Old 09-03-2004, 07:13 AM
SMOKEATR's Avatar
Dealer : Mike Erdman Toyota Scion
2006 Toyota Tacoma
Last Online: 08-27-2009 03:48 PM
SMOKEATR is on a distinguished road.
Send a message via ICQ to SMOKEATR Send a message via AIM to SMOKEATR Send a message via Yahoo to SMOKEATR SMOKEATR's Photo Albums
Default Oil
What's the best oil to run in the 4.7 Tundra?
06 4x4 non TuRD with some added crap.
http://i4.photobucket.com/albums/y11...R/IMG_0998.jpg
Old 09-03-2004, 10:27 AM
scdtrd's Avatar
Dealer : Lagrange Toyota
Last Online: 02-09-2009 04:48 PM
scdtrd is on a distinguished road.
scdtrd's Photo Albums
That is like asking what is the best vacation spot!
For me... it is Amzoil 20-50 race blend..
That is my .02
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Old 09-03-2004, 10:47 AM
RWK RWK is offline
SERVING LIFE HERE
Dealer : Langley Toyotatown
2004 Toyota Tundra
Last Online: 05-11-2008 09:20 PM
RWK is on a distinguished road.
RWK's Photo Albums
I run Amsoil Series 2000, 0-30w Synthetic (Severe Service)
2004 DC Limited 4x4//JBA Headers & Y PIPE//Firestone Rear Air Lift//Hellwig Sway Bar//Protech EZ 1" Lift//Air Induction//Ledco Custom Rack
Raider Canopy//Street Scene Grill//Magnaflow Muffler//Piaa Lights//Amsoil Fluids//Nokian WR Shoes//Unichip//Westin Bull Bar.
Old 09-03-2004, 11:35 AM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX,
2009 Toyota Camry HV (wife's car)
Last Online: 10-04-2009 05:29 PM
THarms is on a distinguished road.
THarms's Photo Albums
any good synthetic. Amsoil, Mobil 1, etc... (I personally am currently running Amsoil Series 3000 5W-30).
Make sure you use a good quality filter as well... It is just as important (if not more so) than the oil. I highly, highly, highly recommend the Amsoil SDF-15 filter.
Old 09-03-2004, 12:34 PM
mitchr's Avatar
Dealer : Phil Bachman Toyota
Last Online: 10-28-2009 11:01 AM
mitchr is on a distinguished road.
mitchr's Photo Albums
I run Mobile1 synthetic 10w30 and a PureOne oill filter. The main thing is to use a good oil and if you use non-synthetic oil I would change it at 3000 miles. I run the synthetic to 5000 miles and I have heard of other members running it as high as 10,000 miles.
Mitch
Old 09-03-2004, 12:39 PM
Dealer : Fremont Toyota
Last Online: 12-18-2008 10:29 AM
Trouthead is on a distinguished road.
Trouthead's Photo Albums
Default motul, Amsoil, Mobil 1, Delvac 1, etc etc
I have used most of the above with oil analysis. You are good in most conditions for 10-12 thousand miles on most if not all of the above. Use an oversized filter, either amsoil, or Mobil 1 and don't waste time or money changing oil too often. Oil analysis really pays off in telling you how much oil life you have left.
If you want to be super conservative, change at 8-10 thousand, and forget the oil analysis (after doing one).
Old 09-03-2004, 01:19 PM
Dealer : Stevens Creek Toyota
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
I'd agree 100%. After the warrantee had worn off I'd run mobil1 synthetic (5w30 or 10w30 if you're in a year round warm climate) at 10,000 to 12,000 miles *and* run it with an Amsoil SDF 15 filter. I'd do at least one oil analysis on *your* engine to make sure that flies but it's 99.9% sure it will.
But any good synthetic in the 5w30 or 10w30 range will work fine along with a good filter so just use what's locally available.
If you choose to run regular oil, change it every 5,000 miles but still use one of the best filters (amsoil, mobil1, pureone).
But wait until you hit 10,000 miles with regular oil until you start putting synthetic in. You'll get better gas mileage on the front side. On a diesel engine (vs gas) this is much more critical to wait until 10k.
If you use synthetic but don't change the intervals to 10,000 miles or more it's going to be more expensive and you'll be throwing away good oil. It's kind of like throwing away tires when only half the tread is worn. There may be good reasons for doing that for some people but it's a waste of perfectly good performance for most people.
Alan
Old 09-04-2004, 03:34 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I prefer to use the highest viscosity oil permitted in the owner's manual...10W-30 in the summer and 5W-30 in cold winter areas. If the engine is working hard & hot, I like a 15W-40 or 5W-40 oil. I know, this isn't in our U.S. or Canadian owner's manual, but the same 2UZ-FE engine in Australia has 20W-50 recommended by Valvoline & BP.
Among conventional oils, I like Chevron/Havoline, Pennzoil, and Castrol. Among synthetics, Mobil 1, Schaeffer, Amsoil, and Castrol.
The new oil spec, ILSAC GF-4, will soon be on the shelves instead of the current GF-3. This is a tougher spec for the oil, and requires higher quality (higher cost) ingredients. Some oil makers are blending low quality (cost) conventional oil with some synthetic as a correction fluid to meet the spec, and trumpeting it as synthetic blend. It is, but it isn't anything special. An equally good or maybe better oil can be made from higher quality (cost) conventional oil. ConocoPhillips is one of the oil makers using this cheap synthetic blend to get their GF-4 oil at at the lowest production cost. Their brands are Conoco, Phillips, 76, & Kendall.
Don't run a synthetic beyond the recommended 7500 miles without a satisfactory oil analysis to protect your warranty.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 09-08-2004, 12:09 PM
Void's Avatar
Dealer : Toyota of Santa Cruz
2004 Toyota Tundra
Last Online: 10-13-2006 04:23 PM
Void is on a distinguished road.
Void's Photo Albums
Default Oil from the factory?
I just got my Double Cab on Saturday and one of the last things the salesman said to me was to not change the intial factory oil until after 4500 miles because it's break-in oil. Is this true and what type of oil does the truck come pre-filled with?
Old 09-08-2004, 12:25 PM
mitchr's Avatar
I think that is B.S. Alot of people only run the first oil around a 1000 miles and then change it to get rid of any "junk" (metal shavings, ect) that may be in the engine.
Mitch
Old 09-08-2004, 01:39 PM
Desertnate's Avatar
Dealer : Newbold Toyota - Scion
2001 Toyota Sequoia
Last Online: 10-26-2009 10:47 AM
Desertnate is on a distinguished road.
Desertnate's Photo Albums
Mitch
I agree, why on earth would you run longer on the "break in oil" than you would on regular motor oil (if that is what it ships with). It was recommended to me that the break in oil change should occur around 1000~1500 miles and there should be regular oil in the engine. Once that period has lapsed and the oil changed go synthetic.
Old 09-08-2004, 02:32 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I believe only Honda has a special break in oil.
Dump that oil early. It can't do any harm and might do some good.
Ken
Old 09-08-2004, 03:48 PM
Void's Avatar
2004 Toyota Tundra
Void's Photo Albums
Thanks for the replies, much appreciated.
Deceided to go 1,500 then another 3,500 on Dino and then Synthetic at 5,000.
Old 09-08-2004, 04:04 PM
HBjeff's Avatar
Dealer : Carson Toyota Scion
2005 Toyota Tundra
Last Online: 11-03-2009 11:19 PM
HBjeff is on a distinguished road.
HBjeff's Photo Albums
5k miles on the initial oil!!! EEK thats really bad.
do a change at 500 miles. it can ONLY do good things for your motor.
i myself have used synthetics in the past, but i prefer a quality conventional oil now. it just suits my driving style(i dont drive much). so i can change the dino oil every 2500 for less than sythetic at 7500 or so. i cant imagine running that long without a change though. when i used synthetics i still changed it at 3000.
Old 09-09-2004, 01:02 PM
Default don't believe the salesman
Although intuitively it would seem that the salesman should know what he is talking about, for the most part this will never be the case. There is no reason to leave factory oil in for any amount of time.
Also not switching to syn oil untill it is broken in is an old wives tail. Syn oil is good, but you engine is still going to wear in or break in. Syn does not stop all wear.
