, and you'll reduce the bearing's oil flow, which will make it hotter and may cause it to fail.
Engine oils are viscosity-rated by subjecting them to the arcane arts of viscometry at 40 degrees F, then heating them and repeating the test at 210 degrees F. When you see a 10W30 rating on an oil, the "W" means the oil's base stock has actually been tested down to zero degrees F with a cold cranking simulator. It is assumed, for purposes of viscosity, that motor oils are "Newtonian" in that their loss of viscosity with temperature (meaning that their rate of loss is fairly constant.) The rate of loss is given as a viscosity index number, and in this respect some oils are better than others.
Multi-grade oils are made so by chemical additives called "viscosity index improvers." These additives contain either colloidally dispersed long-chain molecules that dissolve into true solution as temperature rides, or spiral molecules that open up and get longer with increases in temperature. Both of these actions "thicken" heat-thinned oil. Add the right VI improver and you get, for example, an oil that tests like SAE 10 at 40F, but looks more like SAE 30 at 210F. A multi-grade oil doesnt thicken with increased temperature, it doesnt thin as much as a single-grade oil.
One thing you should know about multi-grade oils is that their VI-improving additives will wear out. You can fool mother nature, but not forever: Long-chain molecules shear apart, so the the 10-30 oil you poured into your motorcycle's engine becomes 10-25 oil after a time, then 10-20, 10-25, right down to 10-10 if you cover enough miles between oil changes.
Over the last couple of decades we have seen the rise of "synthetic" and "synthetic blend" base stocks in motor oils. The big difference between plain old refined oil and synthetic is the the latter is, well, synthesized. When crude oil is refined, it is effectively sifted. The SAE 30 base stock you get in the sifting operation represents an average of molecule sizes, some being larger and others smaller. Shearing in a running engine breaks the big molecules apart faster than the little ones, which reduces the average size of molecules in the oil and thins it.
In contrast, synthetic base stocks' molecules are uniform in size, having been assembled out of fragments in a molecular stew. Synthetic oils also contain none of the waxes that can block low-temperature flow, and none of the instant-sludge crude-oil cruds or aromatics that vaporize and drift away the first time a spark plug fires anywhere near them.
I was not impressed by some of the early synthetic motor oils, which were compounded using cheap glycols as a base. Union Carbide's polyalkylenes oozed past gaskets and seals, some others synthesized from gases returned to gaseous form in the hot engine environment.
The better synthetic base stocks in use today are record-holders on the viscosity index scale. They still need a good squirt of VI booster to qualify as multi-grade oils, but they need less of it than refined base stocks. This is important, as polymeric viscosity index improvers' long molecules are unstable in shear. The less help your SAE 10W30 motor oil needs to meet its high temperature obligations, the longer it will be effective.
Good synthetic motor oils also have better non-newtonian, "apparent viscosity" behaviors. Oil displaying these "kinematically diminished" properties behaves like a thinner oil when rubbing speeds are high enough to build a thick fluid wedge.
Which synthetic oils are best in terms of apparent viscosity? I dont know, and neither does anyone who lacks a laboratory full of expensive, complicated equipment. I also dont know which additives, or how much of each, is present in the containers of motor oil--refined or synthetic--you'll see displayed at dealerships, service stations, and the like. That information is a closely held trade secret.
So after all this talk of motor oils, how do you tell good from bad? The bottom line here is, you buy the label on the container; you buy reputation. When you see a plastic bottle labeled "zowie lube," with small print that says it was packaged by "O'grady's Motor and Hemmroid products," put it back on the shelf and reach for something familiar. When I tell you to buy name-brand products, I'm not just sucking up to this magazine's advertisers.
Castrol is not an advertiser, but I will tell you the company has been making motor oils since we've had motors and I dont think it would knowingly sell you anything that would tarnish it's good name. I've used Castrol's motor oils for both racing and street applications, without disappointment. Refined-based GTX, sold super-cheap at supermarkets everywhere, is a very good motor oil and may be better than some higher-priced synthetics.
Mobil, which is an advertiser, long ago began developing synthetic motor oils and put its considerable technical resources to work creating a good one. They came up with Mobil 1, an oil using mostly polyalphaolefin base stock reinforced with a big percentage of polyol ester, the latter being an especially good lubricant in its own right. Mobil 1 probably is today's best widely-available motor oil. As a result of prepatory research I have done prior to writing this article, I bought (yes, bought!) Mobil 1 for use in my own vehicles
Red Line, an advertiser, is making a name for itself as a source of all-synthetic motor oils, and this company, like Mobil, relies on big percentages of polyol esters in its base stocks. My contacts in two- and four-wheeled racing tell me Red Line's oils are producing excellent results in everything from NASCAR's stockers to motorcycle GP racing's shrieking 2-stroke engines.
Keep in mind that your motorcycle was extensively tested with its cavities full of the lubricants specified by its maker. Motorcycle manufacturers dont test their models on oil specially compounded to keep engines, clutches, and transmissions happy, they instead do the sensible thing and design hardware compatible with the oils they know you'll be able to find. Its the smart thing to do, and it works right up to the point where you ignore their advice.
You MUST HAVE gotten that article out of Motorcyclist Magazine... from the "Tech Guy" (his name slips my mind at present) who has a small column in each months edition!
When I subcribed to Motorcyclist & Sport Rider back in the early 90's (now I'm telling my age ) I read his little "spoofs" each month and ALWAYS... seemed to finish his column... thinking to myself... "what in the hell... did he just say?!" Even wrote in... to the magazine once... for the Readers Column asking for a little more "lay-man's terminology" about an article this guy did on suspension, because after reading his column, that month... I was left... once again... thinking... "what in the hell..."!
Anyway... if it isn't the same guy... then I NOW KNOW... that there's another guy like him... out there... who just simply... talks... "WAY" above my poor "widdle" head!
Dave
__________________ 2004 SR5 Double Cab 4x4 w/TRD Pkg. Mods to Date:
16" 5 Spoke Brawn Enkei Wheels, Keyless Entry, Line-X Bed Liner, Challenger Running Boards, Husky Floor Liners, Bug Flector II (painted to match), Colegan Bra, Borla Dual (Side-Exit) Exhaust System, 2" Wheeler's Coil Lift, TRD Add-A-Leafs Mods to Come:
265/75/16 BFG A/T's, Possible Mods:
Dave
Actually I got this off of "Bob the oil guy's" web site. I believe this is the same guy that you refer to, as he gets into motorcycle stuff at the end of the post. I don't know what his qualifications are, but he makes a lot of good points regarding engine oil.
I think what I took away from the post is the factory engineers design the engine around a certain type and weight of oil. We are always trying to use something WE think is better. Maybe that's not too smart.
Muleskinner,
Lots of good info in that article, some out-of-date stuff, and a couple of errors.
The current ILSAC oil spec is GF-3, and that is in the process of being replaced withGF-4. The current API Service Category for gasoline engines is SL, and that will be replaced with SM around the end of this year. Each newer spec is better oil for better, cleaner engine protection and longer oil life.
"Energy Conserving II" is an obsolete designation.
I like his comment about over-the-counter oil additives reducing the friction in your wallet to allow the money to slip out.
The liquid, oil soluble, invisible moly used in motor oil is molybdenum dithiodialkylcarbamate; the phosphate version is used in some greases or gear oils. I haven't seen any tungsten antiwear or extreme pressure compounds, but have seen some antimony and boron compounds.
Generally, oil one viscosity grade heavier is no problem in most engines. Engines used in many parts of the world have many different oil viscosities specified for the same engine depending on local custom and regulations. In the U.S., the government pressures the car companies to get the best fuel mileage, so we see lots of 5W-30, sometimes 5W-20, specified. Our same 2UZ-FE V-8 engines have 20W-50 recommended for them on Valvoline's Australia's web site, 'cuz that's what folks down there think is the right stuff to use.
Oil viscosities are tested at 40°C (not 40°F), at 100°C, and for the "W" rating, at -25°C for 10W, -30°C for 5W, etc., according to SAE chart J300 http://www.infineum.com/information/viscosity.html There is no testing of oil viscosity at 0°F. So-called multiviscosity oils, 5W-30, etc., are not spec'd or tested at 40°F, they're tested at -30°C and 100°C for the 5W-30.
Ken
Consumer Reports Article
The surprising truth about motor oils
July 1996, pp 10-13
Our 4-1/2-million-mile test with a fleet of New York City taxicabs turned some conventional wisdom on its head.
Mobil commercial claims its oil "has been in more Indy 500 winners than any other oil." Quaker State shows an engine with a terminally corroded inside what they imply could happen when you use another oil. Exxon's commercial for its Superflo oil urges motorists to "rely on the tiger."
Oil companies spend millions of advertising dollars each year to convince you that their oil can make your car's engine perform better and last longer. And purveyors of motor-oil and engine "treatments" assert that their products offer engine protection that oil alone can't provide. In our most ambitious test project ever, we set out to discover whether such claims are fact or fancy.
One way to gauge the performance of motor oils is to test them on the road. We did just that, using a fleet of 75 New York City taxicabs. Indeed, the oil industry itself tests its oils in New York City taxis.
For 22 months, we tested the performance of 20 popular motor oils. Each of those oils met the industry's latest standards, as certified by a starburst symbol on the container. (See "It's not just oil," article 3 of 4.) We also tested Slick 50 Engine Treatment and STP Engine and Oil Treatments.
In addition to the taxicab tests, we had the oils' chemical and physical properties analyzed by an independent lab. We also surveyed our subscribers about their oil-changing experiences and preferences, and we sent shoppers to quick-lube centers across the country to assess the service. Finally, because changing the oil is just one part of car care, we've reviewed some other ways you can help keep your car running longer. That report begins on page 18 (not included in this e-mail).
Testing the oils
We put identical rebuilt engines with precisely measured parts into the cabs at the beginning of the test, and we changed their oil every 6,000 miles. That's about twice as long as the automakers recommend for the severe service that taxicabs see, but we chose that interval to accelerate the test results and provide worst-case conditions. After 60,000 miles, we disassembled each engine and checked for wear and harmful deposits.
Our test conditions were grueling, to say the least. The typical Big Apple cab is driven day and night, in traffic that is legendary for its perversity, by cabbies who are just as legendary for their driving abandon.
When the cabs aren't on the go, they're typically standing at curbside with the engine idling - far tougher on motor oil than highway driving. What's more, the cabs accumulate lots of miles very quickly, making them ideal for our purposes. Big-city cabs don't see many cold start-ups or long periods of high speed driving in extreme heat. But our test results relate to the most common type of severe service - stop-and-go city driving.
Each of the 20 oils we studied was tested in three cabs to provide meaningful test results even if a few cabs fell out with mechanical problems or because of accidents. (Six of the 75 engines did, in fact, have problems, none apparently related to the oil's performance.) For a detailed description of our test procedures, see "Testing in the Big Apple," article 2 of 4.
Our shoppers all across the country bought hundreds of quart containers of oil. Some brands had slightly different formulations in different areas, but all the oils included a full package of additives.
The independent lab helped us identify the most representative formulations of each brand. Our engineers transferred containers of that oil to coded 55-gallon drums and hauled them to the fleet garage for testing.
Ideally, oil should be thin enough to flow easily when the engine is cold and remain thick enough to protect the engine when it's hot. The lab analyses of each oil's viscosity characteristics - its ability to flow-indicate that motor oils have improved since 1987, when we last tested them. This time, far fewer test samples failed to meet the viscosity standards for their grade - and those were typically outside the limits by only a slight amount. No brand stood out as having a significant problem.
We tested oils of the two most commonly recommended viscosity grades - 10W-30 and 5W-30. Automakers specify grades according to the temperature range expected over the oil-change period. The lower the number, the thinner the oil and the more easily it flows.
In 5W-30 oil, for example, the two numbers mean it's a "multiviscosity" or "multigrade" oil that's effective over a range of temperatures. The first number, 5, is an index that refers to how the oil flows at low temperatures. The second number, 30, refers to how it flows at high temperatures. The W designation means the oil can be used in winter.
A popular belief is that 5W-30 oils, despite their designation, are too thin to protect vital engine parts when they get hot. However, one of our laboratory tests measured the viscosity of oils under high-temperature, high-stress conditions and found essentially no difference between 5W-30 oils and their 10W-30 brand mates. But at low temperatures, the 5W-30 oil flowed more easily. Viscosity grade is important, so be careful.
Recommendations vary with the make, engine, and model year of the car, so check your owner's manual and ask the mechanic for the proper grade of oil.
Of the 20 oils we tested, nine were conventional 10W-30 oils, and eight were 5W-30. We also tested two synthetic oils, Mobil 1 and Pennzoil Performax, and one synthetic-and conventional blend, Valvoline DuraBlend; all three were 10W-30 oils.
No brand performed best
If you've been loyal to one brand, you may be surprised to learn that every oil we tested was good at doing what motor oil is supposed to do. More extensive tests, under other driving conditions, might have revealed minor differences. But thorough statistical analysis of our data showed no brand-not even the expensive synthetics-to be meaningfully better or worse in our tests.
After each engine ran about 60,000 miles (and through 10 months of seasonal changes), we disassembled it and measured the wear on the camshaft, valve lifters, and connecting-rod bearings. We used a tool precise to within 0.00001 inch to measure wear on the key surfaces of the camshaft, and a tool precise to within 0.0001 inch on the valve lifters. The combined wear for both parts averaged only 0.0026 inch, about the thickness of this magazine page. Generally, we noted as much variation between engines using the same oil as between those using different oils. Even the engines with the most wear didn't reach a level where we could detect operational problems.
We measured wear on connecting rod bearings by weighing them to the nearest 0.0001 gram. Wear on the key surface of each bearing averaged 0.240 gram - about the weight of seven staples. Again, all the tested oils provided adequate protection.
Our engineers also used industry methods to evaluate sludge and varnish deposits in the engine. Sludge is a mucky sediment that can prevent oil from circulating freely and make the engine run hotter. Varnish is a hard deposit that would remain on engine parts if you wiped off the sludge. It can make moving parts stick.
All the oils proved excellent at preventing sludge. At least part of the reason may be that sludge is more apt to form during cold startups and short trips, and the cabs were rarely out of service long enough for their engine to get cold. Even so, the accumulations in our engines were so light that we wouldn't expect sludge to be a problem with any of these oils under most conditions.
Variations in the buildup of varnish may have been due to differences in operating temperature and not to the oils. Some varnish deposits were heavy enough to lead to problems eventually, but no brand consistently produced more varnish than any other.
The bottom line. In our tests, brand didn't matter much as long as the oil carried the industry's starburst symbol (see "It's not just oil," article 3 of 4). Beware of oils without the starburst; they may lack the full complement of additives needed to keep modem engines running reliably.
One distinction: According to the laboratory tests, Mobil 1 and Pennzoil Performax synthetics flow exceptionally easily at low temperatures - a condition our taxi tests didn't simulate effectively. They also had the highest viscosity under high-temperature, high-stress conditions, when a thick oil protects the engine. Thus, these oils may be a good choice for hard driving in extreme temperatures.
Note, too, that a few automakers recommend specific brands of motor oil in the owner's manual. You may need to follow those recommendations to keep a new car in warranty.
Oil changes: How often?
The long-time mantra of auto mechanics has been to change your oil every 3000 miles. Most automakers recommend an oil change every 7,500 miles (and a specific time interval) for "normal" driving, and every 3,000 miles for "severe" driving - frequent trips of less than four or five miles, stop-and-go traffic, extended idling, towing a trailer, or dusty or extremely cold conditions. Many motorists' driving falls into one or more of those "severe" categories.
In our survey, almost two-thirds of our readers said they had their oil changed every 3,000 miles or less. They may be following the thinking expressed by one of our staffers: "I have my oil changed every 3,000 miles because that's what my father did, and all his cars lasted for many years."
To determine whether frequent oil changes really help, we changed the oil in three cabs every 3,000 miles, using Pennzoil 10W-30. After 60,000 miles, we compared those engines with the engines from our base tests of the same oil, changed every 6,000 miles. We saw no meaningful differences. When Mobil 1 synthetic oil came out, Mobil presented it as an oil that, while expensive, could go 25,000 miles between changes. That claim is no longer being made. But Mobil 1 is still on the market, selling at a premium (along with pricey synthetic competitors from several other companies). And synthetic oil's residual reputation as a long-lasting product may still prompt some people to stretch their oil changes longer than the automaker recommends.
Determining whether synthetic oils last longer than conventional ones would require a separate test protect. To try to get some indication, we put Mobil 1 synthetic into three cabs and changed their oil every 12,000 miles.
We intended to compare the results of these tests with those from the three taxicabs whose Mobil 1 was changed at our normal interval, every 6,000 miles. Unfortunately, two of the three engines using the 12,000-mile interval developed problems. (We couldn't attribute those problems to the oil.) The third engine fared no worse than the three whose oil had been changed at 6,000-mile intervals.
The bottom line. Modern motor oils needn't be changed as often as oils did years ago. More frequent oil changes won't hurt your car, but you could be spending money unnecessarily and adding to the nation's energy and oil-disposal problems.
Even in the severe driving conditions that a New York City taxi endures, we noted no benefit from changing the oil every 3,000 miles rather than every 6,000. If your driving falls into the "normal" service category, changing the oil every 7,500 miles (or at the automaker's suggested intervals) should certainly provide adequate protection. (We recommend changing the oil filter with each oil change.)
We don't recommend leaving any oil, synthetic or regular, in an engine for 12,000 miles, because accumulating contaminants - solids, acids, fuel, and water - could eventually harm the engine. What's more, stretching the oil-change interval may void the warranty on most new cars.
Testing Slick 50 and STP
We also tested Slick 50 and STP Engine Treatments and STP Oil Treatment, each in three cabs. (Slick 50 costs $17.79 per container; STP Engine Treatment has been discontinued.) All three boast that they reduce engine friction and wear.
The engine treatments are added with the oil (we used Pennzoil 10W-30). They claim they bond to engine parts and provide protection for 25,000 miles or more. We used each according to instructions.
The STP Oil Treatment is supposed to be added with each oil change. It comes in one formulation (black bottle, $4.32) for cars with up to 36,000 miles, another (blue bottle, $3.17) for cars that have more than 36,000 miles or are more than four years old. We used the first version for the first 36,000 miles, the second for the rest of the test-again, with Pennzoil 10W-30.
When we disassembled the engines and checked for wear and deposits, we found no discernible benefits from any of these products.
The bottom line. We see little reason why anyone using one of today's high-quality motor oils would need these engine/oil treatments. One notable effect of STP Oil Treatment was an increase in oil viscosity; it made our 10W-30 oil act more like a 15W-40, a grade not often recommended. In very cold weather, that might pose a risk of engine damage.
Recommendations
None of the tested oils proved better than the others in our tests. There may be small differences that our tests didn't reveal, but unless you typically drive under more severe conditions than a New York cab does, you won't go wrong if you shop strictly by price or availability. Buy the viscosity grade recommended in your owner's manual, and look for the starburst emblem. Even the expensive synthetics (typically, $3 or $4 a quart) worked no better than conventional motor oils in our taxi tests, but they're worth considering for extreme driving conditions high ambient temperatures and high engine load or very cold temperatures.
On the basis of our test results, we think that the commonly recommended 3,000-mile oil-change interval is conservative. For "normal" service, 7,500-mile intervals (or the recommendation in your owner's manual) should be fine. Change the oil at least that often to protect your engine and maintain your warranty. Even for the severe service experienced by the taxis in our tests a 6,000- mile interval was adequate. But some severe service - frequent cold starts and short trips, dusty conditions, trailer towing - may require a shorter interval. Note, too, that special engines such as diesels and turbos, which we didn't test, may need more frequent oil changes.
We don't recommend stretching the change interval beyond the automaker's recommendations, no matter what oil you use. Engine combustion contaminants could eventually build up and harm engine parts.
As for STP Oil Treatment, STP Engine Treatment, and Slick 50 Engine Treatment, our advice is simple: If you use an oil with the starburst symbol, you don't need them.
New York City taxicabs played a key role in our massive test project to evaluate motor oils. For consistency, we used only 1992-93 Chevrolet Caprice cabs. Each received a precisely rebuilt 4.3-liter V6 at the beginning of its 60,000-mile test. We started with six rebuilt engines; after each engine was installed in a cab, the six engines that were removed were rebuilt and installed in six other cabs-and so on. Using that rotation, we monitored 75 cabs over 4-1/2 million miles of driving in New York City and its environs. Each oil was tested in three engines.
A local shop completely machined each engine block and crankshaft, rebuilt the cylinder heads, and installed new bearings, pistons, rings, seals, gaskets, and oil pump. Though the engines originally had roller lifters and camshafts, a design that reduces friction, we installed conventional sliding lifters and camshafts to accelerate wear.
Before the engines were assembled, we measured or weighed the parts most likely to show wear if the oil wasn't doing its job - the camshafts, valve lifters, and connecting-rod bearings. Each cab went through a break-in procedure before hitting the road. During testing, two engine timers measured the time the engine was running and the time it was in gear.
Over the next 22 months, our engineers paid more than 100 calls - usually without notice - on the fleet garage. They dropped off test oil and picked up used-oil samples for ongoing analysis. They also made sure that oil was being added to the engines when necessary and changed as scheduled.
After each 60,000-mile test, we remeasured the key engine parts. We also examined combustion-chamber deposits, the color of the valves, scoring of cylinder walls, and valve-deck deposits for any sign of engine problems.
It's not just oil
Certainly, motor oil is slippery. That's what helps protect an engine's moving parts. But motor oil does much more than lubricate. It helps cool the engine keep it clean, prevent corrosion, and reduce friction to improve fuel economy. To do all that, refiners blend in various additives, which account for 10 to 25 percent of the product you buy.
The oil industry has devised a starburst symbol (described at the bottom of this article) to certify that a particular motor oil meets the latest industry requirements for protection against deposits, wear, oxidation, and corrosion. The starburst on the label means the oil meets API (American Petroleum Institute) Service SH requirements - the latest, most advanced formulation. (Service SH supplants SG, the previous top category.) The CD designation on most of the oils we tested refers to diesel performance. The starburst also indicates that the oil passes ILSAC/GF-1 standards developed by the International Lubricant Standardization and Approval Committee, a U.S.-Japanese group. And it means the oil meets Energy Conserving II requirements - it improves fuel economy by reducing engine friction. All the oils we tested carry the starburst - and all performed well in our tests. But note that oils without that symbol may not perform as well.
Below are some of the additives found in modern oils.
Viscosity-index improvers modify the oil so its viscosity is more consistent over a wide temperature range.
Antioxidants prevent the oil from thickening when it runs hot for extended periods.
Dispersants keep contaminants suspended so they don't form deposits in engine.
Detergents help prevent varnish and sludge on engine parts and neutralize acid formed in engine.
Rust and corrosion inhibitors protect metal parts from acids and water formed in engine.
Pour-point depressants help the oil flow in a cold engine, especially in cold weather.
Foam inhibitors collapse the bubbles churned up by engine crankshaft. (Foam reduces lubricating effectiveness.)
Friction modifiers strengthen the oil film and prevent unlubricated contact between moving parts.
Antiwear agents provide lubrication when oil is squeezed out from between moving engine parts.
The starburst symbol is a circle with a serrated edge about an inch across with text which reads "AMERICAN PETROLEUM INSTITUTE CERTIFIED FOR GASOLINE ENGINES."
Ratings & Recommendations Motor oils
Shopping strategy
Discount stores are generally the least expensive place to buy oil. Look for sales and buy by price - but make sure the container has the starburst symbol.
Details Listed alphabetically
All the tested oils performed well in our tests, and all claim to meet the latest (API-SH and ILSAC/GF-1) industry standards (see "It's not just oil," article 3 of 4). Prices are the average for one quart, based on a national survey of discount stores.
5W-30 oils
Castrol GTX $1.21
Appears to use same formulation in all areas sampled. Graduated container.
Exxon Superflo
Price not available; not widely found in discount stores. Appears to use same formulation in all areas sampled. Graduated container with window.
Fire & Ice All-Season (Shell) * $0.93
Different formulations in Florida and New York. Graduated container with window.
Havoline Formula 3 (Texaco) $1.11
Mobil * $0.95
Pennzoil $1.16
Quaker State Deluxe * $1.20
Appears to use same formulation in all areas sampled. Graduated container with window. 10W- 30 is called Super Blend.
Valvoline All-Climate $1.14
Different formulations in California and Texas. Graduated container with window.
10W-30 oils
Castrol GTX $1.18
Exxon Superflo $1.13
Different formulation in Florida. Graduated container with window.
Fire & Ice All-Season (Shell) * $0.99
Havoline Formula 3 (Texaco) * $1.13
Different formulations in Illinois and Texas. Graduated container with window.
Kendall Superb 100 * $$1.23
Different formulation in Florida. 5W-30 version not tested.
Mobil 1 synthetic $3.76
Low-temperature flow characteristics were better than most. Appears to use same formulation in all areas sampled. 5W-30 version not tested. Graduated container with window.
Mobil $0.95
Different formulation in New York. Graduated container with window.
Pennzoil $1.16
Pennzoil Performax synthetic $2.97
Low-temperature flow characteristics were better than most. No 5W30 version. Appears to use same formulation in all areas sampled.
Quaker State Super Blend * $1.20
Appears to use same formulation in all areas sampled. Graduated container with window. 5W-30 is called Deluxe.
Valvoline All-Climate $1.13
Different formulation in California. Graduated container with window.
Valvoline Semi-Synthetic DuraBlend Conventional/synthetic blend * $2.12
Appears to use same formulation in all areas sampled. Graduated container with window, No 5W-30 version. Flow characteristics were more like those of a conventional oil than those of a synthetic.
* One or more samples differed from viscosity-grade requirement by a small amount.
The table below shows price ranges of five popular 10W-30 oils in discount stores and auto-parts stores, on the basis of a national survey. Discount stores account for an estimated 51 percent of do-it-yourself oil sales; auto-parts stores, nearly 35 percent. Service stations tend to be the most expensive, charging as much as $2.50 a quart.
Discount
Store Retail Auto
Parts Store
Castrol GTX
Havoline Formula 3
Pennzoil
Valvoline All-Climate $0.89-1.69
$0.97-1.49
$1.08-1.39
$1.06-1.69
$1.07-1.69 $1.24-1.80
$1.09-1.61
$1.24-1.89
$1.19-1.80
$1.22-1.99
