Old 09-07-2004, 09:28 PM
4cloud9's Avatar
Dealer : Poway Toyota
2003 Toyota Tundra
Last Online: 11-20-2008 12:34 AM
4cloud9 is on a distinguished road.
4cloud9's Photo Albums
Question A/T V6 Gearing question?
I was trying to find info on the site for what ratio and size gears are in my v6 tundra, many poeple stated that the gearing was 4.10.
But on this site http://www.brian894x4.com/Gearratiosanddiffs.html with the chat provided at the bottom of the page it would appear that my truck has:
A= 8" size gears
02= 3.58
A= 2 pinion open dif.
yet another
http://www.toysport.com/Technical%20...ifications.htm
claims:
A= 138mm
02= 3.36
A= nothing designated for a letter in the thrid digit. I know it's not an LSD so I think the other site is right about the diff. type
So which is it does anybody now for sure?
When I get 33's I am definately going to re-gear.
Thanx- 4cloud9
Old 09-07-2004, 10:39 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:24 AM
nhparrot's Photo Albums
A= 8" size gears
02= 3.58
yet another
claims:
A= 138mm
02= 3.36
Thanx- 4cloud9
2wd
Transmission Type - A340E
Transmission Gear Ratio:
In First - 2.804
In Second - 1.531
In Third - 1.000
In Fourth - 0.705
In Reverse 2.393
Transfer Gear Ratio H4/L4 -
Differential Gear Ratio (Front/Rear)- — / 4.083
Differential Gear Size (Front/Rear) in. - — / 8”
4wd
Transmission Type - A340F
In First - 2.804
In Second - 1.531
In Third - 1.000
In Fourth - 0.705
In Reverse 2.393
Transfer Gear Ratio H4/L4 - 1.000 / 2.566
Differential Gear Ratio (Front/Rear)- 4.300 / 4.300
Differential Gear Size (Front/Rear) in. - 7.5” / 8”
~Glenn
Old 09-07-2004, 11:25 PM
Dealer : Arlington Toyota Scion
Last Online: 12-05-2008 10:15 PM
rjmmmay is on a distinguished road.
rjmmmay's Photo Albums
Mr Parrot: If I were to install the 4.30s into my 2000 4WD V8, would I be able to use the driven speedo gear from the V6 to keep my speedo reading correctly? Thanks.
Marty
Old 09-08-2004, 12:19 AM
4cloud9's Avatar
2003 Toyota Tundra
Thumbs up
[QUOTE=nhparrot]2wd
Differential Gear Size (Front/Rear) in. - — / 8”QUOTE]
Thanx nhparrot,
That is the answer to the question I was looking for.
So in my auto I have 4.08 ratio which is close enough to call it 4.10.
Thanx alot for your help and your knowledge, once again you come through with the answer.
Old 09-08-2004, 12:28 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Marty
If your going to go to 33's for tires, i would suggest 4.56's for gears.The 4.30 is not enough gear to bring back the torque yur going to lose with the big tires. The speedo will be off, and the V-6 gear wont fix it. Nobody makes a gear to fix this, it has to be done electronically.You have to get speedo recalibrator here are some other forums for more answers 285's
25 yrs with TOYOTA
Old 09-08-2004, 07:55 PM
Victor,
Thanks for the feedback. I was considering it with 275/70-16s to get a little more torque with the possibility of having a simple speedometer correction solution. The project would be mostly for my own entertainment as opposed to looking for big torque gains.
Regards,
Marty
